Actively learning
Drives: 2013 FRS US MT
Is it worth buying expensive toe arms?
I think the price of toe arms is ridiculous. Some places are selling them for over $500.
Wouldn't buying cheap toe arms (even god speed for example), and adding the eccentric lock out kit make them the same? This might be a dumb thought but want to see what other people think.
2013 FRS: Tein Flex Z coilovers, Rays Gram Lights 57CR Black Chrome, Gruppes UEL headers, OFT e-85
#2 | |
Drives: '23 BRZ
Drives: Subaru BRZ
^ Same as above except close to -4 camber in front; still on OEM toe links.
Yeah factory toe adjustment is fine unless you’re stancing.
Actively learning
I read a few threads saying that the rear toe gets misaligned after hitting big bumps or taking aggressive corners. I haven't had the car long enough to see any changes though
Drives: 17 Asphalt 86
I had OEM toe arm slip at autocross last year. Probably due to the tech not torquing it properly after adjustment.
SPC toe arms are cheap and offer more range of adjustment. |
| The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | brianbui23 (01-24-2022), Scargod (01-24-2022) |
#7 | ||
Drives: '23 BRZ
I trust factory parts a lot more than aftermarket. Factory parts have more/better analysis behind them and way way WAY more testing. Seems like a waste of time/money/effort to me... |
| The Following 2 Users Say Thank You to ZDan For This Useful Post: | brianbui23 (01-24-2022), Tcoat (01-24-2022) |
Track Day Junkie
Drives: 2022 BRZ Limited
Setup for max track performance with suspension mods?
I'm not into doing something just because it looks cool. Are ALL the adjustable rear toe arms being offered just there for the stance crowd?
My track buddy says he has the rear at -2.0°. The front at -3.5°. Can you get there with stock adjustability, especially if I'm dropping the car 1~1.5 inches? I have Voodoo 13 LCA's and coilovers arriving any day for my 2022 BRZ. I'm not sure if my buddy is using adjustable arms or not, but he seems to have everything else. His setup came off a real race car that crashed. |
#9 | |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | brianbui23 (01-24-2022), ZDan (01-24-2022) |
#10 | |||
Drives: '23 BRZ
#11 |
Most people can get the toe you need with the stock arms.
The OEM toe adjuster can slip and IMO are a little bit of a pain to adjust if you're doing your own alignments. It's not common, but it does happen. An aftermarket arm usually uses a spherical bearing instead of the factory rubber bushing, which means a more direct connection and less "give." It's a small difference, but doing more bushings in the rear adds up to a more noticeable difference. A "better" aftermarket arm will use a higher quality spherical bearing that lasts longer. On the lower end arms the bearing or the ball joint is more likely to develop play earlier and require replacement. Some arms will also use a rubber booty to protect the bearing from the elements (salt). Aftermarket toe arms are defintely not a "required" part, but I like them. - Andrew |
| The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#12 | |
-2.5 in the rear, been as low as 1.5” zero issue with factory toe arms, plenty of adjustment left |
#13 |
Drives: 2013 frs
Get the moog ones off of rockauto. Just simply for the ease of adjustment.
| The Following 2 Users Say Thank You to Adamf220 For This Useful Post: | brianbui23 (01-25-2022), treedodger (01-28-2022) |
#14 |
Drives: Crapcan
I believe these are made by SPC for moog.
| Why Buying EXPENSIVE Wings from Evasive Motorsport??? | SexAs86 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-06-2019 10:22 PM |
| Is it worth buying aftrmarket parts for the frs? | sledheadguy | CANADA | 23 | 03-02-2015 11:24 AM |
| Worth buying joint pipe now or later? | Bakemono858 | Engine, Exhaust, Transmission | 21 | 02-21-2015 02:04 PM |
| Buying Fr-S, this one worth checking out? | Fang | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-07-2014 02:31 PM |
| Series 10 - Still worth buying new? | Double_Clutch | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 08-14-2014 03:40 PM |
