| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: Miata
steering knuckles
I prefer the looks of the GR but I want the aluminum knuckles from the BRZ.
Are they interchangeable? Geometry the same? Any thoughts as to why the difference? |
#2 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I believe Savage Geese said they are the same and are easily swappable if you're so inclined.
#3 |
Drives: '20 Tundra, '84 SpecE30
Only $340 each from Subaru! lol
https://parts.subaru.com/p/Subaru_20...8311CC010.html |
#4 |
Drives: 2020 M340i, 2022 BRZ
What's the final verdict on this ?
Did Toyota use the steel ones to save cost or because they are stiffer than the aluminum ones (may give better steering feel) |
#5 | |
The Dictater
Drives: '13 Red Scion FRS
Some possibility not considered is that Subaru and Toyota started with some baseline and then it was Subaru that decided to make aluminum knuckles independent of Toyotas engineering team. |
#6 |
Drives: JRSC BRZ SOLD
They will lessen the un-sprung weight as well. I assume there are published weights somewhere of each.
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | ruturaj001 (04-11-2023) |
#7 |
Drives: 2022 GR86
Be aware that the aluminum knuckles are not compatible with some BBKs on the market.
Otherwise should swap fine. Minimal weight savings, probably not noticable. A lightweight battery is probably better value for money. |
| The Following 4 Users Say Thank You to timurrrr For This Useful Post: |
#8 | |
Drives: 2022 GR86
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | racingfool (01-09-2022), ruturaj001 (04-11-2023) |
#9 | |
Drives: 2022 GR86
| The Following 2 Users Say Thank You to timurrrr For This Useful Post: | racingfool (01-09-2022), SuperTom (04-13-2025) |
#10 | |
Drives: WR Blue Pearl 2022 Subaru BRZ
There is a chance it was done to improve the balance of the car at the limit, Toyota was (again according to reports at the time) really struggling with some of the tuning. |
#11 | |
Its probably cheaper to just get the GR86 front facia for your BRZ.
#12 | |
I don't mind it at all they will probably do some additional tuning and changes as the year go on. |
#13 | |
Drives: 2022 BRZ Limited 6 speed manual
| The Following 2 Users Say Thank You to PBR For This Useful Post: | racingfool (01-09-2022), timurrrr (01-09-2022) |
#14 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Cast iron is stiffer. Would you notice? I don't know, would you notice the rear swaybar being mounted to the subframe versus the body? Would you notice the difference between a 18.3mm hollow swaybar versus a 18mm solid one? Would you notice putting the 18mm bar bushings on the 18.3mm bar to get more squish in the rubber and more stiffness?
The aluminium knuckles by themselves are probably not better or worse, they probably don't make that huge of a difference in the overall setup. I'd spend my money elsewhere on things that would make more of a difference. |
| Drop Knuckles instead of lowering Springs or Coilovers | FRSPacNW | DIY (Do-It-Yourself) Guides | 19 | 10-09-2017 12:42 AM |
| PBM modded knuckles | sid94 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 07-12-2017 05:40 PM |
| Wisefab knuckles | Ryaquinn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 03-27-2014 12:28 AM |
