Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-11-2022, 03:36 PM   #113
CincyJohn
Drives: 2022 MT Neptune GR86 Prem.
Originally Posted by Yoshoobaroo View Post
Same here. I was using a shorty 3rd party cable and ran into disconnects. My apple cable is fine so far, but I had to zip tie it in a bundle or it would get stuck in the lid mechanism.
First gen situation, but I found the problem was that the cable end "sat" on the end of the phone holder slot in the armrest area putting significant pressure on the connector and damaging the charging port as a result.
I made an L-shaped insert out of black packing foam so that the connector sits well above the ledge (bottom of the L) and tighter against the holder slot wall and haven't had any problems since. Of course, given the different design of the Gen2 armrest, this might not be the problem or solution.
CincyJohn is offline   Reply With Quote
The Following 2 Users Say Thank You to CincyJohn For This Useful Post:
groovymoonbear (01-11-2022), Midnightsky (01-11-2022)
Old 01-12-2022, 12:24 AM   #114
azndavepgh
Drives: 2022 BRZ
Originally Posted by groovymoonbear View Post
If anyone is curious, there are cables that are “MFi” or “Made for iPhone” which is a licensed thing from Apple that these companies follow to make their cables and they’re often better than OEM Apple ones - main reasoning is the apple ones don’t perform well when twisted or at an angle which is most of the use in a car.
I usually would go off of the third party ones they sell in an Apple store and they have multiple companies which make cables with little pieces that allow them to flex more and some are nylon braided - main thing is they have longer warranties than the apple cables and that’s what you want.
This Lightning cable works pretty well in the center console:
https://www.amazon.com/Satechi-USB-L.../dp/B08SY9WG9V
azndavepgh is offline   Reply With Quote
Old 01-12-2022, 03:46 PM   #115
emce
emce's Avatar
Drives: 22 BRZ Limited
For people having issues with CarPlay - I made sure I had the latest software update and then did a factory reset on my head unit. After about an hour of driving CarPlay hasn't done the reboot thing on me. Note, I also reset my ECU when I did this but I can't imagine that would have any impact.
emce is offline   Reply With Quote
Old 01-12-2022, 03:58 PM   #116
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
I wouldn't really say this is a problem but it's definitely annoying..
When stuff falls between the cup holder and seats oh my god is it so hard to get out, there's literally no room. I occasionally drop my e-cig in there along with some change and random stuff, I always scratch the hell out of my hand trying to get it out.
Took me so long to find a proper seating position for me so I do my best to not move the driver seat unless it's a last resort and I really can't get the item out
suhhh is offline   Reply With Quote
Old 01-12-2022, 03:58 PM   #117
GSX-R1000
Drives: '22 WRB BRZ
The rear driver-side indicator works intermittently (has happened maybe 50% of the time during my first two weeks of ownership). Normally occurs first thing in the morning, where it won't work for the first 10 min then it will start working.
Took it in this morning, of course when I brought it to the shop it was working, although it wasn't working 5 min prior. The techs looked at it and said they ensured the connections were tight but ultimately it was working now so nothing they could do.
As I was leaving and in the parking lot of the dealership, it stopped working again, I went back in to get the tech to prove I'm not crazy. In the 5 min of getting the tech, it started working again (the vehicle wasn't moved during this period). So they are going to order a new rear light assembly, but of course, they are on backorder.
Not the end of the world by any means, just adding this to the thread.
GSX-R1000 is offline   Reply With Quote
The Following User Says Thank You to GSX-R1000 For This Useful Post:
Midnightsky (01-12-2022)
Old 01-12-2022, 05:12 PM   #118
MisterGoober
Drives: IS300, WRX, STI, Bicycle
https://www.amazon.com/Drop-Stop-Ori...ps%2C97&sr=8-5
I think there are cheaper generics on Amazon as well.
MisterGoober is offline   Reply With Quote
The Following User Says Thank You to MisterGoober For This Useful Post:
Old 01-12-2022, 06:22 PM   #119
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
edit: ^^ yeah, that or similar.
Went to a local car club meet sponsored by a toyota dealer a couple years ago when you could still do that.
One of the freebie giveaways for showing up were a pair of fabric covered foam shims to shove between the seat and center console.
There's a slot for the seatbelt button to shove through the middle.
Keep EVERYTHING from sliding under the seat.
I'd miss them if they were gone.
I've seen them for sale somewhere or other. Recommended.
soundman98 (01-12-2022)
Old 01-13-2022, 12:00 AM   #120
C R
Drives: 22 BRZ
I've been having some weird issues with traction control. When I press and release the traction control switch, the TRAC OFF light shows for about 5 seconds and then disappears.
The only way it will stay disabled is if I hold it for more than 3 seconds (disable TRAC and VCS), but that changes to the track display which I don't like. I thought that bar rpm display was only for track mode.
C R is offline   Reply With Quote
The Following User Says Thank You to C R For This Useful Post:
Midnightsky (01-13-2022)
Old 01-13-2022, 12:20 AM   #121
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Single press traction control off turns back on over 30 mph iirc
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
C R (01-13-2022), Midnightsky (01-13-2022), Pete (01-13-2022), timurrrr (01-13-2022)
Old 01-13-2022, 10:36 AM   #122
C R
Drives: 22 BRZ
That would make sense. Couldn't find anything about it on the owners manual.
Old 01-13-2022, 10:48 AM   #123
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
It starts on page 257
The Following 2 Users Say Thank You to dragoontwo For This Useful Post:
C R (01-15-2022), Midnightsky (01-13-2022)
Old 01-13-2022, 11:14 AM   #124
brzsgal
Drives: 2022 BRZ
Anyone ran into issues with the gear indicator? Just noticed it on my drive yesterday that it stopped displaying which gear I'm on.
brzsgal is offline   Reply With Quote
Old 01-13-2022, 02:45 PM   #125
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
You can set this option in the head unit, maybe yours reset for whatever reason? I had to set mine when I first got the car.
Rossman is offline   Reply With Quote
Old 01-14-2022, 11:43 AM   #126
brzsgal
Drives: 2022 BRZ
That's good to know! Thank you. How did you turn it on?
Mine had it on when I got it and it just randomly disappeared. I wonder if this has something to do with the occasional restart of the carplay.
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 10:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 09:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 05:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 05:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 11:21 PM
