Old 01-25-2022, 04:03 PM   #15
brianbui23
Actively learning
brianbui23's Avatar
Drives: 2013 FRS US MT
I believe these are made by SPC for moog.
If they are it's a great deal, almost half the price!
brianbui23 is offline   Reply With Quote
Old 01-25-2022, 07:08 PM   #16
Grady
Grady's Avatar
I bought the Whiteline ones. I do my alignments, only bought them for ease of adjustments.
The Following User Says Thank You to Grady For This Useful Post:
brianbui23 (01-25-2022)
Old 01-30-2022, 12:33 PM   #17
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Adamf220 View Post
Get the moog ones off of rockauto. Just simply for the ease of adjustment.
Don't want no stinkin' rubber bushed ones!
Scargod is offline   Reply With Quote
Old 01-30-2022, 04:01 PM   #18
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Then buy sphericals
I gave away a set of RacerX toe arms with sphericals. I was DD'ing my car still then and the ends were not surviving beyond a couple years even with regular lubing.
Old 02-01-2022, 08:04 AM   #19
Scargod
Track Day Junkie
Scargod's Avatar
... I gave away a set of RacerX toe arms with sphericals. ...
LOL. Just ordered them! Did you feel the geometry correction was useful?
Old 02-01-2022, 10:20 AM   #20
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Not really. I’m on bump steer correction rod ends in the front too and don’t notice that much difference from those. I noticed the roll center correction in the front immediately though. I don’t think it is worth doing RC correction in the rear as it negatively effects anti squat though.
Old 02-04-2022, 06:46 PM   #21
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Ive considered toe arms for the exact reason that it slips. My camber is never far off between alignments but the toe can get pretty wacked out of spec. Just cant pull the trigger due to cost as well
Old 02-04-2022, 11:24 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
108k miles, lots of autox and shit roads and mine only slip when they’re under torqued.
ineedyourdiddly
Old 02-05-2022, 01:58 AM   #23
finch1750
finch1750's Avatar
Im at 190k miles. Various alignment places. Seems to slip fairly often. I wish it was that simple. Maybe i'll try retorquing after my next alignment to be sure.
Old 02-05-2022, 02:34 AM   #24
strat61caster
I’ll ask my guy what he torques to next time, it’s mega tight, probably around 100 ft lbs. factory spec is 76, every time I’ve slipped has been because I was below 76.
If they use the same cammed bolt an aftermarket arm (like spc) isn’t going to change anything about your slipping issue. Some do have ‘lockouts’ though, make sure you get one of those.
ineedyourdiddly
finch1750 (02-05-2022)
Old 02-05-2022, 09:35 AM   #25
ZDan
ZDan's Avatar
Drives: '23 BRZ
My stock arms never slip, but only at 63k miles and 40+ track days...
Why Buying EXPENSIVE Wings from Evasive Motorsport??? SexAs86 Cosmetic Modification (Interior/Exterior/Lighting) 4 05-06-2019 10:22 PM
Is it worth buying aftrmarket parts for the frs? sledheadguy CANADA 23 03-02-2015 11:24 AM
Worth buying joint pipe now or later? Bakemono858 Engine, Exhaust, Transmission 21 02-21-2015 02:04 PM
Buying Fr-S, this one worth checking out? Fang Scion FR-S / Toyota 86 GT86 General Forum 9 11-07-2014 02:31 PM
Series 10 - Still worth buying new? Double_Clutch Scion FR-S / Toyota 86 GT86 General Forum 16 08-14-2014 03:40 PM
