Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-21-2022, 04:59 PM   #29
otter
Drives: 22 BRZ
Originally Posted by Desertnate View Post
Maybe I'm over simplifying things, but is there any reason you couldn't get two screws, paint the heads with touch up paint, and screw them into the threaded sleeves?
I'm thinking a couple small hex head screws would work and not look too bad.
Panhead screw would be the way to go, IMO. I have to run a front plate (will drill the plate so I can use threaded holes) but if I didn't, I'd used some touchup paint on some panheads and call it a day. Thread is 6mm x 1.0 if anybody is curious.
otter is offline   Reply With Quote
The Following User Says Thank You to otter For This Useful Post:
Desertnate (02-22-2022)
Old 02-21-2022, 05:22 PM   #30
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
Originally Posted by Krokodil View Post
There are dedicated locations on a front bumper where you can put a plate mounting screws. Same as on most of the cars. Same as on BRZ rear bumper.
Yes, I understand that. The post I was responding to mentioned that the threaded inserts in the front need to be 'knocked out' in order to install the plugs, which would mean if you wanted to then run a tag in the future (or the next owner wants/needs to), you'd have to come up with another method for securing, as the inserts will no longer be available..
LRNAD90 is offline   Reply With Quote
Old 02-21-2022, 06:19 PM   #31
EZLVN
Drives: 2022 BRZ Premium, 1990 Miata
Here’s a couple of pics.
I threaded a license plate bolt a couple of turns into that exposed sleeve on the flat bumper area.
I then used my thumb to push in on the head of the bolt.
Doesn’t take huge force.
That metal bracket you see in the first pic dislodges from the backside of the bumper and falls straight down.
You can reach into the bottom of the grill and pull it out.
I then popped in the custom painted plugs I got from bumper plugs.com.
Took less than five minutes.
Granted, I live in a state that doesn’t require front plates.
The plugs ain’t cheap at 30.00 pair, but this huge eyesore is out of my head.
EZLVN is offline   Reply With Quote
The Following User Says Thank You to EZLVN For This Useful Post:
Krokodil (02-22-2022)
Old 02-21-2022, 06:22 PM   #32
EZLVN
Not sure why my pics aren’t loading but hopefully you got the idea.
Old 02-21-2022, 07:10 PM   #33
MikeNSX2
Drives: Ice Silver 2022 BRZ Limited
I would love to see pictures when you can post them.
Did you buy the plugs for the factory round holes or the small screw holes?
I had these on several Porsches' I've owned in the past, and they are very high quality and match perfectly.
MikeNSX2 is offline   Reply With Quote
Old 02-21-2022, 07:52 PM   #34
EZLVN
These are the plugs for the “factory round holes”
The Following 3 Users Say Thank You to EZLVN For This Useful Post:
Krokodil (02-22-2022), MikeNSX2 (02-21-2022), Simmons (02-21-2022)
Old 02-21-2022, 07:54 PM   #35
EZLVN
This is the bracket that knocked out.
The Following 2 Users Say Thank You to EZLVN For This Useful Post:
Krokodil (02-22-2022), Simmons (03-12-2022)
Old 02-22-2022, 09:39 AM   #36
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
WEIGHT SAVINGS!!!!!! (Joke)
SpectreRT is offline   Reply With Quote
The Following User Says Thank You to SpectreRT For This Useful Post:
Old 02-22-2022, 01:45 PM   #37
Perseus0001
Drives: 2022 BRZ
Anyone happen to have a zoomed out before and after photo...
Up close the before and after just doesn't impress me. The factory screw holes and the plugs seem to equally draw my attention, but maybe when looking at the car as a whole the improvement is more obvious?
Perseus0001 is offline   Reply With Quote
Old 03-03-2022, 09:36 PM   #38
Krokodil
Drives: Blue BRZ
Originally Posted by PhatFreshPrince View Post
I am done with the front bumper for now. I got these at Ace Hardware and they match the black trim nicely.
I think you came up with a very efficient solution.
Thank you very much for sharing!
Krokodil is offline   Reply With Quote
The Following User Says Thank You to Krokodil For This Useful Post:
PhatFreshPrince (03-04-2022)
Old 03-03-2022, 10:21 PM   #39
MikeNSX2
Do you have the part # for these?
Thanks.
Old 03-08-2022, 06:17 PM   #40
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
The part number I used is 58570-A. FYI, I did have to trim it down a little with a razor blade at its widest point. I also twisted it in using the internal threads. It’s worth it to me for only a $1.50.
PhatFreshPrince is offline   Reply With Quote
The Following 2 Users Say Thank You to PhatFreshPrince For This Useful Post:
Midnightsky (12-15-2022), MikeNSX2 (03-08-2022)
Old 03-12-2022, 01:05 AM   #41
Camilobrzts
Drives: 2018 brz ts
I just ordered 1 x SubieBros Subaru Bumper Hole Plugs
Subaru Paint Code Crystal White Pearl - K1X
Camilobrzts is offline   Reply With Quote
Old 03-12-2022, 08:58 AM   #42
Shub Deetle
Large Member
Shub Deetle's Avatar
Drives: 2022 Subaru BRZ
We’re required to have front licence plates here, so I needn’t worry about plugs. Dodged a bullet there! 😀
Baby, you can drive my car
Shub Deetle is offline   Reply With Quote
Front license plate holes JayBoii Cosmetic Modification (Interior/Exterior/Lighting) 1 12-25-2014 11:03 PM
Front Bumper Mustache Holes Splicer006 Cosmetic Modification (Interior/Exterior/Lighting) 8 07-21-2014 12:29 AM
BRZ Front Plate Relocation - No (visible ) Holes Gary in NJ DIY (Do-It-Yourself) Guides 0 09-20-2013 07:23 PM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 12:44 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) — General Topics 29 08-14-2012 01:19 PM
