Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-03-2022, 02:46 PM   #1
MisterGoober
Drives: IS300, WRX, STI, Bicycle
GR86 Spoiler - Just Received
Just received the GR86 duckbill spoiler pre-painted from Japanparts. Spoiler arrived in perfect condition. I'm posting photos below, the spoiler arrived with screws that are supposed to go through the trunk-lid. Not sure if i'm comfortable drilling the trunk, especially if I want a different spoiler down the road. Planning on removing the screws and adding more 3M automotive tape over the areas where the screws are located. Here are a few pics of the spoiler for now:
MisterGoober is offline   Reply With Quote
Old 01-03-2022, 04:36 PM   #2
saltywetman
Drives: 2020 Toyota 86 GT 6M
curious if the usdm duckbill and fender vent trim addons are the same product as the JDM GR catalogue. It should be but the 2019 TRD SE aero kit had an inferior paint job on the aero pieces with everything sprayed gloss black vs the lower portions being satin black
saltywetman is offline   Reply With Quote
Old 01-03-2022, 06:17 PM   #3
Mathmk7r
Drives: VW
following. no way i'm gonna drill the trunk. Maybe i'll wait for an aftermarket alternative that use 3m tape only.
Mathmk7r is offline   Reply With Quote
Old 01-03-2022, 07:24 PM   #4
teabubblez
Drives: BRZ 2018
The OEM Zenki, Kouki duckbills also had studs that needed the trunk to be drilled.
However, a lot of people that I know opted to remove the studs and simply stick it on.
teabubblez is offline   Reply With Quote
Old 01-03-2022, 07:26 PM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I wonder how the production models compare.
Old 01-03-2022, 07:53 PM   #6
MisterGoober
This is the OEM Toyota piece, so i'd assume the production models will be similar. I plan to install over the weekend and will post pics if successful
Old 01-03-2022, 08:23 PM   #7
You guys put a lot of trust in the 3M tape.
I can guarantee that if the manufacturer decided they needed 4 good sized bolts to hold it on properly I would be drilling for good sized holes.
Could always swap trunk lids later if I decided i didn't want the tail anymore.
Old 01-03-2022, 08:50 PM   #8
DaffyDOHC
DaffyDOHC's Avatar
Drives: CRV, INTEGRA
3M only holds for so long. You will be washing your car and daily driving on freeways. That will wear down the tape. My window deflectors started to come off after 2 years. It looked like the tape was starting to dry out and cracking.
DaffyDOHC is offline   Reply With Quote
Old 01-03-2022, 08:56 PM   #9
Chris_f
Drives: 2022 GR86
Have to agree. Also the rear section of the trunk lid is a seperate piece. So you would only have to replace that smaller piece if you wanted a stock, hole free boot again.
Chris_f is offline   Reply With Quote
Old 01-04-2022, 02:32 AM   #10
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
I forsee alot of trunk swaps happening on the 2nd Gen for this exact reason.
Midnightsky is offline   Reply With Quote
Old 01-04-2022, 02:33 AM   #11
chikubi
Drives: 2022 BRZ
You are correct, and I would imagine that there’s a corresponding version that mates with the spoiler and already has the holes for mounting built in. There’s no parts diagrams out yet that I can find to check for sure, but I would expect there to be two versions of that trunk trim piece - one for with and without the spoiler. If there is, then I’d buy the trim and spoiler and the swap would be easy with no damage to the trunk.
Is the Toyota Halo White just Crystal White Pearl with a different name? IOW, the exact same paint? That would be so convenient.
chikubi is offline   Reply With Quote
Old 01-04-2022, 05:35 AM   #12
Same paint different names.
Old 01-04-2022, 11:35 AM   #13
PulsarBeeerz
Drives: JRSC BRZ SOLD
I can count on no hands all the ducktail spoilers that I've heard have come off when properly attached with 3M tape on the GEN1's.lol I have a feeling it will be fine.
PulsarBeeerz is offline   Reply With Quote
Old 01-04-2022, 12:02 PM   #14
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
To me, it looks like the bolts are held on with sticky tape too.
Didn't get a clear view of the two in the center.
Do those just fit under some breakaway plastic flanges?
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
The New Ca-Fi Dashlinq CT Received Aqrab Electronics | Audio | NAV | Infotainment 38 01-18-2017 03:10 PM
Odd compliments you've received about your FR-S/BRZ illmatic_frs Scion FR-S / Toyota 86 GT86 General Forum 205 08-09-2016 10:43 AM
Received my 2nd 86! Silverdub Scion FR-S / Toyota 86 GT86 General Forum 87 12-11-2012 09:01 PM
Finally received my rear spoiler today Roadstercycle Cosmetic Modification (Interior/Exterior/Lighting) 6 07-12-2012 07:42 AM
