Old 01-23-2022, 07:00 PM   #85
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I got my hands on the nicer variant of the first generation 86 airbag cover. There are two versions, one made of a single piece of plastic with fake embossed stitching, and one made of leather with real stitching. I think the plastic one is SU003-03413 and the leather one is SU003-03410. I think in the UK and Japan the lower spec versions of the 86 had the plastic airbag cover and the higher trim models had the leather airbag cover.
Be careful if you order one of these and make sure you the get the right one. The eBay UK vendor I ordered from pictured the nicer leather cover in their listing, but shipped me the lower trim plastic cover. I did not notice for a while and the vendor did not take responsibility when I brought it to their attention.
I swapped the new cover in just like I did with the Scion airbag cover. I was able to sell the plastic airbag cover and it paid for almost all of the new one. The plastic cover sold immediately so there is good demand for these parts.
Mike_ZN6 is offline   Reply With Quote
The Following 3 Users Say Thank You to Mike_ZN6 For This Useful Post:
Jdmjunkie (01-24-2022), kevaughan (01-24-2022), Stonehorsw (01-24-2022)
Old 01-24-2022, 01:37 PM   #86
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I've been meaning to do this logo/emblem swap on the steering wheel airbag forever! How much did everything cost?
kevaughan is offline   Reply With Quote
Old 01-24-2022, 02:44 PM   #87
Jdmjunkie
Drives: Scion FR-S 10 Series
You actually made me go look at my airbag. I have the one with stitching.
Jdmjunkie is offline   Reply With Quote
The Following User Says Thank You to Jdmjunkie For This Useful Post:
Mike_ZN6 (01-24-2022)
Old 01-24-2022, 04:54 PM   #88
Mike_ZN6
Mike_ZN6's Avatar
Used first gen 86 airbags are going for $400-500.
Old 01-28-2022, 08:02 PM   #89
Mike_ZN6
Mike_ZN6's Avatar
LED Lighting and JDM Side Markers
I replaced all of the lights on the car with LEDs and got some clear JDM side markers.
I wanted to go with all Diode Dynamics lighting but they don't offer LEDs with the exact specs I wanted for the interior dome and trunk lights. I went with HID Kit Pros 5000k LEDs for the dome and trunk. I was concerned the Diode interior options would be too blue-ish at 6000k. But after seeing their 6000k LEDs installed on the exterior, I see they are not actually very blue. I may switch in the future.
The CF18 LED turn signal flasher was a major PITA to get installed. It is very difficult to get down into position to remove the stock one and the clip is almost impossible to unlatch. I ended up just pulling the OEM relay out with the plastic clip holding it to the car still attached. Luckily, I was still able to reuse the clip to attach the CF18. I would recommend anyone doing this install to just pull it out and replace the clip with a new one. You can see the white clip I suggest replacing in the pics with the LED relays.
The JDM side markers are a nice improvement over the stock amber units and they were a super easy install. Not really sure why I waited so long to change these out. However, I think there may be too much chrome on the front of the car now. I ordered a set of Spec-D smoked side markers to try out.
Old 01-28-2022, 09:23 PM   #90
jflogerzi
jflogerzi's Avatar
The Flasher was the biggest PITA to switch on this car OMG. I know your pain. Otherwise nice clean build.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Mike_ZN6 (01-28-2022)
Old 01-28-2022, 10:07 PM   #91
Jdmjunkie
I love Diode Dynamics, they are a great company to work with. For my trunk I went with one of their led strips. That was one of the best mods I have done. You can see everything in the trunk.
Old 08-15-2022, 09:33 PM   #92
Mike_ZN6
Mike_ZN6's Avatar
STi Short Throw Shifter
I recently installed an STi short throw shifter (C1010CA100). It is not a huge difference but the throw is a bit shorter. There are no loud vibrations like have been reported on other aftermarket short shifters. It is a nice upgrade even though it is kind of expensive for what you get.
The install was all pretty easy except for the dust boot that covers the connection between the gear lever and transmission. I found it to be impossible to install the new dust boot without tearing it. I tried to install the dust boot by putting it on the transmission arm and sliding it up onto the gear lever (opposite of how I removed the original one). You can see in one of the pics how I slid down the original dust boot onto the transmission arm. I managed to rip both the old and new dust boots this way. I believe this is the correct way to remove the dust boot, but not the correct way to install it. I just saw a video where someone installed the new boot by putting it on the gear lever before bolting it in to the car and then slid it down onto the transmission arm once in the car. I am going to order a new dust boot and try it that way.
The dreaded dust boot:
How to slide down the dust boot:
Old 01-02-2023, 07:53 PM   #93
Mike_ZN6
Mike_ZN6's Avatar
Brembo GT BBK
It has been a while since I posted any updates.
Earlier in the thread I posted some pics of a set of Performance Package Brembos I had picked up. I planned to have the PP calipers powder coated black and also install new lines, pads, and rotors. I realized I could just buy a brand new set of Brembo GT BBKs for about the same total price so I sold the PP Brembos. I got an amazing deal on a brand new front Brembo BBK from @Jstyle and picked up the rear kit from GSG.
The Brembo GT components are not identical to the Performance Package parts. The calipers are actually a completely different design. The rear GT calipers require a bracket to mount while the PP rears mount directly to the knuckle. The rotors are the same size (326x30mm/316x20mm) but the GT rotors are Zinc plated and come in slotted or drilled. Because the GT and PP rotors are the same diameter, you can utilize the OEM PP dust shields with the GT kits. This may be the only setup allowing you to retain dust shields after upgrading to a BBK.
