Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-31-2021, 05:00 PM   #1
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Wheel spacer with stock wheels.
I added 1" wheel spacers for the stock wheels. It looked bad with stock offset and being lowered IMHO.
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
The Following 7 Users Say Thank You to Simmons For This Useful Post:
dsc_pat (01-02-2022), Dzmitry (01-03-2022), JD001 (01-03-2022), joemysterio (01-01-2022), kaesu (01-03-2022), Varelco (01-01-2022), Wally86 (12-31-2021)
Old 12-31-2021, 07:34 PM   #2
beat1
beat1's Avatar
Drives: 2022 BRZ
Which brand did you go with?
beat1 is offline   Reply With Quote
Old 12-31-2021, 07:40 PM   #3
Simmons
Simmons's Avatar
https://www.amazon.com/dp/B07YS4DNLY...ing=UTF8&psc=1
Old 01-01-2022, 12:58 PM   #4
Simmons
Simmons's Avatar
Added pics from outside.
Old 01-01-2022, 02:46 PM   #5
joemysterio
Drives: Mini
I know next to nothing about suspension and wheels/tires. Does that extra inch require any sort of alignment or adjustment? I also wonder if it would look good on a non lowered vehicle... unfortunately I'll likely not be able to lower mine because of back issues.
joemysterio is offline   Reply With Quote
Old 01-01-2022, 03:18 PM   #6
Krokodil
Drives: Blue BRZ
Originally Posted by Simmons View Post
Pictures look great.
But I read this in the description of spacer:
“ *hand wrench and glue recommended, no impact”
How do you feel about this statement?
Krokodil is offline   Reply With Quote
Old 01-02-2022, 08:35 AM   #7
H380
H380's Avatar
Drives: 2022 BRZ Limited WR Blue MT
"Hand wrench" = use a socket and ratchet Not a impact gun.
"Glue" = Loctite
H380 is offline   Reply With Quote
The Following 2 Users Say Thank You to H380 For This Useful Post:
Krokodil (01-03-2022), Simmons (01-02-2022)
Old 01-02-2022, 09:21 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If they are recommending putting ANYTHING on the threads avoid it.
Chinglish is not reassuring either.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
Krokodil (01-03-2022), Yoshoobaroo (01-02-2022)
Old 01-02-2022, 10:16 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
$70 for 4 spacers with bolts is ridiculously cheap. I would feel uneasy driving on these.
If it keeps the car off the ground, I personally would recommend to go with quality parts. TÜV certified if you can find it (eibach makes some, I’m sure others do too.)
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
Dzmitry (01-03-2022), Krokodil (01-03-2022), spcmafia (01-03-2022), x808drifter (01-03-2022)
Old 01-03-2022, 01:23 PM   #10
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Thought I agree, it seems to use 6061 T6 aluminum, which has great tensile strength. I am certainly not endorsing this, and these spacers do seem a little cheap. But the material doesn't seem to be of issue here. Typically, it is proper installation that is more important when it comes to spacers, such as proper torque, etc. I guess the only other thing that is quite concerning to me is the studs, as these are likely the weak link.
I would also be a little more concerned about the additional stress that suspension components receive with a 1" extension, but I don't have much knowledge on how major of an effect this would have.
Dzmitry is offline   Reply With Quote
Old 01-03-2022, 01:32 PM   #11
spcmafia
spcmafia's Avatar
I believe Engineering Explained touched on some of the benefits / disadvantages on spacers and FT86Speed also talked about it too. It does put a little more stress on some components but nothing you would notice immediately. The way I remember them putting it, lets say you replace your bearings at 60K Miles, random number. The spacers might reduce that 58K Miles, so the damage is almost at negligible spec.
I run 25mm on the front and 30mm on the rear for a flush look.No issues so far and I've put about 20K miles into the car. I paid a pretty penny for mine (Perrin/Eibach) and as long as you do exactly what the instructions say, and you get the right ones, you should be good. It is imperative to do a torque-check after a few miles to make sure things are still within spec.
Old 01-03-2022, 01:46 PM   #12
Robertw
Robertw's Avatar
Drives: 1996 Turbo Miata
Looks good.
Only concern would be the strength of the studs, in the amazon reviews someone snapped the a few of the studs off. Maybe they were over torqueing.
Robertw is offline   Reply With Quote
The Following User Says Thank You to Robertw For This Useful Post:
Old 01-03-2022, 01:59 PM   #13
kinghurl
Drives: BlueBurz
So regarding wheel studs and long term use. I can share my experience with studs. I had an autocross car which had on average 2 wheel changes a week over its lifetime of 40K miles of combined autox and street/track driving. I only used ARP studs, kept them lubed to avoid galling and seizing. Never had a stud failure in 6 years of doing this and in always used a torque gun to install after initially hand securing the first couple threads. Seen many issues with cheap studs and particularly ones not kept lubed. So just beware that wheel studs do require more maintenance. You pay for the cheap ones in reliability. Ideally for a race car you change studs annually, but at a minimum you inspect with each wheel change. For street cars you can be a little less anal, but don't cheap out on studs, or spacers.
Sent from my SM-G955U1 using Tapatalk
kinghurl is offline   Reply With Quote
Old 01-03-2022, 02:12 PM   #14
Yoshoobaroo
TRACKBREAD
I honestly doubt they’re 6061 T6. These Chinese companies manage to make parts identical to domestic ones but they fail much more often. Material certs are falsified all the time. Almost 20 years ago the place I worked at ordered custom 6061-T6 weldments from China because management wanted to save money. They had material certs and everything. Every single one ended up failing within 6 months while identical spec frames made in the US are still being used at that company every day.
China metals are not to be trusted unless they are independently verified. Faking/bootlegging/knocking off things is so embedded in their culture (and legal system) that it’s almost impossible to avoid. This kind of crap even happened to Subaru with the valve spring recall. That was caused by the Chinese supplier faking the material certs.
Many TÜV certified parts are made in China too, BUT they are independently tested. I would personally never drive on 70$ spacers, but I can’t make that choice for someone else.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Wheel Spacers on stock wheels?? Husker BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 08-01-2020 01:05 PM
wheel hub spacer help FujiTofuShop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-27-2017 09:36 PM
Nice wheel cap for the stock wheels Sexyeve Cosmetic Modification (Interior/Exterior/Lighting) 5 04-17-2015 08:02 PM
Wheel locks on stock wheels TM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-19-2013 03:21 PM
Wheel Spacer tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-06-2013 01:44 AM
