Old 02-07-2022, 03:26 PM   #57
zeroomega
zeroomega's Avatar
Drives: Supra MKV, FR-S
Originally Posted by timurrrr View Post
What makes you think the track width / scrub radius changes?
JRitt was talking about the offset of the brake rotor / caliper, not the wheel offset. I'm assuming the offset wasn't corrected by simply putting a spacer under the rotor hat (who ever does that for purpose-built kits?) and rather a new hat is used. I'm also assuming that the thickness of the new hub part of the hat hasn't changed either.
Even if the scrub radius did change by a couple of mm, you won't notice.
Definitely less change than what you'd get by putting wider wheels for track-oriented tires.
Yeah, that is just some wild guess from me. It might not be correct. I am just posting the worse case scenario that if they decide to use a hat that add may be 1 mm offset to the inside of towards the hub while still retain the gen1 top hat's overall shape to clear the knuckle. There exists such thing called rotor top hat spacers and BMW use it to fix the clicking sound from their 2 piece rotors when it hits the knuckle under high load.
zeroomega is offline   Reply With Quote
Old 02-08-2022, 09:38 AM   #58
ozafar
Drives: 2015 Scion FRS Release Series 1.0
So basically within ~1 week, we should know if gen1 BBKs fit the 22 gr86.
ozafar is offline   Reply With Quote
Old 02-08-2022, 10:47 AM   #59
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
That is correct.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 02-08-2022, 03:31 PM   #60
Dylans47
Drives: Scion FR-S
Originally Posted by JRitt View Post
We have finalized the designs for our 299mm and 325mm kits for the 2022 BRZ and they are completely new and different from our old kits.
You've said the team updated the disk hat and mounting bracket to fit the BRZ. To me that didn't sound like a comprehensive update or something completely new and different. With the caliper over 10 years in production, are there any plans to redesign the caliper itself?
Dylans47 is offline   Reply With Quote
Old 02-08-2022, 04:02 PM   #61
JRitt
JRitt's Avatar
We spent several days measuring the car, and many hours in CAD drawing up new caliper brackets, disc hats, producing prototypes, a secondary test-fitting session, etc. Those parts were also put through FEA analysis to assess strength and durability. The discs in our 325mm system are also a completely new design and casting. Quite a bit of work went into this over the past month or so, and our engineers would contend that this was in fact a fairly comprehensive update based on their workload!
The CP8350 calipers in our smaller kits are already stiffer, lighter, and more durable than competing products, particular those that are anywhere near the same price. They have high quality ventilated stainless steel pistons as standard, anti-knockback springs, etc. (which others don't even offer). The CP8350 has won races and championships all over the world, and in terms of value for the price our new kits will continue to set the industry standard just like our old ones did. As such, we have no plans to redesign the CP8350 caliper. If we did redesign it, our 299mm and 325mm kits would become considerably more expensive (which many 86 owners don't want).
That said, we do have the latest caliper tech available, which would be our AP Racing Radi-CAL Kits. We plan to have these available for the GR86, just like we now have them for the new BRZ. Bleeding-edge caliper technology unfortunately comes with a higher price tag, but we will have them if that's what you're after.
In summary, we have a bunch of great brake kits across a wide variety of price levels. There is something for everyone, regardless of your budget and goals with your car. Nobody will be disappointed with our brake kits, just like they weren't disappointed with our kits for the Gen.1 cars. Quite the opposite in fact.
www.essexparts.com
Old 02-08-2022, 09:13 PM   #62
Dylans47
Drives: Scion FR-S
Understood! Not trying to give you and the team a hard time. I read "completely new and different" and was confused looking for clarification. I'm all for lower prices but I'll have to look into the radi-cal kit too. Thanks for the response.
Old 02-09-2022, 11:03 AM   #63
JRitt
JRitt's Avatar
No worries...it's all good. I didn't think you were busting my chops.
I'm currently working on article that will help people choose between the 299mm and 325mm system. I did one years ago, but this is an updated version.
www.essexparts.com
Old 02-09-2022, 11:20 AM   #64
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Did you happen to look into a compatible 2 pot caliper for the rear yet?
Old 02-09-2022, 11:24 AM   #65
JRitt
JRitt's Avatar
We did, and we will not have any 2 piston caliper kits for the rear. Sorry!
We do have our four piston rear Radi-CAL solution available if someone wants a front and rear kit. Thanks!
www.essexparts.com
Old 02-12-2022, 03:05 PM   #66
ozafar
Any update?
Old 02-14-2022, 10:07 AM   #67
JRitt
JRitt's Avatar
For existing Essex/AP Racing brake kit owners: We have completed measurement of the 2022 GR86. If you have one of our original 299mm or 325mm CP8350 AP Racing by Essex Competition Brake Kits, it will fit and function properly on your new GR86. Also, both kits will fit behind the 2022 GR86 OEM 17" and 18" wheels without a spacer.
We also put together a document that explains our fitments for all Gen.1 and Gen.2 cars. It should answer most questions you might have, and you can read it here:
Toyobaru 86 Brake Kits: Gen.1 vs. Gen.2
We also put together an article that examines the choice between our 299mm and 325mm kits:
86 299mm vs. 325mm AP Racing by Essex Brake Kit Comparison
Thanks gents.
www.essexparts.com
Old 02-14-2022, 10:16 AM   #68
fredzy
Mebmer
fredzy's Avatar
Drives: Sienna, GR86, TourX
Awesome, thanks! Now I just need a car!
fredzy is offline   Reply With Quote
Old 02-14-2022, 01:41 PM   #69
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
In this article you say, "Essex does not offer individual brake kit components separately". This bothers me, in considering whether I will buy one of your kits! As I read it, if a part needs replacing we can't get it from you.
True?
In the other article you say the 299mm rotors are non-floating. You don't offer a floating option? Is your 325mm rotor lighter than the Brembo 326mm rotor?
Lastly, I assume the rear Brembo's from the PP or rear of a GR+ STI would be the best pairing for your Endurance kit?
Scargod is offline   Reply With Quote
Old 02-14-2022, 02:02 PM   #70
JRitt
JRitt's Avatar
True?
If you damage something or have any problems, we will of course sell you a replacement. That only occurs very rarely. I will put a note in the article about that. We would never leave anyone hanging without parts. Thanks for mentioning this...good catch!
The 299mm disc is fixed. The 325mm is the floating option. There is no 299mm floating option. Our 325mm disc with hat weighs about 15.9 lbs. You'd have to find out what the Brembo disc weighs.
Either rear OEM brake setup works great with our front kits. We've deployed them to many cars with both types.
Thanks.
www.essexparts.com
brake, disc, pad, rotor, track
AP Racing by Essex Brakes for the 2022 BRZ JRitt BRZ Second-Gen (2022+) — General Topics 62 06-10-2024 08:14 PM
2022 GR86 MSRP 2k over the BRZ? mangler CANADA 5 12-06-2021 10:51 AM
AP Racing (Essex) brakes - glowing... (and brilliant) grumpysnapper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-21-2021 01:13 AM
Essex/AP Racing Brakes Black Friday 2019 Sales Event! JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-28-2019 01:02 PM
Essex & AP Racing: New website & tech videos...Find out where your brakes were born! JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-13-2016 10:05 AM
