Old 01-21-2022, 01:11 AM   #1
SushiBRZ
SushiBRZ's Avatar
Drives: Black 2015 BRZ
Auto-Tranny shifting issue
Hello all, I've searched and searched the internet for a fix for my Automatic trans shift problem/slippage and Honestly im stumpt. I have no leads, no ecu codes and im just at a complete loss. The car only has 25k original miles, not boosted, and I have no clue why this issue is happening. Anyone have any clues?
EDIT: at one point i had a p0700 code but that is it.
Video is below.
What I have tried:
I replaced the torque converter completely, with a brand new OEM one and it did not fix it.
That came with a transmission oil change, and diff oil change.
We inspected all connectors and plugs and nothing looked out of order.
VIDEO:
SushiBRZ is offline   Reply With Quote
Old 01-21-2022, 07:23 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You looked at the wrong control module captain.
P0700 is a general transmission fault that sets in the PCM at the request of the TCM, which is where the trouble code that could have helped you was.
You get to the TCM with a better scan tool.
Old 01-21-2022, 07:30 PM   #3
SushiBRZ
SushiBRZ's Avatar
I got the code when I was tuning with the OFT I think thats what caused it, because since reverting back to stock tune, the check engine light disappeared.
Old 01-21-2022, 10:13 PM   #4
Espi
Espi's Avatar
Drives: 17 BRZ
dang what tune did you use before going back stock?
have you tried re-flashing stock tune?
Espi is offline   Reply With Quote
Old 01-21-2022, 10:17 PM   #5
SushiBRZ
SushiBRZ's Avatar
I flashed the stage 2+ tune that OFT supplies, I ran it for months before this issue suddenly happened. Since it happened I flashed back to Stock, and the issue ensues.
Old 01-21-2022, 10:21 PM   #6
Espi
Espi's Avatar
Drives: 17 BRZ
hmmm same issue in auto mode? was the video in manual shifting mode?
I'm also AT on stage 2 but its customized.
Old 01-21-2022, 10:29 PM   #7
SushiBRZ
SushiBRZ's Avatar
It happens in both Manual and Drive gears.
Old 01-30-2022, 05:47 AM   #8
steve99
Drives: FT86
https://www.ft86club.com/forums/show...55&postcount=2
TSB out on idle and hard shift issue on 2015 auto, Auto trans computer updated software
Old 01-30-2022, 05:06 PM   #9
SushiBRZ
SushiBRZ's Avatar
in that video of the issue that guy had, it just looked like rough shifting. In my situation it looks more like it goes in limp mode and revv's out before going into next gear. Do you think its the same issue?
Old 02-01-2022, 11:45 AM   #10
Project_1796
Drives: Scion FRS 10 series
It doesn't hurt to update the transmission software, issue seems to be the transmission valve body solenoid not engaging on command. you can probably find a whole used auto transmission to swap out or go to a transmission shop to diagnose the issue which would cost the same in parts and labor. good luck on the issue
Project_1796 is offline   Reply With Quote
Old 02-01-2022, 11:49 AM   #11
SushiBRZ
SushiBRZ's Avatar
Should I buy this part and swap it out? I already swapped out the Torque Converter cuz i that that was the problem but it wasn’t.
Old 02-01-2022, 12:21 PM   #12
Project_1796
Finding a complete low mileage transmission to swap in would be your best option, I've seen some on ebay off 541 motorsports for around $700 shipped
Old 02-01-2022, 12:31 PM   #13
SushiBRZ
SushiBRZ's Avatar
so costly
Old 03-25-2024, 03:55 AM   #14
Lucky21
vroooooooom
Lucky21's Avatar
Drives: 86
Were you able to fix this issue?
Lucky21 is offline   Reply With Quote
automatic, help please, transmission
AT Tranny Issue Riftur Engine, Exhaust, Transmission 35 02-01-2018 11:23 AM
Clutch/tranny issue diagnostic help yomny Engine, Exhaust, Transmission 46 08-26-2015 12:48 PM
Shifting issue? RaveSaint5 BRZ First-Gen (2012+) — General Topics 30 10-20-2014 01:21 PM
High RPM Shifting Issue? Rinzler Issues | Warranty | Recalls / TSB 5 05-17-2013 12:30 AM
Is the auto tranny from a isf? WolfsFang Engine, Exhaust, Transmission 6 08-25-2012 09:25 PM
