#15 | |
At the track
Drives: '14 FRS - Former e92 M3
500f/600r, I know most are at 300-400 range for autox but figured this would be better for the aero setup. May play around with rates some more this season but not sure how many times I want to re-align the car. I kind of like to just set it and forget it and drive. Plus the end-goal for this car is probably to not autocross it forever so I was thinking longer-term.
I’m not gonna lie I’ve had some growing pains with them. The first set I got had lots of problems with the front droop/ride height (initial install resulted in my car being 2” higher than stock at lowest adjustment lol) but the rears came perfect so I drove on a mismatched coilover setup in-between for 2 mos. We spent many late nights in July/August trying to get the car ready for nats on phone calls and e-mails with Chris/Nitron getting everything re-done to have the right length bodies and shock travel. I can’t finger-point what happened to cause the issue with the fronts in the first place, but they resolved everything quickly (considering overseas shipping) at no extra cost with great service to have the fronts fit my requested specs, and are still working with us to redesign a couple components for legal additional camber. Right now everything maxed out is -3.2 deg in front. Overall, now that the whole ordeal is mostly over I’m really happy with them. Their bodies/hardware are great quality and the car handles great. If I had to do it over, the time spent in my case I’m not sure, but I feel like that’s an odd situation and I have a platform they probably don’t get a lot of orders for. If you are looking for them for a BMW/Lotus/Porsche which they build the most for I think they’re an excellent option.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
| The Following 2 Users Say Thank You to Kelse92 For This Useful Post: | racingfool (01-18-2022), strat61caster (01-17-2022) |
#16 |
Drives: '13 FRS - STX
Oof thanks for that. If autox has taught me one thing it’s that going your own way can be very expensive and painful. Hope you get more camber soon, 3* is not enough even with 500# springs lol.
| The Following User Says Thank You to strat61caster For This Useful Post: | Kelse92 (01-18-2022) |
#17 |
Drives: LP DSP / CSP '13 BRZ
I haven't touched much since I traded cars with Ray, other than some comfort items, If it's not broke and all....
2013 BRZ KW V3 (400/343) with custom front camber plates Wilwood Dynapro front brakes with 2 piece rotors, very light, and Ferodo DS2500s Hotchkis front bar, Mann rear bar ACE 350 Type-A header Remark dual exhaust Subaru Forester Oil Cooler Custom made intake tube No name rear control arms EcuTek tuned Little AGM battery 17x9 RPF1s (lots of them) with 245/40/17 Yoko A052s Sparco QRT-R drivers seat with B-K brackets (28.6lbs total so ST legal) NRG steering wheel with quick release and spacer (0.5lbs heavier than stock so ST legal) |
#18 |
At the track
Lol yeah it's rough, will be fixed soon. It's been manageable on street tires just flipping them and whatnot but running Hoosiers on the car for TT the wear could be much better...
#19 |
Drives: 2016 Brz Limited
what is everyone doing to access the rear shock adjusters? Just cutting a hole in the trunk fabric?
#20 |
At the track
Yup, to make it nice you can cut it the size of the little desk cable organizer circle pieces you can get from office supply stores.
| The Following User Says Thank You to Kelse92 For This Useful Post: | TeamBadger (01-19-2022) |
#22 |
Drives: 2017 BRZ PP, 2004 WRX
Figured I'd post here since I'll be moving to STX at some point in the future. Currently in DS and planning on running there in 2022. I've run the last two seasons in CS and then DS when the move happened for 2017 PP cars. Only upgrade I've done is tires both seasons. Some old RE-71R's I had and then fresh A052's. Likely going with RT660's this year.
I'm planning on upgrading the front swaybar this year for DS, but also want something that I'll keep for STX. I'm set on either RCE Tarmac 2's or KW V3's both with camber plates when the jump happens. Given that, how large of a swaybar would you go with to also work well with coilovers eventually? Here are some options I'm considering: 20m Whiteline solid (likely on stiff) 22mm Whiteline solid (likely on soft) 25mm Hotchkishollow
#23 |
Drives: 2022 BRZ
#24 |
I had 20mm whiteline, it does the job pretty well. I think 22mm WL would be too stiff to be useful. Iirc Wong had a 25.4mm hollow, all three of your suggestions are viable I think. I found the whiteline difficult to adjust on site, much happier with the karcepts bar.
#25 |
Drives: 2017 BRZ series.yellow
I run the Hotchkis 1" hollow bar in the front on soft with RCE T2's (400/400 springs) and the factory PP rear bar.
I'm quite satisfied with the setup. |
| The Following User Says Thank You to Breezio For This Useful Post: | smg1138 (03-03-2022) |
#26 |
#27 |
Thanks for the clarification!
"#30860 Twins Class Change Proposal The SPAC is withdrawing the proposal to move the Scion FR-S and Subaru BRZ from CSP to DSP. The committee does not believe this change is in the best interests of the category. The SPAC will continue to monitor the competitive balance in the category. " Booo......... |
| The Following User Says Thank You to Breezio For This Useful Post: | RT-BRZ (01-21-2022) |
#28 |
Drives: Miata
Put them all on the same line in BSP?
2.4L swaps into first gen cars. Choose between 4.1 and 4.3 FD. |
| The 2022 Autocross Thread | trippinbillies40 | Tracking / Autocross / HPDE / Drifting | 11 | 02-26-2023 06:13 AM |
| STX setup sharing thread (2021) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 366 | 12-07-2021 02:57 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 02:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