This is the best Brembo and dust shield install video I could find. The video is for installing a set of Performance Package Brembos, but the installation is the same except for the rear calipers.
I did the install with a friend of mine that drives a supercharged BRZ (unfortunately not on FT86club). As usual when modding, the install did not go perfectly smooth. A fitment issue with the rear brackets forced us to put the car back together and wait nearly 2 weeks for a response from Brembo. Then once we got the rear brackets installed and the calipers on, we could not get the driver side rear brake line removed. I am going to let PTuning take care of the brake line now. They are going to install a new brake line on the frame back to the rear driver side.
Brembo GT Brake Kits
OEM Performance Package Dust Covers
Front Install
We used an Allstar bleeder bottle to drain the brake fluid. Glad I picked it up - it made the process much easier.
Installing the new rear dust shields requires disassembling the parking brakes.
The Brembo rear caliper brackets did not fit on the rear knuckles.
CSG contacted Brembo and they said "Due to production tolerances on the casting and machining of the rear knuckle, some slight smoothing of the caliper mounting bosses on the knuckle may be required to fit the bracket." I picked up an angle grinder and we removed some material from the bosses.
You can see the amount of material removed from the rear passenger knuckle.
Rear Installed
There was an issue installing the driver side rear brake line. The fitting connecting the brake line would not break free. I had to leave the OEM rubber line on for the time being.
Brembo GT Installed
The black calipers look amazing with the bronze TE37s! The brakes feel great. Definitely stiffer than the OEM setup. However, the Brembo Dual Purpose brake pads squeal very loudly! I was hoping the squeal would go away when the pads wore in, but after several hundred miles they are still super loud when applying medium pedal pressure.
The Following 5 Users Say Thank You to Mike_ZN6 For This Useful Post:
gt5759 (01-03-2023), jflogerzi (01-23-2023), jongers (01-05-2023), RToyo86 (03-07-2023), villainous_frx (01-03-2023)
Old 03-06-2023, 10:33 PM   #94
Mike_ZN6
Mike_ZN6's Avatar
K&N Cabin Air Filter
Installed a K&N Cabin Air Filter tonight. Worth at least +5 hp!
Old 04-02-2023, 02:14 PM   #95
Mike_ZN6
Mike_ZN6's Avatar
I contacted CSG and started a thread (link) regarding the squealing after installing the Brembos. The consensus is that the Brembo Dual Purpose brake pads that come with the kit are just very noisy. No amount of bedding or grease application will make them quiet down.
I am probably going to replace the pads with either Project Mu Type-PS or Ferodo DS2500.
Old 04-02-2023, 03:17 PM   #96
Mike_ZN6
Mike_ZN6's Avatar
Racer X Rear Upper Control Arms
I picked up a set of Racer X rear upper control arms during their 2022 Black Friday sale. Racer X runs a huge sale for Black Friday and these were a great deal.
I wanted to replace my rear upper control arms to adjust the fitment of my TE37s. They have a very aggressive offset (18x9.5 +36) and without adding more negative camber the rear tires will not tuck if I go wider than 245/35. I would like to keep rear camber at the optimum level for performance, which is about -2.2 degrees.
The install for the rear upper control arms looked painful, so I decided to have PTuning install them. An alignment is necessary right after the install so I had to make the trip anyway. I also had PTuning flare the brake line that was stripped when I installed the Brembos and install a dust cover for the STi short shifter.
The Racer X RUCAs came with some minor damage out of the box. No big deal. You will never be able to see these when mounted on the car.
Unfortunately, I was not able to achieve the fitment I was hoping for. I have SPC rear lower control arms which provide camber adjustment with an eccentric bolt. The SPC rear lowers do not allow enough adjustment to pull the bottom of the wheel inward to tuck the top of the wheel without increasing negative camber from my previous setup (-2.2 degrees). It seems I will need to get some rear lower control arms that provide adjustment with the threaded rod style of adjuster.
I contacted Verus and SPL about the minimum length of their rear lower control arms. Both come in at about 430mm. This is significantly shorter than OEM and what can be adjusted on the SPC rear lowers using the eccentric bolt. I should be able to tuck the rear wheels and hit my camber specs with either one. Shifting the entire rear track is also probably going to require some aftermarket rear toe arms.
Installing the RUCAs also seemed to lower my ride height some in the rear. I had to adjust my coilovers up 2 rotations of the collars on each side to get back to the 1 finger gap I had before the installation.
Old 04-02-2023, 03:31 PM   #97
Mike_ZN6
Mike_ZN6's Avatar
Here is a shot of the driver side stainless rear brake line after PTuning flared the stripped hard line:
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
villainous_frx (04-02-2023)
Old 07-20-2024, 04:37 PM   #98
Mike_ZN6
Mike_ZN6's Avatar
I am putting my car back to stock. I still have the RCE SS-1s coilovers, Brembo GT brake kits, Pioneer AVH-ZL5150BT radio, JDM airbag, 2017+ 'Track Mode' VSC Module, SPC RLCAs, Racer-X RUCAs, and the OG Rays TE-37s. Send me a PM if anyone is interested.
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 09:08 PM
2016 Toyota 86 GTS Street/Track Build arthur93 Member's Car Journals 77 02-22-2018 07:07 PM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 03:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 01:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
