Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-22-2022, 10:10 PM   #281
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
et51!
Old 01-22-2022, 11:41 PM   #282
Kona61
Kona61's Avatar
Drives: ‘22 CWP
Originally Posted by 86man View Post
Don't worry guys.
Japan will have a lot of new forged wheels size for the GR96/BRZ this year
For example, Advan will release a Racing GT Beyond version in 18 x 9J ET51. That means you can run wider tyres in the rear without having to cut up anything
http://www.yokohamawheel.jp/brand/ad...pn_beyond.html
I’m curious when they’ll actually arrive, though. Most wheel companies I’ve spoken to don’t have anything incoming to the US until Spring/Summer.
Kona61 is offline   Reply With Quote
Old 01-23-2022, 12:47 AM   #283
OkieSnuffBox
Drives: '23 BRZ Limited
Has anyone taken pics of exactly what they have had to do to the inside of the rear fenders for the 18x9.5_255/35 setup to work?
I know "cut the fenders." But I'm curious to see exactly what the few have done to make it work.
Old 01-23-2022, 02:47 AM   #284
Dylans47
Drives: Scion FR-S
Am I overthinking it to say needing to compromise and go for an 18x9 is silly? The previous gen ran 18x9.5s well. Would that loss of 0.5" matter at all on track?
We got horsepower and lost wheel width.
Dylans47 is offline   Reply With Quote
Old 01-23-2022, 10:05 AM   #285
Kona61
Kona61's Avatar
Drives: ‘22 CWP
I’ll take some pics when mine is done.
Old 01-23-2022, 01:13 PM   #286
ozafar
Drives: 2015 Scion FRS Release Series 1.0
Okay, so I plugged in some numbers in WheelItFit. Obviously the wheel to vehicle isn’t accurate anymore, but comparing two wheels still works.
We know the following 17x9 setup works well (Thanks Tr4ck_day!!)
17x9 et42 245/40/17 on coilovers with 2.5 camber and 1.5 drop compared to:
18x9.5 et45 255/35/18 on coilovers with 2.5 camber and 1.5 drop with these differences:
18x9.5 setup has 3mm more poke
18x9.5 setup has 4mm smaller fender gap
18x9.5 setup is 10mm closer to strut
18x9.5 setup is 8mm larger overall diameter (1.28% difference)
@Tr4ck_day can you help confirm if the following differences would cause problems?
Thank you
ozafar is offline   Reply With Quote
The Following User Says Thank You to ozafar For This Useful Post:
finch1750 (01-24-2022)
Old 01-23-2022, 01:17 PM   #287
Powersfrs
Drives: Frs
I have these specs on a +45 Rim with no rubbing.
Ridiculous!
Powersfrs is offline   Reply With Quote
Old 01-23-2022, 01:50 PM   #288
ozafar
So just to confirm. You’re running 18x9.5 et45 255/35/18 on coilovers without any issues?
Old 01-23-2022, 02:43 PM   #289
Powersfrs
Drives: Frs
pic sharing
Correct
They increased the rear end track by a few mm. Thats why folks with 18 9.5 +35 are having issues. The front end seems to be the same as before so a +35 fits up front and a +45 is what to get in the rear.( I’m running PS4S which tend to run wider than most tires)
Again At my height with 2.2 camber all around I have no issues. I’m running whiteline rear control arms. Kw V3 all around and vorshlog top hats up front. I’m also running a bit of toe in all around (just a tad)
Ridiculous!
The Following 4 Users Say Thank You to Powersfrs For This Useful Post:
botbs (01-25-2022), finch1750 (01-24-2022), MMoore4545 (01-24-2022), PLF69 (01-23-2022)
Old 01-23-2022, 04:04 PM   #290
ozafar
Thanks for the pic! Looks great. Do you have the rear control arms to control the rear camber? Do you know what the rear camber would be if you hadn’t changed the rcas?
Old 01-23-2022, 05:05 PM   #291
Powersfrs
Drives: Frs
Without the control arms you have no adjustability for camber. On my 2013 Scion FR-S without control arms one side had about -3 degrees of camber and the other side had -2.6. Without control arms you will most likely rub. Ride height will sort of dictate your camber without the arms.
Ridiculous!
Old 01-23-2022, 05:11 PM   #292
ozafar
Also more angles please!
Old 01-23-2022, 07:24 PM   #293
Powersfrs
Drives: Frs
Ok I’ll take more pics tomorrow
Ridiculous!
Old 01-23-2022, 09:18 PM   #294
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
You are thinking wrong. the more camber means less chance of rubbing.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
