Old 02-22-2022, 01:17 PM   #673
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Locust View Post
Was this at Crow's? Not sure the gain from 18s at the top is going to outweigh the quicker accel from 17s, even at Crow's with 3rd gear usually being mandatory. How prepped is that CT-R? I don't know the driver but just looking at index times for S1 and SMP that's looking *maybe* competitive with a full setup. 1.6s off on index is a lot. But hey it straight timed STX?
Yes, Crows, not many digs, some sections of rev limiter and a third gear shift so the gearing helped imho, I’d be surprised if it was a significant negative anyway. I wouldn’t put much stock in stx times, my car is far from dialed, I’ve got a whole paragraph of excuses that nobody cares about lol but I did find half a second in the first fun run (and was able to repeat it) and after watching Marks video there was easily more on the table. The Civic is a shaftworks testbed, it also ran FSP this weekend, I don’t think it’s “ready” either, Adrian is a very good driver though.
Fifteenth in pax for an undeveloped car is a good sign, I have no doubt it will get faster, top fifteen is loaded with champs and trophy winners in developed cars and the CTR placed very well regardless of pedigree.
I’ll just post the videos because nobody will benefit from me tap dancing around it, they’re public for a reason.
DS 57.044
STX 57.200
ineedyourdiddly
Aroundomaha (03-10-2022)
Old 02-26-2022, 07:11 AM   #674
des
des's Avatar
Originally Posted by simpleisbest View Post
0.375 behind CS ND MX5
0.264 behind DS CTR
Maybe with shocks and some alignment tweaks the car will be able to carve out its spot in D-Street.
Not the overdog it seems
Mark got significantly faster with a few more (fun) runs, still thinks it's a jump ball. Also, he says the CTR driver is pretty darned good.
22mm Perrin and crash bolts on mine -- just 1.5 tho. Is that fairly typical so far?
des is offline   Reply With Quote
The Following 2 Users Say Thank You to des For This Useful Post:
DocWalt (02-28-2022), simpleisbest (02-27-2022)
Old 02-28-2022, 11:07 AM   #675
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I got -1.3 with the crash bolts, sounds about right
The Following 2 Users Say Thank You to DocWalt For This Useful Post:
des (03-06-2022), timurrrr (02-28-2022)
Old 02-28-2022, 02:39 PM   #676
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
Yeah, I'm at 1.1 and 1.6 L/R
MacSpeed is offline   Reply With Quote
The Following User Says Thank You to MacSpeed For This Useful Post:
des (03-06-2022)
Old 02-28-2022, 04:11 PM   #677
strat61caster
Shifting the subframe might help even that out fyi, a good alignment place can be willing to put in the effort to do that.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
DocWalt (03-01-2022), MacSpeed (02-28-2022)
Old 02-28-2022, 09:16 PM   #678
SCFD
That's pretty amazing for OE crash bolts. Most people are only able to get closer to -1*.
SCFD is offline   Reply With Quote
The Following User Says Thank You to SCFD For This Useful Post:
des (03-06-2022)
Old 03-01-2022, 08:36 AM   #679
steverife
Drives: 2016 Scion FRS
I couldn't find an alignment shop that would touch the subframe, but if it is like the 1st gen, it isn't terribly difficult at all. And a 1 or 2mm shift made a massive different in alignment numbers. The biggest challenge is physically getting the subframe to shift. Had to get creative with ratchet straps.
steverife is offline   Reply With Quote
The Following 2 Users Say Thank You to steverife For This Useful Post:
des (03-06-2022), strat61caster (03-01-2022)
Old 03-07-2022, 08:27 AM   #680
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Just from watching you on course on Saturday, looks like it might be time for a smaller FSB? The Perrin 19mm is probably the better option.
trippinbillies40 is offline   Reply With Quote
The Following 2 Users Say Thank You to trippinbillies40 For This Useful Post:
Aroundomaha (07-04-2022), des (03-07-2022)
Old 03-07-2022, 01:10 PM   #681
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Based on math, I'd definitely do the smaller Perrin bar for the BRZ. GR86 *maybe* needs the 22mm but I doubt it.
The Following User Says Thank You to DocWalt For This Useful Post:
des (03-07-2022)
Old 03-13-2022, 03:23 PM   #682
des
des's Avatar
Not sure if Steven Hughes is on here but would love to know setup info on the Red Hills NT winner (may be Terry McIntyre's car).
And congrats -- fun to listen in on your win! A lot of great talent behind you.
Old 03-14-2022, 10:37 AM   #683
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
I’m Terry, that’s my car. It’s 245 falkens on RPF1 with a +48 offset. 6mm spacer in front. Nothing out back. Karcepts bar. MCS 2w up front and stock rears until perch are ready on April. AEM dry filter on the intake.
Here’s our Day 1 video:
Day 2 on Stevens 43.1 the RJ45 slipped out of the RC and stoped recording everything about 15s into the run but here’s my sloppy overdrive LOL
The Following 6 Users Say Thank You to MacSpeed For This Useful Post:
Autoxer62 (03-14-2022), des (03-14-2022), DocWalt (03-14-2022), edj (03-14-2022), Kelse92 (03-14-2022), strat61caster (03-14-2022)
Old 03-15-2022, 09:17 PM   #684
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I can't see why they wouldn't clear. At worst, buy cheap 3mm spacers.
BlkTrax (03-16-2022)
Old 03-15-2022, 10:39 PM   #685
strat61caster
There should be zero problems, I had 17x9+40 245/40/17 at over -2 degrees with just bolts for awhile.
ineedyourdiddly
Old 03-16-2022, 05:26 PM   #686
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Originally Posted by BlkTrax View Post
TLDR: Will 225/45-17 Falken 660's on OEM 17x7.5+48 Wheels; Clear the Front Strut perch with Crash Bolts Installed? (without spacers)
Shouldn't have any issues. I've run 225/45/17 Re-71's on +53 STI wheels and they just barely cleared in the front.
Ran the A052's last year on the 2017 PP wheels which are the exact same specs as the 2022's. 3mm spacer, but had plenty of clearance with the OEM camber bolts and ~1.1*.
I have RT660's in the same 225/45/17 size sitting in my living room right now.
If you read above, you can fit 245/40/17 on a 17x7.5 +48 with a 6mm spacer (aka, +42). If you can fit that with a 245, 225 is nothing.
cmiovino is offline   Reply With Quote
The Following User Says Thank You to cmiovino For This Useful Post:
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 10:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 03:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 01:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
