Old 01-15-2022, 06:09 PM   #1
patelk100
Drives: 2014 FR-S MT Monogram
What engine oil do you guys run?
I'm on an OFT stage 2+ e85 tune as of yesterday and I heard that you should change your oil to an e85 compatible oil. I also have read about a lot of people moving to a slightly thicker oil than stock as it's better for the engine when driving hard. Does anyone have any recommendations for what oil I should run knowing this? I do a lot of very hard driving and my car only has about 3k miles on the block and I wanna make sure I maintain it and don't blow it. Thanks for any suggestions
patelk100 is offline   Reply With Quote
Old 01-15-2022, 06:42 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Any good synthetic will work. 5-30 is a good one. I run 0-20 at the direction of my engine builder and IAG who supplied the short block. Their warranty is void if 0-20 wasn’t used.
Old 01-15-2022, 07:09 PM   #3
patelk100
Originally Posted by TommyW View Post
And this would work with my e85 correct?
Old 01-15-2022, 07:53 PM   #4
TommyW
TommyW's Avatar
I don’t think what fuel you use matters.
The Following User Says Thank You to TommyW For This Useful Post:
humfrz (01-15-2022)
Old 01-15-2022, 08:36 PM   #5
Tokay444
Fuel and engine oil compatibility is hugely important, especially in a mechanical pump-fed direct injection vehicle.
Old 01-15-2022, 08:56 PM   #6
TommyW
TommyW's Avatar
Interesting. Reasons? Thinking fuel contamination however a high quality synthetic should eliminate any issues, correct?
Old 01-16-2022, 06:24 AM   #7
Tokay444
Only if it’s compatible. There’s a reason Dexos is a thing.
Old 01-16-2022, 12:07 PM   #8
Grady
Grady's Avatar
The only correct answer to what oil to use is “NEW”. With E85 I would change oil more often.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Jdmjunkie (01-16-2022), TommyW (01-16-2022), Yoshoobaroo (01-17-2022)
Old 01-16-2022, 07:14 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i am pretty sure tons of people still stick with 0w-20 even using E85. educate us what will go wrong if we stick with 0w-20
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 01-16-2022, 10:42 PM   #10
Tokay444
It’s not the viscosity. Lol. It’s the chemical composition.
Old 01-16-2022, 11:10 PM   #11
TommyW
TommyW's Avatar
What chemical composition is that
Old 01-17-2022, 12:17 AM   #12
Tokay444
The chemical composition of the oil.
Old 01-17-2022, 04:22 AM   #13
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Canola, but Avocado works in a pinch. Jokes aside, Motul Xcess 8100 5w30. Track driven summer car on Costco 91 or Petro 94.
villainous_frx is offline   Reply With Quote
Old 01-17-2022, 04:41 AM   #14
TommyW
TommyW's Avatar
Uhhhh yeah. What is the difference from a normal synthetic?
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 03:32 PM
Need some advice on engine guys! dsteezy86 Northern California 23 01-19-2017 08:33 AM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 07:56 PM
Do you guys have the dealership to change out your engine oil? JS + BRZ Southern California 11 01-04-2014 01:23 AM
