Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-07-2022, 01:59 PM   #1
Noction
Drives: 2018 BRZ Limited
Has anyone attempted to install the JDM LED accessory liner
I ordered this part from JapanParts:
https://www.japanparts.com/parts/detail/?id=62952
And the kit comes with these grey plugin tips that are apparently supposed to plug into a harness that either I could not find behind the bumper or the USDM car does not have. I can always just tap a fuse in the fuse box to get these working, but I dont know which size fuse these lights should use. Has anyone tried to install these yet, and know where they SHOULD plug in? They look and function similar to the 2017+ LED accessory light that went next to the fogs, so if anyone has installed those, your experience might help too.
Noction is offline   Reply With Quote
The Following User Says Thank You to Noction For This Useful Post:
groovymoonbear (01-07-2022)
Old 01-07-2022, 11:23 PM   #2
groovymoonbear
groovymoonbear's Avatar
Drives: ‘22 CWP BRZ LTD 6MT
I haven’t done it, nor would I be any help, but if you figure it out please post here as I will 100% buy these if they work.
groovymoonbear is offline   Reply With Quote
Old 01-08-2022, 02:42 PM   #3
BigT
Drives: Previously evo x
Those look nice, how functional are they? Would love some kind of aux fog light to help cut through foggy morning drives!
BigT is offline   Reply With Quote
Old 01-09-2022, 04:22 PM   #4
groovymoonbear
Figure anything out?
Old 01-09-2022, 06:49 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
They’re not fog lights, they’re accent lighting. They look pretty but they won’t be useful in fog.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
soundman98 (01-09-2022)
Old 01-09-2022, 10:45 PM   #6
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
That's a shame. The car probably doesn't need fog lights but it'd be nice to have an oem option even if it's just for the looks.
Interceptor777 is offline   Reply With Quote
Old 01-10-2022, 02:00 AM   #7
Noction
Finally figured out the install. Easiest way was to tap the amber side marker harness which are very close to where the new accent light wiring sits inside the bumper. This also avoids long cable runs to tap the fuse box and needing to remove the bumper. I cut off the terminals the accessory lights came with, then attached male quick disconnect terminals to the ends. On the side marker harness I spliced in female terminals to each line, so the accessory lights can be easily disconnected if you need to remove the bumper. Basically, connect the side marker and accessory lights in parallel. When finished I wrapped the whole thing in electrical tape and heatshrink for water proofing and zip tied it out of the way. This install could be easily done with t taps too. Just in case, I measured with multimeter, and it shows total draw is way less than the 10 amp limit on that circuit.
Driver side:
-Red side marker wire to white accent light wire.
-Black side marker wire to black accent light wire.
Passenger side:
-Pink side marker wire to white accent light wire.
The Following 5 Users Say Thank You to Noction For This Useful Post:
Busybee (10-16-2023), DriveDriftDogfight86 (06-23-2025), finch1750 (01-10-2022), groovymoonbear (01-10-2022), joemysterio (01-10-2022)
Old 01-10-2022, 02:02 AM   #8
groovymoonbear
Looks absolutely sick, and thank you for the write up. Now begins the internal decision of whether or not I’m capable of doing all that.
Does the LED accessory sit on top of the pre-exiting vent there, or did you have to do some work to remove the front and pop it out?
Haven’t been able to find any information on this, you’re definitely the first person to do it!
Old 01-10-2022, 02:20 AM   #9
Noction
These are direct replacements to the black vent bezels that come stock. I had to pop them out from the back to install the new ones. I didnt have to remove the front bumper. To reach the backside of the bezels and do the wiring, I jacked up the front of the car on jack stands and removed both front tires, then removed some pop clips to pull back the wheel well liners. But Im pretty sure you can complete this install by just turning the wheel to one side, bending back the wheel liner, and doing one side at a time. It will be a bit cramped though.
The Following 2 Users Say Thank You to Noction For This Useful Post:
Busybee (10-16-2023), groovymoonbear (01-10-2022)
Old 01-10-2022, 12:36 PM   #10
NikolaiCherepanov
Drives: 1997 BMW Z3 2.8, 2022 BRZ Premium
Really want a set of these but dont feel like paying $400 in shipping from Japan to the US
NikolaiCherepanov is offline   Reply With Quote
The Following User Says Thank You to NikolaiCherepanov For This Useful Post:
Kona61 (01-29-2022)
Old 01-10-2022, 01:19 PM   #11
SneakyLex
Drives: 2022 BRZ
Awesome. Thanks for this. Might pull the trigger on these now. Would be great if I could get these on the same circuit as the daytime running lights, but side markers are fine too.
SneakyLex is offline   Reply With Quote
Old 01-10-2022, 03:26 PM   #12
joemysterio
Drives: Mini
Hopefully in time we can get it locally... it actually looks really good. Now I want this.
joemysterio is offline   Reply With Quote
Old 01-10-2022, 04:41 PM   #13
OkieSnuffBox
Drives: '23 BRZ Limited
Looks great! Although I hate the idea of cutting into the wiring harness of a brand new car, as a minor as it might be.
Maybe they will see the demand and add it as an option for the '23 models.
Old 01-10-2022, 05:37 PM   #14
Yoshoobaroo
TRACKBREAD
You could make a set of patch harnesses.
New Sub Install, Truck Liner Rattling elxte Electronics | Audio | NAV | Infotainment 3 06-24-2019 10:18 PM
WeatherTech Floor Liner and brand new Cargo Liner halleffect Interior Parts (Incl. Lighting) 13 01-07-2018 05:22 PM
Attempted account hack CAUTION ALL! Chris135 Site Announcements / Questions / Issues 17 04-01-2015 06:42 AM
Attempted Break-in downtown...ughh FR-Sh86 CANADA 22 04-02-2014 09:25 AM
Attempted BRZ headlight theft, happened to anyone else? cwik BRZ First-Gen (2012+) — General Topics 106 02-25-2013 12:42 PM
