Old 11-12-2021, 06:47 AM   #1
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Engine Harness swap
Good day,
I would like to know if I can swap the engine harness from a 17-19 into a 2013 GT86. I seem to have a cam issue, but it only throws the codes when at idle. Once driving and the code cleared it stays off. I know sometimes this can be caused by the wiring harness so want to know if I have to use a older harness, or if the newer harness will work.
I do realise that the coil pack plugs are different, but is the rest the same?
G
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 11-12-2021, 11:49 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can use a 15'-16' engine harness and coil packs, but not the 17'+ engine harness. There are a lot of changes on the facelift cars besides just the harness. The crank trigger is totally different and I don't believe the pre-17' ecu can read it and you can't use your current crank trigger with that harness along with a few other issues.
Old 11-12-2021, 01:44 PM   #3
FrickingReallySlow
Drives: 2015 FR-S
You might want to look into why you have a "cam issue" and what codes they are. VVT solenoids went through a lot of versions and you can use the 2017+ ones in 2013 without a harness swap. Check the cam sensor as well as the VVT first
FrickingReallySlow is offline   Reply With Quote
SOLD - Engine harness gcranston Engine, Exhaust, Bolt-Ons 4 02-23-2022 12:58 AM
Toyota Aristo Engine Harness Conversion to USDM Supra TT to Swap into FRS ThePurist Engine Swaps 0 11-23-2017 08:13 PM
FS: OEM engine harness w/ fuse box DatApex Engine, Exhaust, Bolt-Ons 10 09-08-2014 02:51 PM
FS: BRZ engine harness Fenrir Engine, Exhaust, Bolt-Ons 2 05-17-2013 02:04 PM
