Old 01-15-2022, 07:18 PM   #309
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
17x9.5's that work with Brembo's or other BBK's?
I see only one wheel, the APEX EC-7R 17x9.5 +40 listed as a fit.
I would prefer a different look and the price is pretty steep! I was hoping to spend less.
My 2022 BRZ needs BBK's and wheels. I want to fit 245's on it for track work. I'd prefer 9.5" rims because I'd prefer to have the tires stretched a bit, if anything, and it leaves me with the option of running 255's down the road.
It will have coilovers. Wheel shims are fine (I have ARP studs).
I'm pulling my hair out trying to find 17" options in a light, wide wheel that fits over BBK's.
Scargod is offline   Reply With Quote
Old 01-15-2022, 08:36 PM   #310
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You'll need to watch the 2nd gen fit thread. The clearances are different from 1st gen and it seems like some 9" have trouble fitting. You'll also have more problems due to the compression under cornering loads
https://www.ft86club.com/forums/showthread.php?t=147495
EndlessAzure is offline   Reply With Quote
Old 01-16-2022, 10:15 AM   #311
Scargod
Track Day Junkie
Scargod's Avatar
Thanks so much! Sorta new here and I've had trouble finding the right place to find the info I need. I've been searching under wheels/tires... and Tracking / Autocross / HPDE / Drifting.
Old 02-02-2022, 12:34 AM   #312
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
RAYS Volk TE37 OG (Bronze)
18x9.5 +36 5x100
Michelin Pilot Sport 4S
255/35/18
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
The Following 3 Users Say Thank You to KMA KiCKz For This Useful Post:
botbs (02-25-2022), Busybee (02-02-2022), timurrrr (03-09-2022)
Old 02-25-2022, 09:24 PM   #313
therealstoly
therealstoly's Avatar
Drives: 2020 BRZ Limited
17x9 +35 MOMO Heritage 6 fit without issue.
-CSG Tein Flex A
-Kumho 255/40 V730
therealstoly is offline   Reply With Quote
The Following 2 Users Say Thank You to therealstoly For This Useful Post:
NoHaveMSG (02-26-2022), timurrrr (03-09-2022)
Old 03-09-2022, 07:43 PM   #314
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Found out that the official specs for SSR GTX01 explicitly call out Subaru Brembos (see rightmost column and the legend in the bottom right)
Old 03-26-2022, 01:18 AM   #315
LavaMonogram
LavaMonogram's Avatar
Drives: 2014 FR-S Monogram
I can confirm that the 2019 TRD front Brembos do not clear on the USDM TRD 18x7 & 18x7.5 optional wheels (Matte black). Just test fitted it today on my 2014 FR-S.
LavaMonogram is offline   Reply With Quote
Old 04-28-2022, 02:15 AM   #316
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Does anyone know how much of a spacer do I need for the base 17x7.0" stock wheel to clear the Brembos?
N_Raged is offline   Reply With Quote
Old 05-26-2022, 04:57 AM   #317
jlrosales
Drives: dark grey BRZ
Hope this thread is still active enough but I was wondering if anyone knows if the XXR 560 and the XXR 567 will fit with the brembos?
jlrosales is offline   Reply With Quote
Old 06-18-2022, 05:29 AM   #318
EddyEggnog
EddyEggnog's Avatar
Drives: 2019 BRZ Series.Gray
Sparco Podio 17x7.5 fit. Both the +35 and +48 offset. This photo is of the +35 and I don't have pictures of the +48 but they clear too (just barely).
Also for anybody's future reference because it's hard to track down online, Sparco uses 63.3mm center bores for these wheels. It was tricky to find a 63.3mm to 56.1mm hub centering ring online, since my wheels didn't come with rings. I had to order them from Latvia on centricrings.com, which seemed like a bit of a sketchy site but they arrived just fine and work well.
EddyEggnog is offline   Reply With Quote
Old 06-20-2022, 07:52 AM   #319
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
This is probably more useful for European owners but here is JR SL01 17x8+35 on Brembo GT (which should be a little wider than PP caliper). Clears easily without spacer (about 4-5mm of clearance in the narrowest spot).
MrSkubi is offline   Reply With Quote
The Following User Says Thank You to MrSkubi For This Useful Post:
soundman98 (06-20-2022)
Old 06-20-2022, 12:30 PM   #320
gpvecchi
gpvecchi's Avatar
AFAIK Brembo GT is the same kit fitted as stock
Old 06-20-2022, 12:39 PM   #321
MrSkubi
MrSkubi's Avatar
I can guarantee you that it is definitely not the same caliper as PP or STI one.
gpvecchi (06-21-2022)
Old 06-22-2022, 01:57 AM   #322
dsp979
Drives: 2020 Halo 86 TRD
You sure?
USDM 18 x 7.5 +35 square set on 2020 TRD package.
71, 72 Celica STs
85 "AE88" hatch, 89 S13 SE hatch (DD, autox car), 2020 86 TRD
dsp979 is offline   Reply With Quote
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 09:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 09:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 09:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 06:15 PM
