Old 01-01-2022, 02:13 PM   #19377
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
After two weeks, I couldn’t stand not driving her due to being out of town and the weather. The roads are reasonably plowed and sanded up here in the PNW. Drove to Costco for ramen only to remember they are closed today.
Anyways, HAPPY NEW YEAR! May your mods be plentiful and your bearings un-spun.
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
Old 01-03-2022, 09:05 AM   #19378
grumpysnapper
grumpysnapper's Avatar
Cut away enough of the "dribble" lip so that a sandwich plate can now sit where it is supposed to.... lower, more compact and making way more sense.
(no need for a riser plate and its extra seal)
grumpysnapper is offline   Reply With Quote
Old 01-04-2022, 09:06 PM   #19379
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
While I'm waiting for a buddy to get a night free to help me set the timing and put the timing cover back on, I took out the exhaust manifold studs, cleaned them up real nice and put them back in.
demasrv is offline   Reply With Quote
Old 01-05-2022, 04:02 PM   #19380
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Played snowplow last week and the lip didn't survive a very snowy looking chunk of ice.
At least no bumper damage!
wolffbite is offline   Reply With Quote
Old 01-05-2022, 07:00 PM   #19381
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
A bumper is less expensive than that STI lip.
Grady is online now   Reply With Quote
Old 01-05-2022, 07:11 PM   #19382
wolffbite
Just the tip
wolffbite's Avatar
For the part yes, but not if including painting. Bodywork/paint is really damn expensive around here.
Ah well.. I'm replacing it with a much cheaper lip because I'm sure this won't be the last time this happens.
Old 01-05-2022, 09:37 PM   #19383
Grady
Grady's Avatar
The first time I went off the track did the same and tore up my STI lip. I purchased a knock off and put the STI badge on it. It did not fit as well as the STI version but was only $100 instead of $500.
Old 01-16-2022, 02:15 AM   #19384
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Switched to a Lithium battery for the weight savings.
Lost 31 lbs. off the front of the car.
Breezio is offline   Reply With Quote
Old 01-16-2022, 11:02 AM   #19385
Grady
Grady's Avatar
Good choice, that is my plan is to shift to these as batteries start to go out. I will stay with full size replacements though.
Old 01-16-2022, 02:00 PM   #19386
Breezio
Breezio's Avatar
If the full size replacements come down in price, I'd consider it. But these small ones are much less and it still has a similar CCA as the factory battery.
Old 01-17-2022, 05:33 PM   #19387
norcalpb
norcalpb's Avatar
Bought a used HKS header and had it powder coated, and installed Professional Awesome splitter rods on my Verus splitter.
I haven’t been stage 2 since 2018, and this setup (HKs EL header + stock OP/FP + Perrin 2.5” catback) is so much more quiet than my last setup (RevWorks UEL header + Nameless downpipe + Greddy Supreme SP catback), people are 100% right when they say an aftermarket front pipe is a real noise maker.
Old 01-18-2022, 02:41 PM   #19388
juenedgi
juenedgi's Avatar
Drives: 2018 Subaru BRZ with PP
Full lip kit installed! All from 3 different companies (Toyota 86 GR, JUN, & ZELE)
juenedgi is offline   Reply With Quote
Old 01-20-2022, 09:37 AM   #19389
almostquick
Drives: 2017 BRZ PP
Nice setup. Can you give details on what battery hold down and fittings you went with? Also, is that the ATX12 battery?
almostquick is offline   Reply With Quote
Old 01-20-2022, 10:27 AM   #19390
sharkynrk
Drives: 2013 WRB BRZ
also interested
sharkynrk is offline   Reply With Quote
