Old 01-21-2022, 07:19 PM   #127
CSG Mike
CSG Mike's Avatar
Originally Posted by BRZpat View Post
Are you living in the future? Gimmie some lotto numbers brotha!
oops
Old 01-21-2022, 07:20 PM   #128
CSG Mike
CSG Mike's Avatar
Originally Posted by Lantanafrs2 View Post
Tuning?
Aero. Different APR.
Old 01-22-2022, 09:19 PM   #129
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by glamcem View Post
I wonder if that oil temp is the actual oil temp (tapped or put sensor that gets the reading) or a calculated/BS one based on an algorithm that uses the coolant temps it's really good if it's an actual one. I wonder how the track oil temps will be and if that OEM oil filter helps any (doubt it) as long as the oils are stable below (~240F) it should be fine I think .
I don't remember at what temperature the previous BRZ/GT86s start pulling the timing at..if the computer doesn't read the oil temps maybe it was based on Coolant Temps
It's an actual sensor in the timing cover next to the oil pressure switch. Not certain if the new gen uses oil temp in timing tables. Coolant for sure. Most STi models start pulling timing at 214*, but that's F/I.
From product dyno testing with a 15 WRX with this same setup, we'd generally see a 20* difference from the OEM sensor to the sump, with the sump being the colder of the two.
KillerBMotorsport is offline   Reply With Quote
The Following 4 Users Say Thank You to KillerBMotorsport For This Useful Post:
glamcem (01-25-2022), Scargod (02-15-2022), Stonehorsw (01-22-2022), timurrrr (01-22-2022)
Old 01-23-2022, 11:43 AM   #130
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
By "sump", I assume that you mean oil pan? Is the 20* difference due to pressurization of the oil or because the oil galley is hot from the engine's heat?
Old 01-24-2022, 09:34 AM   #131
KillerBMotorsport
Yes, sump = oil pan. The sender was in the drain port.
I have no idea. We've never done testing with the OEM sender, but the dyno sender is very precise and calibrated regularly. Neither exceeded 260°, so it never became more than an anecdotal observation. 20° was the max difference under 'cruise' conditions. Once on boil or under sustained load the difference would drop some, but not a lot.
The Following User Says Thank You to KillerBMotorsport For This Useful Post:
blsfrs (01-24-2022)
Old 02-02-2022, 03:17 PM   #132
mike2100
mike2100's Avatar
Drives: 23 BRZ
8 Nov, 2022 - Dropped car off at OEM Audio+
Did they use your car to do testing/development for a system they intend to release soon? I have their system in my 4Runner and I love it.
mike2100 is offline   Reply With Quote
Old 02-20-2022, 09:06 AM   #133
2015firestormFRS
Drives: 2015 firestorm scion FRS
any talk on a new Ace header or similar design long tube equal length for these?
2015firestormFRS is offline   Reply With Quote
Old 02-20-2022, 07:58 PM   #134
shoreline86
Drives: '22 BRZ 6MT MGM
I thought I'd read a year or so ago that Ace was done making stuff for this platform and was focusing on Porsche stuff instead.
shoreline86 is offline   Reply With Quote
Old 02-28-2022, 11:43 PM   #135
CSG Mike
CSG Mike's Avatar
Something is coming!
Dzmitry (03-03-2022), gcmak (03-01-2022)
Old 03-12-2022, 08:05 AM   #136
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Subbed, excited for this
SON1C is offline   Reply With Quote
Old 01-22-2023, 04:35 PM   #137
Lucky Ookami
Lucky Ookami's Avatar
Drives: N/A
Saw APR's January 3rd Facebook post of the new carbon pieces on the CSG BRZ. Looking good!
Lucky Ookami is offline   Reply With Quote
nowforitbs
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike BRZ Second-Gen (2022+) — General Topics 25 11-04-2021 11:22 PM
Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. CSG Mike Tracking / Autocross / HPDE / Drifting 5 11-02-2021 05:57 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Mike @ LSD Motorsports JDMenrique User/Vendor/Sponsor Reviews, Feedback, Comments 0 04-06-2013 07:13 PM
Mike at Czp _F-R-S_ User/Vendor/Sponsor Reviews, Feedback, Comments 0 12-01-2012 09:01 PM
