Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-29-2022, 11:36 AM   #323
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Yes RCC SS1s come with camber plates.
Also I thought 5mm spacers don’t need stud replacements? Or is that a myth
ozafar is offline   Reply With Quote
Old 01-29-2022, 11:57 AM   #324
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by jongers View Post
This thread successfully gave me a ton of anxiety/had me second guessing my setup before getting my wheels/suspension dialed in today. Ended up going to a shop to get the install + alignment done.
Had 18x9.5 +40 from my Gen 1 wrapped in 255/35. Actually transferred over the coilovers and the RLCA from the previous car as well.
Here's some pics after the install:
Posted in the other thread, but the specs after the alignment are -2.6/-2.7 in the front and -3 in the rear (went with -3 to be on the safe side with clearance). Keep in mind that I've had the rear inner fenders shaved.
The 255/35 Yokohama Advan Apex 601 that I'm currently on seem to run a bit thinner than other tires.
Do you have a pic of what you had to do to the inner fender?
Old 01-29-2022, 12:05 PM   #325
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by CZ6T View Post
ET38 would give you a more flush fitment I think. my 17x9 ET42 poke very slightly on stock suspension.
245 will fit fine on 8.5, but it might look a little bit bulky. 235/35/18 would be a more square look but is slightly smaller in diameter.
Wouldn't ET38 poke more than ET42?
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
MMoore4545 (01-29-2022), suhhh (01-30-2022), timurrrr (01-29-2022)
Old 01-29-2022, 03:59 PM   #326
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
The threads on the stock studs on the first gen are known to be pretty weak, and have just enough engagement when not using any spacers. I would strongly advise against running 5 mm spacers with stock length studs.
Old 01-29-2022, 04:04 PM   #327
jongers
Drives: 19 86, 22 BRZ
Was looking through my phone, and the one picture that I had is a little too dark to really show the details. If i take my wheels off this weekend, I'll try to snap a clear picture.
From what I remember, the tab that protrudes inwards needed to be shaved pretty significantly and some of the inner fender liner was cut in that area as well. I had someone that specializes in fender rolling in the socal area handle the cutting/shaving process.
jongers is offline   Reply With Quote
The Following User Says Thank You to jongers For This Useful Post:
OkieSnuffBox (01-29-2022)
Old 01-29-2022, 04:33 PM   #328
CZ6T
Drives: 2022 crystal white BRZ
It would, but he's looking at an 8.5 instead of a 9 in wheel width, so it should have almost the same poke as my setup does in ET38.
CZ6T is offline   Reply With Quote
The Following User Says Thank You to CZ6T For This Useful Post:
dragoontwo (01-30-2022)
Old 01-29-2022, 10:49 PM   #329
Scubadriver
Drives: 2022 BRZ Limited
I just installed a set of RCE SS1s today. Pretty happy with how the install went. I only dropped it about 7/8". Ended up with about 2.2 degrees camber in back. Dialed in about 2.8 in the front. Should be a good starting point for the BRZ's first visit to the track.
I noted that the front studs seemed quite short and did not appear to offer sufficient length for any sort of spacer.
Scubadriver is offline   Reply With Quote
Old 01-30-2022, 03:36 AM   #330
Kona61
Kona61's Avatar
Drives: ‘22 CWP
That’s funny, I just installed mine today as well. I need to adjust it since the front is sitting with a gap of 3 fingers and the rear is at 2 (very scientific I know).
Kona61 is offline   Reply With Quote
Old 01-30-2022, 01:24 PM   #331
Powersfrs
Drives: Frs
That's actually very helpful info.
We know coilovers save at least 6mm compared to stock suspension.
And if your 9.5 et40 barely clears stock suspension (say 2mm?) that means 9.5 et45 should have no issues clearing coilovers.
And since 9.5 et45 will be 5mm more fender clearance, perhaps no fender rubbing for +45?
Any thoughts anyone?
+45 French kisses stock shocks
+45 on kw’s no issues plenty of clearance.
+45 on kw”s -2.2 camber no rubbing anywhere up front or out back with not too much drop.
Ridiculous!
Powersfrs is offline   Reply With Quote
The Following 2 Users Say Thank You to Powersfrs For This Useful Post:
dsc_pat (01-30-2022), finch1750 (01-30-2022)
Old 01-30-2022, 02:12 PM   #332
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Interesting info in this post:
https://www.instagram.com/p/CZUVYYrJwM8/
19x9.5 et44 wrapped into ADVAN NEOVA AD09 245/35R19
The Following User Says Thank You to timurrrr For This Useful Post:
Old 01-30-2022, 09:15 PM   #333
86man
Drives: GR86
Nice...I want to get Advan Racing GT Beyond in 18 x 9.5J an run 245/35 AD09
86man is offline   Reply With Quote
Old 01-30-2022, 10:18 PM   #334
Scubadriver
That's actually pretty good. I think a little forward rake is appropriate. Front of mine is about 3/8 lower than rear.
Old 02-01-2022, 05:33 PM   #335
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
So they cut out that section marked with the blue line?
Robertw is offline   Reply With Quote
Old 02-02-2022, 01:42 AM   #336
Kona61
Kona61's Avatar
Drives: ‘22 CWP
If Mr.Sexy did yours, which I assume he did, Ill be able to get similar pics as I have an appointment on Saturday with him.
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 11:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 07:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 08:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 05:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 04:34 PM
