#29 |
Persona Non Grata
Drives: '15 BRZ (WRB)
With that degree of metalflake in the oil, I'd presume the worst. You can pick up a new short block for around $1800, then have the rest of the parts thoroughly cleaned replacing those that are shaky. Given how little money you currently have in the car, I'd personally lean toward selling it and buying a new one. However, if cash was really tight or I was looking for a project I'd go the short (or maybe even a built block) route.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | TommyW (01-15-2022) |
#30 | |
Drives: 2013 white frs
#31 | |
Persona Non Grata
#32 | |
Drives: '13 Whiteout
#33 | |
#34 | |
| The Following User Says Thank You to TommyW For This Useful Post: | Ultramaroon (01-18-2022) |
#35 | |
#36 |
Less is more as long as the philosophy behind the instructions is understood. Thorough degreasing prior to application is key.
@NoHaveMSG, can you share pics of the alignment pins you made for the timing cover here? That was genius.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (01-18-2022) |
#37 |
Drives: Crapcan
Engine rattle, spun bearing? Now wont start
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (01-18-2022) |
#38 |
U da man
#39 |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (01-18-2022), x808drifter (01-20-2022) |
#40 |
Drives: 2013 frs base
The cardboard cutout for keeping track of the 38 timing cover bolts was cool too.
| The Following User Says Thank You to blsfrs For This Useful Post: | Ultramaroon (01-18-2022) |
#41 | |
Drives: Crapcan
Old flat rate habits never die, they just get applied elsewhere. I actually pulled and stuck them here first. Then did a new sheet where I numbered the tightening pattern and transferred them there. ![]()
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (01-18-2022), Ultramaroon (01-18-2022) |
#42 |
Drives: 2013 Rally Blue BRZ
Oh my god those alignment pins would've been so useful.
When I was cleaning up the gasket material, there was some on the front of the cam gear/hub and I had no idea how a tech could've possibly smudged some there. Until a buddy and I applied the sealant and put the timing cover on and did the same thing ![]() Between all of the gaskets/parts, I'm probably in for about $4k on my rebuild (including a fancy digital torque wrench). That being said, I'm also replacing the timing chain/guides/tensioners, water pump, and clutch/flywheel bearings. I went ahead and bought new head bolts and a new crankshaft bolt instead of risking to reuse them. Also putting in a new overpipe since it was the only stock piece of my exhaust left. I probably overbought fluids and gasket maker though. |
| Toyota 86 after crash engine wont start | maciekg9 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 11-16-2021 04:53 PM |
| Spun Rod Bearing? | itsAlex | Issues | Warranty | Recalls / TSB | 38 | 03-12-2021 09:03 PM |
| FS: 2013 FA20 engine w/spun bearing | Bullnettles | Engine, Exhaust, Bolt-Ons | 9 | 04-05-2017 06:39 PM |
| Engine failure - Spun rod bearing TWICE | dinoniel | Issues | Warranty | Recalls / TSB | 38 | 11-07-2016 01:17 PM |
| Spun Rod Bearing #4 | KE70 | Issues | Warranty | Recalls / TSB | 13 | 07-05-2016 03:17 PM |
