Old 01-04-2022, 06:42 PM   #43
simpleisbest
Senior Citizen
Drives: Scion FR-S
off the shelf is 1.5way tuned for track/high performance street.
You can drift on it, but it wont be as aggressive as a drift spec 2way.
If you are actually competing in drift, then get it tuned. If you are a street user looking to drift on occasion for fun or to practice skills, then you should be gtg.
simpleisbest is offline   Reply With Quote
The Following 2 Users Say Thank You to simpleisbest For This Useful Post:
Mykii (01-30-2023), x808drifter (01-05-2022)
Old 01-10-2022, 12:48 PM   #44
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Anyone know if the 2013- 2020 OS giken fits the 2022 model?
Thanks!
botbs is offline   Reply With Quote
Old 01-10-2022, 02:01 PM   #45
CSG Mike
CSG Mike's Avatar
Thanks!
Sure does. Send me a PM to order, as they're backordered, but CSG has a bunch coming in. It can be configured for your driving discipline as well if you want.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
botbs (01-10-2022), justinco (01-10-2022), Mykii (01-21-2022), saltywetman (01-11-2022)
Old 01-10-2022, 08:57 PM   #46
ihavefat
Drives: 2018 BRZ
Hi CSG mike,
Just curious. What’s the ETA on the osgiken diffs and are there any discounts available? I am highly considering doing this over headers and tune.
ihavefat is offline   Reply With Quote
Old 01-11-2022, 07:37 PM   #47
botbs
botbs's Avatar
Hi CSG, I see you are using ATS LSD on one of your posts, do you use the OS Giken LSD oil for the ATS LSD? If not, what other LSD oil do you use?
Getting OS Giken LSD oil in Canada is not easy, most places here carry Motul 75W140.
Thanks!
Old 01-21-2022, 04:53 PM   #48
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
Ah-- yes.. I ordered through 86Speed and selected the 2-way option. Support local businesses, right? Well, unfortunately, they didn't deliver and the stock option as it comes is 1.5way. Kind of annoyed by 86Speed at this point, but I can't complain about the diff. Got it installed by Kaiju Motorsports and it's been quite good on the daily streets. Haven't hit an event with it yet though, so I'll update that later on haha!
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Mykii is offline   Reply With Quote
Old 01-21-2022, 07:17 PM   #49
CSG Mike
CSG Mike's Avatar
Originally Posted by ihavefat View Post
Hi CSG mike,
ETA is 3-10 weeks. Can't get anything firm due to shipping challenges.
A lot of diffs are backordered, so I'd say get in line if this is the route you want to go. The majority of the incoming batch is already sold.
Old 01-21-2022, 07:17 PM   #50
CSG Mike
CSG Mike's Avatar
Thanks!
I am no longer on an ATS.
On a OS diff, I'd recommend only OS fluid, unless you have a customized diff and your builder says otherwise.
botbs (01-21-2022), x808drifter (01-24-2022)
Old 01-22-2022, 11:26 AM   #51
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Apologies if this was already posted. Very informative 12 minutes.
The Following User Says Thank You to blsfrs For This Useful Post:
Jdmjunkie (01-22-2022)
Old 01-22-2022, 12:35 PM   #52
ZDan
ZDan's Avatar
Drives: '23 BRZ
OSG fluid is worth the $$$ for the smell. It's like a delightful grapefruit IPA. The only diff fluid I've encountered that doesn't stink to high heaven!
Old 01-24-2022, 01:40 PM   #53
CSG Mike
CSG Mike's Avatar
Let me introduce you to my friend Motul 300V for your engine.
ZDan (01-24-2022)
Old 07-02-2022, 02:04 PM   #54
coolhandluke
coolhandluke's Avatar
I welcome confirmation as I research installing this piece. I plan to purchase:
* 2x Differential Carrier Bearing PN# 9036650001 (G5001)
* 10x Differential Ring Bolts PN# 9010111353 (38113)
* 1x FRSsport Diff cover gasket
coolhandluke is offline   Reply With Quote
Old 08-19-2024, 05:44 PM   #55
Ruben_86_
Ruben_86_'s Avatar
Drives: Toyota GT86
I found a OS Giken with the following recorded numbers, would anyone tell me if it's 1.5 or 2?
55/55 224 10-10s
I want it for the road and some trackdays
Ruben_86_ is offline   Reply With Quote
Old 08-27-2024, 01:44 PM   #56
RedReplicant
Drives: None
55/55 224 10-10s
That means 55* ramp on both accel and decel sides
224kg of internal spring pressure
10 clutch plate pairs (20 plates total)
10s refers to preload but its relative to everything else
Anyway, it's a "2 way". Whether this is a setup you actually want is a question for someone like Jon at Shaftworks https://shaftworksusa.com/
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
Ruben_86_ (08-29-2024)
lsd, os giken
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover mav1178 Engine, Exhaust, Transmission 5 02-11-2021 01:20 PM
Project Mu Lugs BNIB - Racing Floating Nut & Super Lock Nut 7 SonnyBRZ Canada Classifieds 0 02-05-2014 10:37 PM
Results: OS Giken SoPac Super Regional Autox Championship ... des Tracking / Autocross / HPDE / Drifting 5 06-25-2013 11:02 PM
Nagisa Auto D-Lock Super Low Seat Rail poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 3 11-06-2012 04:35 PM
