Drives: 2014 Scion FRS Hot Lava
Pulling left under acceleration
HI All,
FRS 2014, about 120k km's (72k miles). Car seems to be pulling left under acceleration at highway or close to highway speeds. You can put your foot on it and there is a noticeable rightward shift when you let off. Steering runs straight otherwise. Seems like fairly soon to be having worn out suspension links but that is likely what it is. Which rear link should I take a look at first? Thanks! |
#2 |
Drives: 2014 GT86
It's not by chance one of most common reasons, such as different tire pressure (easiest and quickest free check), or misalignment? I seen many cases where people start searching different other reasons, when simply one tire was leaking air.
| The Following User Says Thank You to churchx For This Useful Post: | Spuds (10-22-2019) |
#3 |
This is probably not it, but I hear sometimes when the diff is going bad it’ll apply more power to one wheel than the other and make you veer when you accelerate.
#4 |
Did you get the Mustang mod? Was there a crowd to your left?
| The Following 2 Users Say Thank You to Grady For This Useful Post: | soundman98 (10-23-2019), Spuds (10-22-2019) |
#5 |
Checked tire pressures already. Highly doubt bad diff. Have had this happen on another vehicle before and it was definitely suspension related.
#6 |
Software Hobbiest
Drives: 2015 FRS
Is one of your shocks out, at highway speeds the smallest bump can cause a wheel to hop in the rear causing power to transfer to the driven wheel. That can cause a pull.
Is your alignment in spec. wheels pointing in different directions can cause the car to pull differently when weight is transferred over that wheel. Are your bushings all good, You can lift the car and shake the wheel. Is there play Is your air pressure all even. |
| The Following User Says Thank You to dholloway543 For This Useful Post: | Tristor (10-23-2019) |
#7 |
Drives: 2014 BRZ
I had the opposite issue on my '14; under braking it would pull to one side.
Front lower control arm bushings were worn. Check all the bushings on a lift... If it's pulling (turning at the front) then mostly like its a front suspension issue. Rear suspension issues make the car feel like its moving "under you" rather than pulling to one side or another.
#8 |
Drives: 2013 Scion FRS
How was this issue resolved? Im having the exact same problem, alignment is good, rolls straight after its done doing it rightward pull
#9 |
Drives: 2013' Toyota 86 (EU spec)
If tire pressure, toe and bushings are fine it will by very high chance be caused by the shocks. Had this issue also when once changed the hardness setting of my adjustable shocks from pretty soft to maximum stiff on one side only. Tirned the knoob unintensional when I unloaded a box out of the trunk.
#10 |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
When was the last time you had all the wheels aligned?
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
#11 |
Drives: 2012 Toyota 86
I'm having a similar issue. All tyres are brand new, new front control arm bushings, new ball joints and tie rod ends as well. It sometimes pulls to the right but mostly to the left when travelling about 80-100 km/h. I'm still trying to figure this out.
Had to do some chassis straightening to bring the front left wheel hub forward as the caster was not matching the right side. Now, I'm thinking it may need another chassis check as the previous alignment shop data is showing that the caster is still a little off compared to the front right side. So I'm wondering if that's causing the issue for me or worse case scenario, something to do with the steering. Toyota 86 in the building! |
| The Following User Says Thank You to Gamace For This Useful Post: | Ultramaroon (02-05-2022) |
#12 |
Sounds like it just needs a smidge more tweak. Do you guys have the chassis reference points? There's a link you can follow in my sig.
| Aggressively pulling to the left on acceleration | sero901 | Issues | Warranty | Recalls / TSB | 39 | 01-12-2021 06:39 PM |
| Car pulling to the left when steering wheel is centered | Bach415 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-14-2017 01:43 AM |
| Car pulling under acceleration | Midjetv8 | Issues | Warranty | Recalls / TSB | 37 | 11-15-2016 10:53 AM |
| That left-side vertical streak of residue left by windshield wipers | tzhu07 | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 07-15-2015 01:23 AM |
| WTB Red Bumper, Left Fender, Left head light, Clear side markers | carlossanchez89 | Want-To-Buy Requests | 0 | 09-01-2014 04:43 PM |
