Drives: '14 BRZ Todoroki/OriginLabo
WTB: Zenki BRZ Engine bay harness/fusebox
Need first gen ('13-'16) BRZ engine bay harness/fusebox. Cut/damaged is fine as long as it has both headlight plugs.
Preferred: Manual trans Key start (not push to start) MUST BE '13-'16 BRZ. I only need the blue section in this picture, really only the headlight plugs: ![]() Scammers fuck off, I'm not emailing you. |
#2 | |
Drives: Crapcan
#3 | |
Are all pre-17 8pin headlight plugs the same? BRZ, RS 1.0/2.0, JDM/Euro? If so I could extend my search |
#4 | |
Drives: Crapcan
Im not at a computer right now but check subarupartsonline and compare the part numbers between different years and transmission. For that harness I would guess they are going to be the same pre-facelift regardless of trans but I am not in a place I can check. Sent from my iPhone using Tapatalk
#5 | |
| SOLD - Engine harness | gcranston | Engine, Exhaust, Bolt-Ons | 4 | 02-23-2022 12:58 AM |
| Engine Harness swap | RevoG | Engine, Exhaust, Transmission | 2 | 11-12-2021 01:44 PM |
| FS: OEM engine harness w/ fuse box | DatApex | Engine, Exhaust, Bolt-Ons | 10 | 09-08-2014 02:51 PM |
| Engine, MTrans, ECU, Harness | RRBS | Engine, Exhaust, Bolt-Ons | 0 | 01-30-2014 03:25 PM |
| FS: BRZ engine harness | Fenrir | Engine, Exhaust, Bolt-Ons | 2 | 05-17-2013 02:04 PM |
