Old 01-27-2022, 12:03 PM   #1
kur0111
kur0111's Avatar
Drives: 2017 brz limited
help with suspension problem
hello everyone im trying to diagnose a metal creaking problem after installing fortune auto coilovers. everything else is stock. currently 10k miles. 2017 brz
here is a video of the sound when it creaks
im thinking its just the rear but i could be wrong.
Here is my to do list to check this weekend:
*check front and rear swaybar bushings (then white lithium grease it)
*check any play on the springs
*tighten the end links when the car is on ramps.
*look into adjustable rear endlinks
kur0111 is offline   Reply With Quote
Old 01-28-2022, 09:41 PM   #2
norcalpb
norcalpb's Avatar
Have you checked the main 17mm strut nut that holds the spring to the shock? The top hat nut.
Sometimes new coils are only tightened a bit so they don’t come apart during shipping, but you really should make sure those nuts are tight once you have the full weight of the car on the suspension.
Old 01-30-2022, 01:48 AM   #3
kur0111
kur0111's Avatar
just got done tighten up everything and all that jazz but the squeaking are there which is sad.
i tightened everything up pretty much to spec im just thinking of getting it over with and just take it to a shop
Old 01-30-2022, 04:24 PM   #4
norcalpb
norcalpb's Avatar
Dang I know that feeling of needing a professional diagnosis as a last resort. In the meantime you could try jumping up and down on your door sill to get a better idea of where the noise is coming from. Try to listen if the noise is down low by the control arms or up high by the top hats.
2015 BRZ rear suspension problem av8rdav BRZ First-Gen (2012+) — General Topics 13 10-09-2020 08:11 AM
Possible problem after suspension install? max20s14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-19-2016 01:43 PM
Wheel/suspension problem TE37SL Tomahawk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 02-11-2016 11:59 PM
Suspension problem Border7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-17-2014 05:03 PM
I need info and help with suspension problem kkkirbyyy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-26-2013 11:37 PM
