#15 |
Drives: 2022 Subaru BRZ
#16 | |
What break you recommend since wilwood won't be the best , because I'm gonna daily the car as well |
#17 |
#18 |
Drives: '23 BRZ Limited
It's literally in the last paragraph you quoted. Reread it.
#19 | |
Also, it’s sort of hard to fathom that a big brake aficionado such as yourself has never heard of AP Racing, one of the THE BIGGEST names in brakes. At any rate. It sounds like you’ve already made up your mind on the Wilwoods, and are simply here for confirmation bias. GLWT Ps, the likelihood of you ever actually needing a big brake kit is nearing negative integers. |
| The Following 6 Users Say Thank You to Tokay444 For This Useful Post: | Brz-123 (01-16-2022), Jdmjunkie (01-14-2022), OkieSnuffBox (01-14-2022), soundman98 (01-16-2022), WolfpackS2k (02-17-2022), x808drifter (01-16-2022) |
#20 |
Drives: 2020 Toyota 86 GT 6M
I thought dust seals on bbk's were irrelevant since they tend to melt on the track anyways.
#21 | |
ProCrastinationConsultant
you're throwing money at a possible future problems. which is a waste of money until you've come to the point of proving that it's an actual problem. same with everything else on the car. get to know the car, the chassis, the platform first. then start tweaking where you've found it lacks for your individual style. i think you'll find that the stock setup is very well put together, and only minimal tweaks like brake fluid and pad compound will get you very far into what you're looking for. another critical consideration is that track driving and street driving are drastically different styles. most guy's will run 2 different sets of tires, and 2 different sets of brake compounds. specifically because track tires wear too fast for the street, and track brakes have a different heat range that makes them unacceptable for standard, low-use street driving.
#22 |
Drives: '13 Whiteout
#23 |
Track Day Junkie
Drives: 2022 BRZ Limited
I can see being critical of the OP, but there are those of us that can use and appreciate real racing brakes on the track.
I doubt there was this outcry in 2017 when BRZ offered the Performance Package brakes. What's wrong with wanting it now, when the second gen car has more power? In all my effort to find a brake package I keep running into BBK's for only the front or no adapter yet for the front. When I'm at the track I want to be able to easily change pads. I have spent big bucks on light, 17" wheels, racing tires, racing coilovers and suspension pieces so I don't want any heavy slider brakes! I have a wing and I'm building the splitter. Perhaps I'm a bit sensitive about this as I got dragged already by a FB group about this subject (why do you need better brakes) and I see some giving others a hard time in this thread. With the right tires, pads and aero I'm sure you can overpower the stock brakes. We have little rotors and no cooling except for vented backing plates in front and vented rotors. As I see it, AP does not have a mid-level BBK front and rear combo. Nor does Stoptech seem to have anything. I don't think Brembo does either or I'm talking to the wrong people. I'm okay with the PP/STI Brembo rears, but I want floating rotors in the rear as well as front and I don't want "heavy" rotors. If I sound frustrated, I am. |
| The Following User Says Thank You to Scargod For This Useful Post: | soundman98 (02-12-2022) |
#24 |
with the drum brake parking brake, i don't think anyone ever offered a floating disc in the rear for the last gen.
i know there's some mounting brackets that have floated around on ebay for adding a second caliper to the rear disc for the 'drift guys' to add a hydraulic rear dig caliper that could be repurposed for parking brake duties. but it was never an official brand/source... come to think of it, the previous gen had some brake mods that mixed parts from the wrx and wrx sti. could investigate if anything is available that you're looking for for that vehicle, and then it's just a matter of figuring out bracketry to mount them up.
#25 |
Track Day Junkie
Girodisc has them for the PP Brembo's rear and front. I have them on the rear of my STI and they are great.
| The Following User Says Thank You to Scargod For This Useful Post: | soundman98 (02-13-2022) |
#26 |
Drives: 2023 BRZ
Our rear brakes don't overheat, are small (read: lightweight), effective, and cheap. In my experience the accomplish the task very well. I don't see a problem that needs a solution.
Director of Rocky Mountain 86CUP
#27 |
Should be able to re-use parts from the last gen then. Biggest difference in the AP racing thread was the front knuckles had a small clearancing bump on the new bracket. Something most could fix with 2minutes and a grinder
| The Following User Says Thank You to soundman98 For This Useful Post: | Scargod (02-13-2022) |
#28 |
Drives: Miata
Those are Superlite 6-piston front 4- piston rear with 325mm rotors.
And they use the stock parking brake. Seems like a very nice set-up to me. Don't think the fronts will fit the aluminum front knuckles though. https://www.wilwood.com/BrakeKits/Br...option=Premium And again, it's brakes not breaks. Last edited by racingfool; 02-13-2022 at 10:00 AM. |
| Tags |
| big brake kit, brz, gonna happen soon, my big break, wilwood |
| FS: OEM Brake Rotors + Brake Lines + Clutch Line + Steering Rack Bushings | fc3s_johnny | Brakes, Suspension, Chassis | 11 | 10-05-2020 10:26 AM |
| Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! | eauto | Brakes, Suspension, Chassis | 255 | 10-15-2014 01:45 PM |
| FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot | CamryDS | Interior Parts (Incl. Lighting) | 0 | 06-24-2013 11:26 PM |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
