Old 01-17-2022, 10:08 PM   #43
DarkSunrise
DarkSunrise's Avatar
Anything that is GF-5 rated. Looks like it wasn't formulated for E85 specifically, just with alternative fuels in mind. Though like has already been pointed out, no dilution issue, no problem. Mostly it seems like it was developed around sludge protection since so many new vehicles have VVT to prevent failure with the solenoids.
Agree with this. For E85 use, anything that's GF-5 rated or higher since it was designed with E85 in mind (among other things). I use Mobil 1 0W30 AFE personally. It's GF-6A rated and fairly cheap.
During track season when I'm not using E85, I tend to use a 30 weight with better HTHS protection, specifically Castrol Edge 5W30 LL (3.5 HTHS, 11.6 viscosity at 100c).
2022 BRZ Build
2013 FR-S Build
Old 01-18-2022, 09:03 AM   #44
Tokay444
Originally Posted by TommyW View Post
no
Do you have any experience running E85 in any other platforms?
Old 01-18-2022, 11:27 AM   #45
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I was just answering Yosh's questions. I don't run a GF-5 in my car with E85. 300V actually states "Suitable for alcohol based fuel with shortened drain interval" but my intervals are already short since I just change the oil every year anyway. I think last year my car did a little over 2k miles.
Old 01-18-2022, 12:23 PM   #46
DarkSunrise
Ah got it, I see the conversation history now. Regardless that'd be my easy/simple recommendation. Makes sense to use oil that meets tests designed for E85 use if you're using E85 haha.
In your case with short OCI's and a specific manufacturer's recommendation for ethanol use, 300v seems like a good choice as well.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
NoHaveMSG (01-18-2022)
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 02:32 PM
Need some advice on engine guys! dsteezy86 Northern California 23 01-19-2017 07:33 AM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Do you guys have the dealership to change out your engine oil? JS + BRZ Southern California 11 01-04-2014 12:23 AM
