Old 01-04-2022, 11:27 PM   #82531
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Too big and heavy anyway. Need light and agile
https://www.trade-a-plane.com/search...-type=aircraft
Or how about one you can use from your backyard?
Neither have apple car play... or android auto though
Kiske is offline
The Following 5 Users Say Thank You to Kiske For This Useful Post:
Capt Spaulding (01-05-2022), Dadhawk (01-05-2022), ScoobsMcGee (01-05-2022), soundman98 (01-05-2022), Tcoat (01-05-2022)
Old 01-05-2022, 12:26 AM   #82532
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Too slow.
Spuds is offline
The Following User Says Thank You to Spuds For This Useful Post:
Old 01-05-2022, 06:36 AM   #82533
Too slow.
No torque dip though...
Dadhawk is offline
Spuds (01-05-2022)
Old 01-05-2022, 07:31 AM   #82534
Boomerang
86
Boomerang's Avatar
So I found a drip of oil under the diff, turned out the drain plug was loose.
Boomerang is offline
Old 01-05-2022, 07:37 AM   #82535
Too slow.
They are a momentum plane. If you don't get them you just don't know how to fly.
Tcoat is offline
The Following 9 Users Say Thank You to Tcoat For This Useful Post:
Capt Spaulding (01-05-2022), Captain Snooze (01-05-2022), Dadhawk (01-05-2022), NoHaveMSG (01-05-2022), pope (01-06-2022), ScoobsMcGee (01-05-2022), soundman98 (01-05-2022), Spuds (01-05-2022), x808drifter (01-05-2022)
Old 01-05-2022, 08:44 AM   #82536
ScoobsMcGee
Junior Senior with Cheese
ScoobsMcGee's Avatar
"There's an open recall on your car for the fuel lines. Looks like some of the fittings can leak. There aren't any parts available yet, but Alfa should let you know when they are."
"The car isn't at risk of catching fire, is it?"
"Shouldn't be."
*Italian car intensifies*
ScoobsMcGee is offline
The Following 5 Users Say Thank You to ScoobsMcGee For This Useful Post:
NoHaveMSG (01-05-2022), soundman98 (01-05-2022), Spuds (01-05-2022), Ultramaroon (01-05-2022), x808drifter (01-05-2022)
Old 01-05-2022, 08:46 AM   #82537
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
"Shouldn't be."
This is not okie dokie
spcmafia is offline
The Following User Says Thank You to spcmafia For This Useful Post:
Old 01-05-2022, 09:53 AM   #82538
Spuds
The Dictater
Spuds's Avatar
Now the question is how long it's been dripping. Is that a diff oil change I smell in your future?
Spuds is offline
Boomerang (01-05-2022), humfrz (01-06-2022)
Old 01-05-2022, 10:54 AM   #82539
ScoobsMcGee
The Alfa has an issue...
Just so I don't rant and then leave it open-ended: When I got to the dealership I dealt with the advisor who scheduled the appointment and not the manager. The entire diagnostic process was verifying that the firmware version on the BCM was lower than the updated one for the TSB. It took just over an hour to diagnose, update, perform a multi-point, and then wash the car. No additional upsell attempts. No out of pocket expense.
We did talk about the alignment. He said even if I agreed he would have said it wasn't needed when I got there. Apparently they get a lot of complaints about the stock tires on all Alfas wearing faster than people think they should, and have learned that they are particularly sensitive to misaligned toe. While the QV tires are a gimmick for performance numbers, the normal Ti and Q4 tires should last a lot longer. I didn't bring up the amount they were charging. The advisor isn't the one who sets the prices.
I did park a bit further away from the garage than I normally do.
The Following 3 Users Say Thank You to ScoobsMcGee For This Useful Post:
Old 01-05-2022, 12:26 PM   #82540
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Probably don't have cup holders, either. Meh
Slow is smooth, and smooth is fast
Capt Spaulding is offline
Old 01-05-2022, 12:51 PM   #82541
No but they would have piss tubes so you could dispose of what you drink.
Tcoat is offline
Capt Spaulding (01-05-2022), Ultramaroon (01-05-2022)
Old 01-05-2022, 12:55 PM   #82542
That's bizarre. Those things are in there super tight from the factory. I agree. Drain and refill for science. Gives you an opportunity to marvel at all the iron goo captured by the magnet. That's always fun.
Ultramaroon is offline
Boomerang (01-05-2022), Spuds (01-05-2022), Tcoat (01-05-2022)
Old 01-05-2022, 01:01 PM   #82543
"Checks good on enlisted man"
Tcoat (01-05-2022)
Old 01-05-2022, 02:56 PM   #82544
If you are Bob Hoover good, you don't really need a cup holder....
Dadhawk is offline
The Following 4 Users Say Thank You to Dadhawk For This Useful Post:
Capt Spaulding (01-05-2022), soundman98 (01-05-2022), Spuds (01-05-2022), Tcoat (01-05-2022)
