Old 04-01-2016, 09:00 AM   #43
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Unhappy NEED HELP
Hi sorry for necro thread..
But I just done with installing the TRD Oil Temp gouge, and connected the wiring as the OP did (but I still go the stereo, so i mounted the gauge itself on a different location)
And when I connected the power, the gauge boot up, "reving" the needle, all lights are on and look epic, then the needle go down to 50, and the white lights shut down, then the red light in the arrow shut down, and then it's dead...
I tried when car was on idle, disconnected the plug, that are connected to the gauge itself, and then reconnected it, and it did the same procedure then died again...
So wth can I do to fix this ?
Update: It was just a bad connection for the acc (ignition!) and a bad conmnection for dim, but found the issue, so all good now!
Teclis is offline   Reply With Quote
Old 04-04-2016, 02:54 AM   #44
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
Glad you got it sorted.
Also glad your are liking your TRD 86. Had a look at your build.
You can find mine here @Teclis.
http://www.ft86club.com/forums/showthread.php?t=99536
Tech is offline   Reply With Quote
The Following User Says Thank You to Tech For This Useful Post:
Teclis (04-04-2016)
Old 04-08-2016, 05:46 AM   #45
TRDness
Drives: Toyota GT86
This thread helped me out with my install of these gauges so I thought I'd add my two cents. I wanted to keep my head unit so I did a custom install onto the dash panel. The panel I used was the Blitz Racing Meter Panel (only available in RHD) but there are plenty of companies that make LHD versions.
I also didn't use the sandwich plate to mount the sensors, as I wanted an oil cooler without double stacking sandwich plates and causing a leak. I mounted the temp sensor in the Oil Galley using an OEM Subaru WRX oil galley plug, which has a 1/8th PT threaded sensor hole in it already. I mounted the pressure sensor at the OEM low pressure sensor location, using a relocating pipe with a T fitting at the end. Works very well. Thanks to the OP for the wiring guidance, I wired it into the back of the head unit for power and functionality.
TRDness is offline   Reply With Quote
The Following 4 Users Say Thank You to TRDness For This Useful Post:
FRSBRZGT86FAN (05-02-2016), jcw99 (04-08-2016), nzer (04-09-2016), Tech (04-08-2016)
Old 04-08-2016, 10:27 AM   #46
stevesnj
stevesnj's Avatar
Anyone have the mounting hole diameter size and the face dial size of the TRD gauges? Or maybe the install instructions? Thanks!
My 2016 Build thread
Old 04-08-2016, 10:45 PM   #47
Tech
Tech's Avatar
Nice install! @TRDness
TRDness (04-09-2016)
Old 04-09-2016, 06:00 AM   #48
TRDness
Drives: Toyota GT86
They are 60mm gauges. All the TRD installation instructions are on this website (in japanese) just look for the relevant part numbers:
http://www.trdparts.jp/manual_download.html
The Following User Says Thank You to TRDness For This Useful Post:
stevesnj (04-09-2016)
Old 05-01-2016, 06:08 PM   #49
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I purchased a set. Where do they plug in (power)?
Thanks
Old 05-01-2016, 06:29 PM   #50
Norville Rogers
Drives: Subaru BRZ
Thanks
This might not go well.
Norville Rogers is offline   Reply With Quote
The Following User Says Thank You to Norville Rogers For This Useful Post:
Tech (05-10-2016)
Old 05-01-2016, 10:30 PM   #51
stevesnj
stevesnj's Avatar
Thanks
Use the instructions
Old 05-02-2016, 12:44 AM   #52
Sapphireho
Famous Potatoes
Sapphireho's Avatar
The instructions I have do not show where to plug in in any picture, and text is in Japanese.
Old 05-02-2016, 01:06 AM   #53
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I purchased just the Guages, not the plate that replaced the radio. It did not come wi the instruction sheet with the picture of the power behind the radio.
Thanks for your help. What a bunch of nice guys.
Old 05-02-2016, 10:53 AM   #54
Tech
Tech's Avatar
I may of misunderstood the question, but they don't plug in anywhere.
May I suggest you go to page one of this thread where I explain in detail the colours of the wires you need to tap into and even show a picture of the wiring you need to access.
Each gauge has a small white plug in the back of it which the loom plugs into.
If you have just bought gauges without the wiring looms, then you are going to have problems!
All the best...
stevesnj (05-02-2016)
Old 01-07-2022, 10:19 PM   #55
toxic0015
toxic0015's Avatar
Drives: 2014 gt86
Warning level reset?
Originally Posted by Tech View Post
Each meter has it's own button. The gauges in NORMAL mode continuously monitor the condition they were designed for. If you press a button breifly, it will display the peak value the meter has reached at any point in time. The meter will return to nomal mode after 5 seconds. However, if while in PEAK mode, you press and hold for 3 seconds it will reset the peak value to zero.
While in normal mode, if you press and hold the button for 3 seconds it will display the warning level it is set to. This can be adjusted in increments by further pressing the button.
After 5 seconds of no activity, the setting will be saved and the gauge will return to normal mode.
Awesome thread! Only problem I have is that my warning level keeps resetting each time I turn the car off. Is this normal? I don't want to reset my warning level every time before driving.
toxic0015 is offline   Reply With Quote
Old 01-08-2022, 02:24 AM   #56
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
You probably didn't wire the Hot/Always on power correctly. The gauges need one set of wires directly connected to an always live circuit to save the memory.
EndlessAzure is offline   Reply With Quote
Cyberstork gauges ANREX Cosmetic Modification (Interior/Exterior/Lighting) 53 08-11-2016 07:07 PM
WTB: Gauges AtlasMick Engine, Exhaust, Bolt-Ons 2 03-29-2013 01:04 AM
gauges where the radio is? J-Money Cosmetic Modification (Interior/Exterior/Lighting) 7 02-05-2013 11:11 PM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 04:22 AM
Gauges CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 45 07-24-2010 07:26 PM
