Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-03-2022, 03:09 PM   #71
groovymoonbear
groovymoonbear's Avatar
Drives: ‘22 CWP BRZ LTD 6MT
Originally Posted by Kado View Post
Is it coming from overhead? Press on the headliner to see if it goes away. If thats it, its your map light console. The clips probably need to be replaced or engaged better.
Not the headliner - behind the display in the car (right edge it sounds like).
It’s happening about 20% of the time, usually after the car is nice and warmed up.
groovymoonbear is offline   Reply With Quote
Old 01-03-2022, 03:40 PM   #72
emce
emce's Avatar
Drives: 22 BRZ Limited
The timing (only 20% of the time, and after the car is warmed up), and relative location sounds very similar to mine. I haven’t been able to track it down yet but it definitely seems mechanical to me.
emce is offline   Reply With Quote
The Following User Says Thank You to emce For This Useful Post:
groovymoonbear (01-03-2022)
Old 01-03-2022, 05:02 PM   #73
tenderization
Drives: 88 RX-7, 2022 BRZ
Is the airbag light coming on then going off a cause for concern? When starting the car today I let go of the button a bit too quick or double-pressed and the car only cranked once. After I started the airbag warning light came on "see owners manual." However turning the car off and on twice made it go away...
I might have had my phone on the passenger seat during this, so wondering if that could have been the cause.
tenderization is offline   Reply With Quote
Old 01-03-2022, 09:54 PM   #74
groovymoonbear
I agree on the mechanical, if it was the speaker vibrating I feel like it would happen more often. Maybe there’s some part of the wire harness that isn’t taped down or in a precarious position and whenever the car warms up the plastic is malleable enough to let them vibrate. Hard to figure out, I don’t want to take it in because I don’t want them removing the dash and introducing a whole host of other problems - this is livable for now
Old 01-05-2022, 11:45 AM   #75
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
Anyone gotten the blinker issue fixed?
SpectreRT is offline   Reply With Quote
Old 01-05-2022, 09:37 PM   #76
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
Did you refill your blinker fluid? Not sure that a fix was available for the blinkers, pretty sure that's just how it is, but hey I could also be completely wrong lol it happens.
Midnightsky is offline   Reply With Quote
The Following User Says Thank You to Midnightsky For This Useful Post:
kaesu (01-05-2022)
Old 01-05-2022, 10:32 PM   #77
diga
Drives: 2022 Subaru BRZ Limited 6MT
Not sure if it's the same sound, but I get what I'd call a higher pitched "whoop whoop whoop" sound. It almost sounds like the Jetson's car or something. Seems to be rev dependent, and interestingly only seems to happen when it's really cold outside (regardless of engine temp, with or without HVAC on). I can hear this more clearly inside the car rather than outside.
If it's not the same sound, especially if yours is more audible with the hood raised, it might just be the high pressure fuel pump. I think that's pretty common from what I've been reading.
yea, it sounds like it's coming from the high pressure fuel pump, I guess the issue is still unfixed, even in the new gen
diga is offline   Reply With Quote
Old 01-05-2022, 10:37 PM   #78
diga
I've had my Apple CarPlay, while using GPS apps (Google Maps or Waze), randomly boot me out, causing me to lose GPS. I had to reach back to unplug/plug back in the USB while driving, not great!
Old 01-06-2022, 09:13 AM   #79
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
There is no issue. HPFPs make noise. They are devices made to solve a complicated problem and it took some manufacturers a while to make them reliable. Some are louder than other based on their design or tolerances within an individual unit. It does not impact performance or longevity.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Pete (01-06-2022), Tcoat (01-06-2022)
Old 01-06-2022, 11:23 AM   #80
suhhh
suhhh's Avatar
Drives: 2022 WRB Limited 6 Speed
Thankfully have not had most of these issues yet knock on wood, haven't even noticed the squeaking seats. However my infotainment system is kind of spotty in regards to recognizing my phone for carplay, just this morning my cord would not recognize my phone even after rebooting my phone/headunit.
suhhh is offline   Reply With Quote
Old 01-06-2022, 12:13 PM   #81
Yoshoobaroo
TRACKBREAD
Apple cord or 3rd party? Apple cord is the most reliable for me.
Old 01-06-2022, 12:24 PM   #82
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Randomly stumbled upon this. Comments suggest cause it not found yet.
Old 01-06-2022, 12:47 PM   #83
That is exactly what my FRS did when I got some bad gas so I tend to agree with the comments on Youtube in that is where the investigation should start. By the comments it would appear that the dealer is starting to just throw parts at it without looking at the basics first.
Old 01-06-2022, 07:48 PM   #84
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Anyone gets a sloppy gear when in turn? I am having trouble changing from 3rd to 2nd during quick turns.. Did not have this problem on gen1. If someone in the area that has a gen2 can compare, I would appreciate. It may be a characteristic that I need to get used to, or find a solution.
Very used to MT, just had 1 AT vehicle in my life. Ran a bunch of vehicle testing, including semis…
Stonehorsw is offline   Reply With Quote
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 09:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 08:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 04:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 10:21 PM
