Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 02-02-2022, 12:48 AM   #337
jongers
Drives: 19 86, 22 BRZ
Originally Posted by Kona61 View Post
If Mr.Sexy did yours, which I assume he did, Ill be able to get similar pics as I have an appointment on Saturday with him.
You're in good hands then! I think my car was the first 2nd gen he did.
He did a really clean job! but to be honest, I think the tire ended up shaving off a little more than he had originally done (aggressive fitment).
jongers is offline   Reply With Quote
Old 02-02-2022, 10:27 AM   #338
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Originally Posted by Powersfrs View Post
+45 French kisses stock shocks
+45 on kw’s no issues plenty of clearance.
+45 on kw”s -2.2 camber no rubbing anywhere up front or out back with not too much drop.
I was curious, do you have more pics of the rear wheel fitment/poke?
Kona61 is offline   Reply With Quote
Old 02-02-2022, 10:28 AM   #339
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Yep lol! He did a friends S2000, and it’s so clean that you would have to be told it had been rolled to notice anything.
I’m still not sure if I’m going to run my wheels for certain, though. They are 18x9.5 +45 which isn’t that aggressive but I also don’t want to run camber beyond -2.0° or drop the car too low.
Old 02-02-2022, 04:44 PM   #340
jongers
18x9.5 +45 is still pretty aggressive/flush in the rear! The front can definitely use a spacer if you're going for a flush look, but I'm starting to think that +45 is the ideal offset 9.5.
Don't be too scared of running ~ -2.5 camber IMO. Keep the toe in spec and the tire wear/handling characteristics should be fine. I'd go with a skinnier 255 or a 245 tire if possible though.
Old 02-02-2022, 06:13 PM   #341
Chris_f
Drives: 2022 GR86
If a 9.5” width can only fit a 245 tire comfortably under the fenders.- wouldn’t it make sense to do an 8.5” width and save some weight? Unless some wheel designs only come in 9.5”?
What is the advantage of such a wide wheel in this scenario?
Chris_f is offline   Reply With Quote
Old 02-02-2022, 10:57 PM   #342
Kona61
Kona61's Avatar
Drives: ‘22 CWP
I only went this route because of the whee design. I really am not a big fan of wheels with a lip that have a flat or convex face. Flat faced wheels like AVS Model 5s, the stock wheels, Fifteen52 Tarmacs, etc. look fine with a high offset. But the issue is 5x100 is somewhat less common and most JDM wheels that fit at 8-9 width have a compromised design (in my opinion).
Old 02-03-2022, 06:27 AM   #343
86man
Drives: GR86
GR86 in Advan Racing GT Beyond 18 x 9J ET51
86man is offline   Reply With Quote
Old 02-03-2022, 08:00 AM   #344
Chris_f
Drives: 2022 GR86
^that fitment looks pretty nice to me… I didn’t know such a high offset with a 9” would clear on the inside?
Old 02-03-2022, 08:42 AM   #345
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Likely bolt in wheel spacers.
Old 02-03-2022, 11:16 PM   #346
ZD8.BRZ
ZD8.BRZ's Avatar
Drives: 2022 BRZ
Hello everyone. im new here. im taking delivery of my 22 BRZ in first week of March and i want to change wheels ASAP, this will be my first sports car and first car without OEM spec wheels/tires. i know there is alot of info in the last 25 pages but thats alot to read. can someone please tell me if i get 18x8 ET40 with 225/40 tires for front and 18x9 ET40 235/40 tires for the rear on stock suspensions will i run into any rubbing issues? please and thank you for the reply.
ZD8.BRZ is offline   Reply With Quote
Old 02-03-2022, 11:38 PM   #347
Xed32
Drives: '22 brz Sport-Tech
front looks fine, rear might need to be ET 45-51
Xed32 is offline   Reply With Quote
Old 02-03-2022, 11:49 PM   #348
slipstream8
slipstream8's Avatar
Drives: On order: 2022 ISM BRZ Ltd
Alrighty folks. Time for some photos of bad fitment for the sake of education (and I thought it was worth seeing how this style of wheel looked on the new generation BRZ.)
These are Wedssport TC105N 17x9 ET35 with Yokohama AD08R 245/40R17 at stock ride height. It seems like there wouldn't be any rubbing at maximum compression, but the poke looks terrible.
The last photo is the clearance for the front shock.
slipstream8 is offline   Reply With Quote
Old 02-04-2022, 10:21 AM   #349
OkieSnuffBox
Drives: '23 BRZ Limited
There is no reason to go staggered on these cars. Especially because it negates the ability to rotate tires and extend their life.
As for there being "a lot of read" that's how you learn things. Reading the experience of others who have shared it.
Old 02-04-2022, 05:53 PM   #350
86 & Co.
Drives: 22 WRB BRZ Limited
Got my new wheels on so figured I would share.
18x8.5 +45 Wedsport SA77R with the oem 215/45 Michelin PS4. OEM suspension/alignment.
Will likely go with max height on KW V3s so around a .8" drop from what I have read. Will post updated pics in a few weeks when those go on hopefully.
Sent from my KB2005 using Tapatalk
86 & Co. is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
