Old 01-21-2022, 04:51 PM   #29
RT-BRZ
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by racingfool View Post
Put them all on the same line in BSP?
2.4L swaps into first gen cars. Choose between 4.1 and 4.3 FD.
I haven't delved into SP rules but wouldn't that really be the case? You could swap the 2.4L and whichever final drive you wanted into 1st gen?
RT-BRZ is offline   Reply With Quote
Old 01-21-2022, 05:17 PM   #30
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
They have to be classified on the same line or have an exception stated in the appendix. So looking at the old rule book in csp the frs and brz were actually classified on the same line, but in dsp they are all split up even across years, so you couldn’t put the 205hp red intake engine or shorter final drive into the old cars in dsp, but it may be possible in csp if they expand the years.
Or to look at another example, the nb, nc, and nd miatas are all split on purpose so you aren’t allowed to do cross generation engine swaps.
ineedyourdiddly
RT-BRZ (01-21-2022)
Old 01-21-2022, 07:50 PM   #31
Eric1855
Drives: LP DSP / CSP '13 BRZ
That is a factor of full prep (csp) vs limited prep (dsp) as update backdate is not allowed in Limited Prep.
Eric1855 is offline   Reply With Quote
The Following 2 Users Say Thank You to Eric1855 For This Useful Post:
RT-BRZ (01-21-2022), strat61caster (01-21-2022)
Old 02-02-2022, 11:38 PM   #32
gordo52
Drives: brz
The information in all the prior STX threads was great, and really helped a new guy figure it out, so here's my contribution.
This season will be my 3rd. Been slowly upgrading and growing with the car.
2019 BRZ Base
- Tein Mono Racing coilovers, 10k/10k springs
- Perrin 19 mm front sway bar set full stiff.
- Stock rear bar
- SPC rear arms with DIFtech bushings. I hate these. Squeaky and loud once i swapped the Difftech bushings in. The SPC LCAs should be grandfathered in.
- 17x9 APEX ARC-8 +42 offset. Getting some minor rubbing on the front drivers side inner plastic liner.
- 245/40/17 Falken 660s or RE71s
New parts installed over the winter break are below. Looking forward to the extra power. I'm not sure how much of a difference it will make in times, but it sure feels a lot nicer driving around without the torque dip.
- JDL 4-2-1 EL header
- JDL OP and Quiet catted front pipe.
- Stock catback. New local site has an 85 db limit. Stock catback doesnt sound half bad with the catless 421.
- CSG Ecutek tune
- STi motor mounts
- Torque Solution Trans insert.
I also plan to go from 3.5 to 4 camber in the front and try some A052s once the falkens wear out.
gordo52 is offline   Reply With Quote
Old 02-03-2022, 12:31 AM   #33
strat61caster
Real happy with whiteline rear lca, same as spc but with a poly bushing inboard, no noticeable nvh impacts vs what was there before.
Got em on tire rack, great shipping once they arrived stateside.
ineedyourdiddly
smg1138 (04-04-2022)
Old 02-03-2022, 10:03 AM   #34
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Why does everyone go for rear lower control arms instead of rear upper control arms?
I would think getting camber from pulling the top of the wheel inward rather than pushing the bottom of the wheel outward would be more ideal for suspension geometry and put less stress on the components. You would also get more similar fitment to the front where you are primarily getting camber from the top with camber plates. Mismatches in wheel fitment also seem to negatively effect the traction control systems in these cars.
Mike_ZN6 is offline   Reply With Quote
Old 02-03-2022, 10:43 AM   #35
_____That_-_GUY_____
Drives: 2022 GR86
Upper and lower control arms are not separated as much as the full diameter of the tire. So pushing the bottom out, will bring in the top of the tire. Not as much as adjusting the upper control arm, but adjusting the lower, will bring in the top of the tire some.
_____That_-_GUY_____ is offline   Reply With Quote
Old 02-03-2022, 11:33 AM   #36
steverife
Drives: 2016 Scion FRS
Recommended spark plugs for STX tuned cars?
steverife is offline   Reply With Quote
Old 02-03-2022, 11:46 AM   #37
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Stock?
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
ka-t_240 (02-03-2022), strat61caster (02-03-2022)
Old 02-03-2022, 03:26 PM   #38
strat61caster
The LCA is cheaper and easier to adjust. The RacerX UCA show up first and you have to undo the ball joint to adjust it, how many times before you booger up that interface? 5x? 10x? The OEM hub certainly isn't designed for a dozen assembly/disassembly operations. PBM/P2M/Cusco don't look legal with inboard sphericals.
Adjustable bushings in the upper arm should be legal though and cheaper then both, but more of a pain. This isn't a Miata so the rear suspension isn't designed to be adjusted up there. You're probably right in that it's *theoretically* better, but not enough to show up on course when missing an apex by a foot will add a tenth to your best time. Especially given that you're paying an extra $500, that's almost 2 yokes!
Edit: +1 on stock plugs, high compression engine with weird Toyota direct injection system, not sure if the aftermarket is going to spec anything 'better', there are cheaper options but I don't think there's any gain there.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Mike_ZN6 (02-04-2022), timurrrr (02-04-2022)
Old 02-03-2022, 11:18 PM   #39
Autoxer62
As I recall one of the vendors offers offset upper control arm bushings, you could use those to get in the ballpark, then the usual adjustable lowers for fine tuning.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace
Autoxer62 is offline   Reply With Quote
The Following User Says Thank You to Autoxer62 For This Useful Post:
Old 02-04-2022, 12:09 AM   #40
racingfool
racingfool's Avatar
Drives: Miata
Originally Posted by Autoxer62 View Post
offset upper control arm bushings, then the usual adjustable lowers for fine tuning.
lower arms may be modified/replaced OR other methods of camber
adjustment as allowed by Sections 14.8.B, C, or F may be used, but NOT both.
racingfool is offline   Reply With Quote
The Following 3 Users Say Thank You to racingfool For This Useful Post:
Breezio (02-04-2022), strat61caster (02-04-2022), timurrrr (02-04-2022)
Old 02-04-2022, 12:55 AM   #41
strat61caster
That’s the strut section, for the rear of an 86 h.1 is the correct section:
On double/unequal arm (e.g., wishbone, multi-link) suspensions, only the upper arms OR lower arms may be modified or replaced, but not both. Non-integral longitudinal arms that primarily control fore/aft wheel movement (e.g., trailing arm(s) or link(s) of a multi- link suspension) may not be replaced, changed, or modified.
That’s from ‘21 rule book, I’m hoping the updated wording goes into the ‘22.
ineedyourdiddly
Old 02-04-2022, 03:54 PM   #42
Autoxer62
Yes, but the bushings are free as long as they aren't metal. The control arm remains stock.
The 2022 Autocross Thread trippinbillies40 Tracking / Autocross / HPDE / Drifting 11 02-26-2023 06:13 AM
STX setup sharing thread (2021) Autoxer62 Tracking / Autocross / HPDE / Drifting 366 12-07-2021 02:57 PM
STX setup sharing thread (2020) Autoxer62 Tracking / Autocross / HPDE / Drifting 389 12-29-2020 02:40 PM
STX setup sharing thread (2019) CoolHandMoss Tracking / Autocross / HPDE / Drifting 109 02-17-2020 12:27 PM
STX Set-Up Sharing & Results Thread race2win Tracking / Autocross / HPDE / Drifting 76 02-16-2017 12:30 PM
