| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
#15 |
Drives: '22 BRZ
The Michelin PS4 are pretty crappy for road noise, shockingly so.
That said, it's not a super quiet car.
#16 | |
2022 BRZ Build 2013 FR-S Build |
#17 |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
I absolutely agree with throttle response and trans/engine mounts.
The throttle response is A LOT better at 4.5k+ revs but once the revs drop so does the response. If you don't heel toe while slowing down and instead downshift after slowing down, the engine is slow to respond. And not just for shifting, say I'm in 2nd gear at 2k rpm, if I suddenly punch the gas the car takes a whole second before it does anything. It's pretty annoying on extreme uphill roads where you aren't going fast enough to be high in the revs but still need the low end torque. Road noise wise, I'm coming from a Miata so this thing may as well be a luxury cruiser for me. But compared to my 2019 Camry, the road noise is still very low and quiet for me. I really don't think it needs any more sound deadening especially seeing as how you can barely even hear the motor without the fake noise. It's a sports car after all. Also on the trans/engine mounts, I agree. This thing needs stiffer mounts all around. Sometimes 3rd is hit or miss when driving hard since it shifts around a lot. My Miata was also like this until I put stiffer Mazdaspeed mounts on the engine, suddenly 3rd is perfect Everytime. |
#18 |
Drives: '22 BRZ
Yep, the throttle thing is exactly what I noticed too. It just feels lazy when you're not driving it hard. Hoping tunes fix that!
#19 |
Drives: 2022 BRZ and some other cars
I have noticed the “lazy” throttle at low rpm as well. It kinda adds to the fun of “don’t let the rpm drop” flow. Initially, we may want the quirks to go away. In the long run, I think the quirks make the car even more special.
#20 | |
Drives: A mix
Yeah that's what I figured, thanks for the objective data. I'll probably get the hankook v4 then, I really liked those, nice progressive grip, cheap, and quiet. |
#21 |
Drives: Too fast
#22 |
Drives: '22 BRZ Limited 6MT
Exactly my point—you only need a brief drive in a gen 1 to know it’s noticeably slower relative to the gen 2.
#23 |
Drives: 1M
I’m sure the gr86 will be a great fun once i get to (test) drive it. Yet shouldn’t the (generally linear and) quick NA response be the plus to argue against turbo-lag? Does the lazy throttle you guys experience indeed feel like a lagging turbo? ( I know i’ll experience a power drop coming from an 1M, but i expect to get a vibrant low rev behavior instead …?
#24 |
Drives: 2014 Mazda CX-5
#25 |
| The Following User Says Thank You to StE92ve For This Useful Post: | Sport-Tech (12-29-2021) |
#27 | |
The laziness I experienced is, if you let the rpm fall to low range (say all the way to 1k) in neutral, it’s slow to rev back up to say 6k rpm if that’s what you need for a downshift. Low torque wise, other than 1st gear, I drive in the higher rpm range so it doesn’t impact me. |
#28 | |
Drives: 2022 BRZ (Base, Red)
Aside from that, I thought the car was nice from what I could tell - interior was fine, seats comfy, a good size, nice looking exterior, slick and precise shifter feel. I have a red base model on order, just hoping I'll be satisfied by the throttle response without needing to tune and void warranty. |
| Immediate Impressions OFT | Darkparadox911 | Southern California | 39 | 06-04-2020 01:26 PM |
| RS 1.0 Impressions? | Frs x3 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-14-2014 06:57 PM |
| FRS First Impressions | SVThis | Member's Car Journals | 1 | 10-28-2012 09:51 PM |
| First impressions | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-25-2012 10:35 AM |
| Impressions after my first 50 miles | SEC | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 06-22-2012 04:47 PM |
