Old 02-14-2022, 06:46 PM   #1
Gilbert2908
Drives: 2015 Subaru BRZ Turbo
Question 18x9.5 +40 fitment
Hi guys, i’m new here!
I’ve got 18 x 9.5 +40 wheels on the way and i was wondering if i’d be able to fit a 255/35 tyre front and rear. I’m on silvers neomax s coilovers, lowered with about a finger and a half gap left between tyre & fender.
I’ve read that these tyres can fit with around -2 to -2.5 degrees of camber however i’ve also read that it wont and may require spacers.
Any help would be much appreciated!
Thanks!
Gilbert2908 is offline   Reply With Quote
Old 02-14-2022, 08:02 PM   #2
brianbui23
Actively learning
brianbui23's Avatar
Drives: 2013 FRS US MT
You shouldn't have a problem, i have the same spec wheels but 245/35 and there looks like theres room for some more tire
2013 FRS: Tein Flex Z coilovers, Rays Gram Lights 57CR Black Chrome, Gruppes UEL headers, OFT e-85
brianbui23 is offline   Reply With Quote
Old 02-14-2022, 08:06 PM   #3
Ashikabi
Ashikabi's Avatar
I have 255 on that spec. It fits
Sent from my ONEPLUS A5010 using Tapatalk
Old 02-14-2022, 08:56 PM   #4
Gilbert2908
thanks guys
Old 02-14-2022, 08:58 PM   #5
Gilbert2908
No rubbing whatsoever? Even at full lock? If so, thats awesome
Old 02-14-2022, 09:02 PM   #6
Ashikabi
Ashikabi's Avatar
Can't tell. I have brake ducts so I rub regardless.
Old 02-14-2022, 11:17 PM   #7
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
It’ll depend on ride height and driving conditions. Also which 255s; because some tires tend to run wider/narrower than others
I had 255s in that spec. -3 and -2.5 camber front/rear.
Only had very small rub in the rear under full compression on track
suspension, tyres, wheel fitment
Tire Fitment 18x9.5+35 Cojonudo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 03-25-2024 01:06 PM
wheel fitment 18x9.5 +35 Misfit714 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-02-2020 08:37 PM
18x9.5 +30 255/35 Fitment NeedsBoostt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-02-2018 02:42 AM
TIRES AND FITMENT? 18X9.5 +38 Garcia86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-29-2016 10:24 PM
18x9.5 +45 fitment Wilson15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-05-2014 07:49 PM
