Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-12-2022, 09:43 AM   #337
CZ6T
Drives: 2022 crystal white BRZ
Yea, it's exactly because it's a white pearl. The paint code for both the BRZ and the GR86 is K1X for white so I'm hopeful it'll clean up and match. I'll attempt to clean it when it's warms up a little and provide further photos.
CZ6T is offline   Reply With Quote
Old 01-12-2022, 03:10 PM   #338
Powersfrs
Drives: Frs
Installed kw V3
White line rear lower control arms
Vorshlog top hats
Enkei wheels 18 9.5 +45
PS4S 255 35 18
Alignment/corner balance (for those in southern cali pls check out West End alignment shop awesome super detailed professional)
Ridiculous!
Powersfrs is offline   Reply With Quote
The Following User Says Thank You to Powersfrs For This Useful Post:
Midnightsky (01-12-2022)
Old 01-12-2022, 06:12 PM   #339
Rallywhale
Drives: 2022 BRZ Limited 6MT; '05 OB 5MT
Originally Posted by CZ6T View Post
Added the GR86 premium spoiler on the car, since I'm a big fan of ducktail spoilers and I liked how well engineered the OEM one is.
I think it looks pretty good, and the paint match looks close. I can't tell if it's slightly more white or if my car is just that dirty already.
This looks great! I'm really starting to warm up to the ducktail. Where did you purchase yours? I'm thinking about putting one of these on now instead of the Subaru glossy black spoiler when my car gets here...
Rallywhale is offline   Reply With Quote
Old 01-13-2022, 01:04 PM   #340
shoreline86
Drives: '22 BRZ 6MT MGM
Originally Posted by Powersfrs View Post
Installed kw V3
Vorshlog top hats
PS4S 255 35 18
This looks solid
shoreline86 is offline   Reply With Quote
Old 01-13-2022, 01:07 PM   #341
sds
Drives: '22 BRZ Limited 6MT
Installed kw V3
Vorshlog top hats
PS4S 255 35 18
Front looks good but the rear looks like it pokes? Any fender work?
sds is offline   Reply With Quote
Old 01-13-2022, 01:19 PM   #342
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Originally Posted by jvincent View Post
That is one of the cons of this solution but I've heard that for the most part they get pretty much all of the oil. A little residual old oil isn't going to matter.
I've got a Fumoto coming for the new car myself.
Even a regular oil change might not drain all of the oil. And if you know the engine's oil capacity, it's easy to know how much is left.
You could also compare how much you're draining with the conventional method vs. with a pump, provided you work on an AOTBE basis (same draining method before both tests, same quantity of oil put in, same oil temp when changing it, etc.)
I've heard those might not drain all the grime that is at the bottom of the pan, but then again some cars have no drain plug and seem to survive.
alex87f is offline   Reply With Quote
Old 01-13-2022, 04:44 PM   #343
jvincent
jvincent's Avatar
Picked mine up today and had the winters put on.
My FRS had headers and a tune and the new car is MUCH more responsive. It's going to be a hoot.
The Following 4 Users Say Thank You to jvincent For This Useful Post:
beltax90 (01-15-2022), Jegan_V (01-14-2022), Midnightsky (01-13-2022), Stonehorsw (01-13-2022)
Old 01-13-2022, 05:31 PM   #344
Powersfrs
Drives: Frs
At my height it doesn’t rub one bit even on three wheel motion.
Folks seem to have issues with +35 offsets on the back
+45 seems to be the way for a flush performance oriented stance.
Ridiculous!
Old 01-13-2022, 05:32 PM   #345
Powersfrs
Drives: Frs
Ridiculous!
The Following 3 Users Say Thank You to Powersfrs For This Useful Post:
beltax90 (01-15-2022), Midnightsky (01-13-2022), Simmons (01-13-2022)
Old 01-13-2022, 05:39 PM   #346
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
What's your rear camber?
Old 01-13-2022, 06:38 PM   #347
Powersfrs
Drives: Frs
2.2 back and front
Ridiculous!
dragoontwo (01-13-2022)
Old 01-13-2022, 08:04 PM   #348
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Got Fortune Auto 500's installed on the car by Fortune Auto themselves. I'll post pics soon. Ended up with 7k spring rate in the front and 8k rear. The shocks are six clicks from full soft and the ride is only marginally stiffer than stock but car turns 10x better now.
Got the front to -1.5deg camber and the turn in has been improved 10x. It's very darty and sharp now on turn in. The car feels extremely balanced now with understeer only happening on very cold tires. I still haven't been able to push the limit of the handling but 60mph corners on my favorite backroad have now become 70+, along the way quicker turn in and being able to get on the gas quicker.
Interceptor777 is offline   Reply With Quote
Old 01-14-2022, 05:01 PM   #349
azndavepgh
Drives: 2022 BRZ
Got my Lloyd carpet trunk mat. I ordered the Velourtex in Ebony (962), which has a similar texture to the OE carpet while being more durable. Lloyd also sells a mat that fits on the rear seats when they’re folded down.
https://www.lloydmatsstore.com/catal...ory/view/id/4/
One nice bonus is that the heavier backing adds a bit of sound deadening.
azndavepgh is offline   Reply With Quote
The Following 4 Users Say Thank You to azndavepgh For This Useful Post:
AK2112 (01-15-2022), beltax90 (01-15-2022), Midnightsky (01-14-2022), Simmons (01-14-2022)
Old 01-14-2022, 08:28 PM   #350
Interceptor777
This is about as low as I wanted it to go. Still clears every speed bump and my steep driveway.
The back can be lowered all the way to the tire without rubbing and the front can go another 1/2in or so. Fortune Auto 500's. Name:  20220114_181705.jpg
Sent from my SM-N986U1 using Tapatalk
The Following 3 Users Say Thank You to Interceptor777 For This Useful Post:
beltax90 (01-15-2022), DriveDriftDogfight86 (01-15-2022), dsc_pat (01-16-2022)
WHAT DID YOU DO TO YOUR FRS TODAY? KalbiCool88 Scion FR-S / Toyota 86 GT86 General Forum 1 11-04-2015 10:36 PM
Do you know what today is? Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 26 01-21-2015 02:51 PM
just got my OFT today...help please! carlitosway6891 Software Tuning 9 02-20-2014 10:05 PM
TODAY, TODAY, I GET IT TODAY!!!! :D Trashed675 Scion FR-S / Toyota 86 GT86 General Forum 54 02-14-2013 01:16 AM
