| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2017 BRZ w/Performance Package
I've recently turbocharged my BRZ and I must say its an absolute blast to drive now! With that said, most of my time has been spent hopping up the engine and making more power. I haven't necessarily stopped to consider any other areas of the car until now. I'm pushing around 340whp on e85 and would like to be able to put all that power down without feeling like somethings going to snap or explode. For example I've considered a carbon driveshaft, beefier axles, perhaps some stiffer mounts? The list goes on, but those are just a few. All in all I'd like to hear yall's input as to what should be covered and taken into consideration when trying to put all that power down relaibly. Thank you to all who adds valuable information. It's greatly appreciated!
#2 |
Drives: Bone stock
Definitely get new motor mounts. You'll having a driving feel that's out of this world. Rear diff bushings is a game changer as well.
Sent from my SM-G998U using Tapatalk |
#3 |
ProCrastinationConsultant
the biggest problem with increased power is that the gremlins take over. the trans isn't well known to take tons of extra power, or the output shafts. but beefing up either of those presents an issue somewhere else, and on and on.
#4 |
Drives: Crapcan
The driveshaft and axles are going to handle the power longer then the engine.
#5 |
I have torque solutions motor mounts currently installed and I'm quite pleased. As for any other mounts or bushings, that I do not have. Rear diff bushings are something to seriously consider? Are they any difficult to install?
#6 | |
I've heard the trans starts to become iffy around the 350-400hp mark. The same goes for the shafts. They're both areas I'm considering throwing some upgrades at. But these issues you speak of, would it make considering upgrading those areas not worth it?
#7 |
Figured I'd get one of these posts stating my engine would go before anything else. That I understand, and have fully wrapped my head around the fact that soon one day that engine will go. Which is no problem, as a small part of me kind of wants that to happen so I can move on to a stage 3 block. But until then, I'd like to work with what I have and continue to improve off this platform as much as I humanly can. Money is not necessarily an issue, not for this project.
#8 |
Drives: Chevrolet Ram 250
If you don't mind hammering your transmission tunnel, you may as well just do the CD009 swap for the transmission. Do that and you wouldn't have to worry about it blowing up.
I got a smooth brain.
#9 |
The ol' 350z tranny huh? I've taken a gander, and it's most certainly an upgrade thats going to happen in the future. But for now, I think I can make that stock transmission last if the proper precautions are taken, no?
#10 | |
Drives: Crapcan
Maybe because those are not particularly problematic even above your power level and you would be better off saving for something more pressing like a built block and a cd09
#11 |
If by proper precautions you mean not shifting like an a hole then yeah you could extend the life of it. You're already over the torque rating for our transmissions so it's more or less a ticking time bomb imo.
#12 |
i dunno, part of me likes the mindset that the best method for dealing with a guaranteed driveline failure is to pick a failure point that's easiest to replace.
trans sucks to get to, as does the drive shaft, and rear diff. but then the half shafts i believe could be mostly changed with a single floor jack/jack stand and a nice comfy knee pad. so if i've got to choose a failure mode, my choice is the half shafts for ease of access. YMMV.
#13 | |
Drives: None
#14 |
I drive the thing like it's on glass every day, I never hard shift or rarely have boost built when engaging the clutch. I try to be as gentle as possible. +90 ft lb of torque is really going to guarantee my trans exploding?
| Tags |
| drivetrain, reliability, suspension, track, turbo |
| Something you all need to hear. | NoMoCouch | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 01-07-2014 09:36 PM |
| Anyone hear of a conclusion to the LS2 BRZ? | NOHOME | BRZ First-Gen (2012+) — General Topics | 1 | 05-19-2013 09:31 PM |
| How did you hear about your FRS? | bdanisi | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 01-21-2013 12:14 AM |
| Heads up, you can get 20 Cents off gas from Shell if you have a Ralphs Reward card | jflogerzi | Southern California | 4 | 12-27-2012 02:47 AM |
| Get your GT86 for only 25 cents! | Sport-Tech | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-11-2012 10:28 AM |
