Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-29-2022, 09:44 AM   #15
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
So far I have two people asking for these BumperPlugs. That gets us down to $75 each person, but you get two sets of plugs. Then you could eBay the second set if we want. I will let more people join over the weekend before we decide to order or not.
PhatFreshPrince is offline   Reply With Quote
Old 01-29-2022, 11:21 AM   #16
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
If you ask on Instagram or Reddit you'll get more traction. Or on the Facebook Groups until some other platform does groups and clubs better.
SpectreRT is offline   Reply With Quote
Old 02-01-2022, 10:16 AM   #17
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Not sure how I feel about pushing in the threaded sleeves, but I am looking for something to do with the front of the car.
I'd really like to simply put small, body colored bolts in those holes and call it a day, but the lump left by the plate mount looks a little strange.
I'd almost go for one of those Billetworkz plates if it was body colored too. Though it is small enough it might not be too distracting. It would be funny to debadge my car and then stick a "BRZ" plate on the front...
All that said, there is still the matter of where to put the plate if I need to display it. Hopefully Carbino will have a mount for the 2nd gen BRZ, but I doubt it will show up any time soon.
Desertnate is offline   Reply With Quote
Old 02-01-2022, 11:46 AM   #18
razgriz12345
Drives: 2022 brz limited (WR Blue)
The grimspeed plate relocation kit works great I have had it installed since I got my plates and it hasn't moved a millimeter since I put it in
razgriz12345 is offline   Reply With Quote
Old 02-17-2022, 06:18 AM   #19
Krokodil
Drives: Blue BRZ
Disclaimer on that website got updated to:
“2022 BRZ models have threaded inserts in factory holes. These must be removed prior to installing the plugs. They come out when you slightly push in.”
I am wondering, where threaded inserts are going after you slightly pushing them in…
Krokodil is offline   Reply With Quote
The Following User Says Thank You to Krokodil For This Useful Post:
mike2100 (02-20-2022)
Old 02-17-2022, 09:52 AM   #20
Desertnate
Spelling Impaired
Maybe I'm over simplifying things, but is there any reason you couldn't get two screws, paint the heads with touch up paint, and screw them into the threaded sleeves?
I'm thinking a couple small hex head screws would work and not look too bad.
The Following 2 Users Say Thank You to Desertnate For This Useful Post:
glamcem (02-17-2022), Lonewolf (03-08-2022)
Old 02-17-2022, 09:58 AM   #21
LRNAD90
Drives: X5 35d, D90, CX-5 Turbo
And then what happens if you decide you want (or are pretty much forced to keep your registration) to put a tag on the front? Or, not that anyone probably cares, what happens for the next owner that may need/want to run a front tag..
LRNAD90 is offline   Reply With Quote
Old 02-17-2022, 10:33 AM   #22
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
Back in the day when I wanted to get bumper plugs I would ask a mechanic doing delivery prep for some and get a free handful. They would remove them and discard to place the dealer plate.(we only have the rear plate here) I don’t know if there are models from the factory anymore that still use them pre delivery.
The Red One is offline   Reply With Quote
Old 02-17-2022, 03:30 PM   #23
Krokodil
Drives: Blue BRZ
There are dedicated locations on a front bumper where you can put a plate mounting screws. Same as on most of the cars. Same as on BRZ rear bumper.
Old 02-17-2022, 03:36 PM   #24
Krokodil
Drives: Blue BRZ
Nothing wrong with it, as long as fastener head shape is what you want to be there.
And touch up is more appropriate for small dots.
To properly paint larger surfaces, you might want more complex process, if you want paint to last and to have right look.
Desertnate (02-17-2022)
Old 02-17-2022, 04:11 PM   #25
Desertnate
Spelling Impaired
For the fasteners I figured a hex screw or one with flat-ish domed head would look better than holes and wouldn't require pushing in the threaded sleeves like the plugs do.
Good point on the paint. I have see some kits have the paint in small jars with brushes and include clear coat. Figured that would work better than the paint pens you typically see. The head of a screw is a pretty small area.
Just thinking out loud...
Old 02-17-2022, 05:59 PM   #26
Up4speed
Drives: 2023 BRZ Limited
I think that the smallest flat head screw would look the best.
For bonus points, use body filler to fill in the screw head and sand it smooth, then paint it and screw it in by hand.
Up4speed is offline   Reply With Quote
The Following User Says Thank You to Up4speed For This Useful Post:
Desertnate (02-18-2022)
Old 02-17-2022, 09:18 PM   #27
2020BRZtS
2020BRZtS's Avatar
Drives: '20 BRZ tS (15/300) / '09 Scion tC
Has anyone tried to put a pop clip in it? Black is universal and probably wouldn't look too bad as long as it stayed in.
2020BRZtS is offline   Reply With Quote
Old 02-21-2022, 04:40 PM   #28
PhatFreshPrince
I am done with the front bumper for now. I got these at Ace Hardware and they match the black trim nicely.
The Following 4 Users Say Thank You to PhatFreshPrince For This Useful Post:
2020BRZtS (03-03-2022), Krokodil (03-03-2022), Midnightsky (12-15-2022), MikeNSX2 (03-04-2022)
Front license plate holes JayBoii Cosmetic Modification (Interior/Exterior/Lighting) 1 12-25-2014 11:03 PM
Front Bumper Mustache Holes Splicer006 Cosmetic Modification (Interior/Exterior/Lighting) 8 07-21-2014 12:29 AM
BRZ Front Plate Relocation - No (visible ) Holes Gary in NJ DIY (Do-It-Yourself) Guides 0 09-20-2013 07:23 PM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 12:44 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) — General Topics 29 08-14-2012 01:19 PM
