Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-03-2022, 03:31 PM   #15
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Originally Posted by Yoshoobaroo View Post
I honestly doubt they’re 6061 T6. These Chinese companies manage to make parts identical to domestic ones but they fail much more often. Material certs are falsified all the time. Almost 20 years ago the place I worked at ordered custom 6061-T6 weldments from China because management wanted to save money. They had material certs and everything. Every single one ended up failing within 6 months while identical spec frames made in the US are still being used at that company every day.
China metals are not to be trusted unless they are independently verified. Faking/bootlegging/knocking off things is so embedded in their culture that it’s almost impossible to avoid. This kind of crap even happened to Subaru with the valve spring recall. That was caused by the Chinese supplier faking the material certs.
Many TÜV certified parts are made in China too, BUT they are independently tested. I would personally never drive on 70$ spacers, but I can’t make that choice for someone else.
I guess I didn't think much about them BSing. Figured if it's engraved in the spacer itself, IT'S GOTTA BE TRUE!
Dzmitry is offline   Reply With Quote
The Following User Says Thank You to Dzmitry For This Useful Post:
Yoshoobaroo (01-03-2022)
Old 01-03-2022, 04:04 PM   #16
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Wheel spacer with stock wheels.
yea exactly!
The engraving also says it’s forged! 6061-T6 is typically cold drawn/rolled or extruded.
On this side of the ocean you quite literally can’t even buy the raw materials needed for these for 70$ per set. I know economies of scale are a thing, still. I machined my own set of spacers about 10 years ago and it cost me $100 worth of aluminum stock.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Dzmitry (01-04-2022)
Wheel Spacers on stock wheels?? Husker BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 08-01-2020 01:05 PM
wheel hub spacer help FujiTofuShop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-27-2017 09:36 PM
Nice wheel cap for the stock wheels Sexyeve Cosmetic Modification (Interior/Exterior/Lighting) 5 04-17-2015 08:02 PM
Wheel locks on stock wheels TM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-19-2013 03:21 PM
Wheel Spacer tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-06-2013 01:44 AM
