Old 02-22-2022, 09:06 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
2022 Twin to STR
Finally classed to STR
https://cdn.connectsites.net/user_fi...pdf?1645577607
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 8 Users Say Thank You to Simmons For This Useful Post:
Autoxer62 (02-23-2022), bholliday (02-23-2022), Breezio (02-22-2022), otter (02-22-2022), SCFD (02-23-2022), strat61caster (02-22-2022), timurrrr (02-22-2022), whataboutbob (02-22-2022)
Old 02-22-2022, 09:11 PM   #2
whataboutbob
AutoX-10/10ths every run
...#31899 2022 Twins are Rad
Thank you for your input...
lol
Build thread:Here
Old 02-22-2022, 11:54 PM   #3
Banannie
Drives: 2022 BRZ, 2008 S2K CR Delete
lol
That was my letter I said to class the damn car in STR as there's really no where else to put it, no additional time is going to magically make it reasonable to put it in STX, etc. I said do that, or give it it's own provisional STX2 class, which is why I got a TYFYI
Banannie is offline   Reply With Quote
The Following 3 Users Say Thank You to Banannie For This Useful Post:
strat61caster (02-23-2022), timurrrr (02-24-2022), whataboutbob (02-26-2022)
Old 02-23-2022, 09:23 AM   #4
Autoxer62
This should make for some interesting STR battles.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
Old 02-23-2022, 11:24 AM   #5
PointDSM
PointDSM's Avatar
Drives: 2013 Subaru BRZ
I love that Gen1's get a longer lifespan in STX. It'll create a great battle in STR and leave STX as-is (which is perfect).
PointDSM is offline   Reply With Quote
The Following 4 Users Say Thank You to PointDSM For This Useful Post:
DocWalt (02-24-2022), Molez93 (02-23-2022), strat61caster (02-23-2022), timurrrr (02-24-2022)
Old 02-23-2022, 04:29 PM   #6
racingfool
racingfool's Avatar
Drives: Miata
Classing the FR-S and BRZ in DSP is not considered in the best interests of the category.
However, the committee is interested in feedback regarding classing them in BSP.
Thus the SPAC is requesting member input regarding the following classing change proposal:
BSP
Scion & Subaru
FR-S & BRZ (2013-2016)
FR-S & BRZ (2017-2020)
Why on separate lines?
Put them on the same line along with the 2022 and update/backdate engines and final drives?
racingfool is offline   Reply With Quote
Old 02-23-2022, 07:07 PM   #7
Autoxer62
Write a letter and ask for that. It certainly seems reasonable to ask for all the first gens to be on the same line.
The Following User Says Thank You to Autoxer62 For This Useful Post:
Old 02-24-2022, 05:27 AM   #8
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
STX participation will take a noticable hit though. Don't get too comfortable if numbers slip a lot this year.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 02-24-2022, 04:05 PM   #9
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
They probably meant that 2017- is 86, not FR-S.
Old 02-26-2022, 02:07 PM   #10
Simmons
Simmons's Avatar
I got the rains mounted,.....that should mean it will never rain right?
The Following 3 Users Say Thank You to Simmons For This Useful Post:
dowroa (05-31-2022), racingfool (02-26-2022), smg1138 (09-28-2022)
Old 02-26-2022, 06:03 PM   #11
whataboutbob
lol, didn't notice the screenname initially. I'm assuming it is way past time for you to get a new car :P
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
strat61caster (02-26-2022)
Old 02-26-2022, 07:43 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Well because they’re on separate lines you can’t swap parts between them, yes the frs/2017 is a typo but not the underlying problem they’re looking at.
One of the neat/terrible things about street prepared is update/backdate, so you Could legally put a 2017+ engine with the extra 5hp into a 2013 chassis assuming the cars are on the same line in the classing, which it’s currently proposed that they are not. If the ‘22+ ends up on the same line you could put the 2.4L into an early car. The gearing options may be worth considering as well, not sure much else is. On the newer cars a knuckle swap might be interesting.
Whether that’s the right call idk, not many people are interested in playing with those rule sets these days, it’a a lot of work for not a ton of gain.
ineedyourdiddly
DocWalt (02-28-2022)
Old 03-20-2022, 08:59 PM   #13
Simmons
Simmons's Avatar
My 1st event in the brz. It was a test and tune and was around 48 degrees.
The Following User Says Thank You to Simmons For This Useful Post:
DocWalt (03-23-2022)
Old 04-04-2022, 11:26 AM   #14
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
First autocross weekend in the history books! The car is phenomenal! I tested back to back with an ND2 Miata in STR and I don't think we can hang in STR yet (but it will be close with tunes to fix the low rev limiter) but the car is so dang fun I don't even really care. Love the easy adjust Karcepts swaybar and the Shaftworks USA shocks. I made one swaybar change early Saturday at the Test and Tune (math said I should have been where I ended up, but I was lazy and set the swaybar softer) and I didn't do anything for shocks, adjustment wise. I'm really really happy with the car.
My Saturday TnT run:
Amy's TnT run:
Sunday's event was defined by crummy off and on rain. I made no changes for the wet and I was clearly the fastest in the wet, but it dried out and I coned away my fast run, then it rained again for Amy and she was faster in the rain than in the dry but coned it away too. Ignore the squeaking in the video, we left our trunk junk in because of the rain and the mic was picking up the squeaky styrofoam. I'll share our faster runs first.
My fastest raw time:
Amy's fastest raw time:
My fastest clean run:
Amy's fastest clean run:
The Following 6 Users Say Thank You to DocWalt For This Useful Post:
bcj (04-04-2022), Desertnate (04-04-2022), Kado (04-04-2022), RedReplicant (05-05-2022), Simmons (04-11-2022), strat61caster (04-04-2022)
2022 Twin to STR Simmons BRZ Second-Gen (2022+) — General Topics 11 03-01-2022 11:03 AM
2022 GR86 Premium Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku GR86 General Topics (2nd Gen 2022+ Toyota 86) 13 02-13-2022 12:44 AM
2022 BRZ Limited Results @ Car and Driver Lightning Lap 2022 Competition Hachiroku BRZ Second-Gen (2022+) — General Topics 20 02-10-2022 12:44 PM
2022 Toyota Land Cruiser Revealed With New Platform, Twin-Turbo V6 vh_supra26 Other Vehicles & General Automotive Discussions 24 07-07-2021 02:44 PM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
