Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-06-2022, 02:55 PM   #15
Originally Posted by Stonehorsw View Post
Did anyone use any device like the below to clean the undercarriage? Any recommendations? As mentioned, I plan to use a car wash that has a booth with pressure washer that works in the winter.
Just saw this.
I bought one of those years ago. May be fine if you have super water pressure but didn't do much of anything on a regular garden hose.
I eventually made an attachment for my pressure washer and immediately blew the whole thing apart.
The "max 3000PSI" sticker was a lie!
Stonehorsw (01-06-2022)
Old 01-06-2022, 07:42 PM   #16
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Clay bar doesn't reduce swirls. It actually mars the paint a bit more. You need a polish or cutting compound to remove swirl marks in the paint.
For future reference a full detail includes, in order:
1. Wash and dry
2. Clay
3. Cut (only if necessary, judgement call here)
4. Polish
5. Protect
I wash and dry (drying is important here) once or twice a month if I can, then the rest every 6 months.
Pretty much the process I always done, in this case I did not see any reason to polish. Probably, when the spring comes, I will see better and may repeat, then including polishing the bottom of the side skirt.
Thanks for the comments regarding the mistake of thinking that clay would mar the paint, instead of reducing the swirls. Question here, is there any link that explain better this?
Stonehorsw is offline   Reply With Quote
Old 01-06-2022, 09:44 PM   #17
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Sure is!
https://www.autogeek.net/detailing-clay-bar.html
Here is the full guide.
https://www.autogeek.net/detailingtips.html
Keep in mind, their business is to sell stuff, though the guides and forums are pretty good at autogeek. I think they gloss over the marring a bit (pun intended, but oh so good...) but my experience is even the finer grades of clay make me want to polish afterwards.
soundman98 (01-06-2022), Stonehorsw (01-06-2022)
Old 01-06-2022, 10:27 PM   #18
Stonehorsw
Stonehorsw's Avatar
Sure is!
Thanks. I never done polishing before, just clay and ceramic or graphene. The stuff on the site seems another level, I use Meguiers for soap and clay, normal IPA to prep surface, then graphene from Turtle. Previous car had a very good result also (minus the bumper, that I had so much road rash)
Old 01-06-2022, 11:33 PM   #19
Spuds
The Dictater
Spuds's Avatar
Hey, as long as your happy with it, that's what's important.
In case you wanted to know, my go-tos are:
-Megs hyperwash soap
-Pinnacle clay lube and Griot's clay
-Megs 205 and 105 compounds
-Klasse AIO and HGS Glaze for sealing
Don't get me started on microfiber...
bholliday (01-11-2022), Stonehorsw (01-07-2022)
Old 01-09-2022, 08:31 PM   #20
Burrz
Drives: 2022 BRZ
My pet peave right now is that the touchless carwashes in my area do not clean the lowest part of the body, below the skirt, at all. As described in the following image. The jets simply do not spray there.
Burrz is offline   Reply With Quote
Old 01-28-2022, 03:09 PM   #21
dicegc
Drives: 2022 BRZ Limited
Here is my experience so far (I live in Virgina so have had to take it through washes a few times due to salt).
New touch carwashes are much better, and they get most of the dirt off as compared to touchless (even the newest ones still only take off the top layer of dirt).
Where I live, the touch carwash causes no issues and is pretty new. My family is down in NC where Sam's carwashes are big. When I had my '17 BRZ I never had an issue with them. This past December when I drove the '22 down after getting it, while the carwash didn't hurt the car, it did bend my front license plate (I have it on a tow hook adaptor from my '17). If you were to look at the car head on, it bent the first inch of the license plate in half.
Basically, it all depends. I do also find it interesting it left swirl marks for you as that means it didn't disengage the brushes as it was moving between wheels (the wash I use normally does) and should probably be reported to the operator as that is not normal.
Last thought: When it warms up, I will probably just start washing it more by hand and will get one of those undercarriage wash adaptors you can get for your hose. Normally I handwash, but temps in the teens make it a little too cold to do.
dicegc is offline   Reply With Quote
The Following User Says Thank You to dicegc For This Useful Post:
Stonehorsw (01-28-2022)
Old 01-28-2022, 03:33 PM   #22
Stonehorsw
Stonehorsw's Avatar
Just saw this.
How do you wash during winter? Did you setup a water hose connection through garage or similar?
Old 01-28-2022, 03:52 PM   #23
razgriz12345
Drives: 2022 brz limited (WR Blue)
they do the same where i live i was a little mad about it but it only cost me 10$ so i was like well i guess its the pressure wash station in the next bay for me lol
razgriz12345 is offline   Reply With Quote
Old 01-28-2022, 06:42 PM   #24
I have no garage or way to wash in winter. Just use a quality touchless wash.
Old 01-28-2022, 07:01 PM   #25
Daedex
That One Guy
Daedex's Avatar
Drives: White 2017 BRZ
Based on your needs, you might wanna look into ceramic coatings. Ceramic coatings last for years, and are pretty cheap on amazon and well worth the money. That way you can at least take them through car washes without worrying too much.
Go on amazon and look up some ceramic coatings, and watch a few youtube videos to learn proper techniques, and avoid rainbows. It's pretty straight forward.
Word of warning: you need to wash, clay, and polish before ceramic coating. Ceramic locks the paint in place.
"I am not bound to win, but I am bound to be true."
Daedex is offline   Reply With Quote
Automatic car wash took off clear coat (maybe paint too) norcalpb Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 30 03-14-2023 01:09 PM
Car wash Noodle86 Northwest 2 12-16-2017 09:20 PM
Using handbrake with automatic gt86 and other issues with the automatic version Tommygt86 Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 04:42 AM
Can you recommend a hand wash car wash in Las Vegas whaap Southwest 3 05-14-2013 06:55 PM
What to use to wash this car? ntr0py Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 04-17-2013 10:36 PM
