Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-27-2021, 09:07 PM   #43
beat1
beat1's Avatar
Drives: 2022 BRZ
Does anyone hear a very subtle rattling/grinding like sound on deceleration in 2nd gear when coming to a stop, it does it also in 3rd but much more noticeable in 2nd? I know this engine isnt particularly the greatest sounding and we can hear a lot of parts working, but I can't remember my gen1 doing this.
Not sure if it come from the trans which would make more sense considering the difference between gears. Cars drives just fine so I don't feel taking a appointment at the dealer yet. Could just be gear chatter/ flywheel chatter, who knows.
beat1 is offline   Reply With Quote
Old 12-27-2021, 09:34 PM   #44
emce
emce's Avatar
Drives: 22 BRZ Limited
Is it happening at any particular RPM? Others have mentioned some rattling around 4k RPM, but haven’t experienced any myself yet.
emce is offline   Reply With Quote
Old 12-27-2021, 09:37 PM   #45
beat1
beat1's Avatar
Drives: 2022 BRZ
I'd have to double check but pretty sure it's lower than that, probably around 2k.
Old 12-29-2021, 12:13 PM   #46
kaesu
Drives: 22 BRZ
My first gen always did, but it would be at lower than 2k rpms. Had about 80k kms before it was written off..I did have to go in once for warranty. It was one of the valves or something common.. the replaced the ecu as well. Lucky it was caught before warranty ended. The cost was about 2600.
kaesu is offline   Reply With Quote
The Following User Says Thank You to kaesu For This Useful Post:
JesseG (12-29-2021)
Old 12-29-2021, 12:21 PM   #47
Quagmire
Drives: 22 BRZ LTD Manual Silver
How about Apple car play and usb music at the same time. I couldn’t get it to work. Not both. Any way around that??
Quagmire is offline   Reply With Quote
Old 12-29-2021, 06:30 PM   #48
sds
Drives: '22 BRZ Limited 6MT
I’m noticing substantial clutch/flywheel chatter upon decel from 2K down, and upon acceleration at low rpm (800rpm up—most notable when rolling through a stop in 2nd).
sds is offline   Reply With Quote
The Following User Says Thank You to sds For This Useful Post:
kaesu (12-30-2021)
Old 12-29-2021, 06:31 PM   #49
beat1
beat1's Avatar
Drives: 2022 BRZ
Thank you, im not alone then
Old 12-29-2021, 06:49 PM   #50
sds
It sounds like a cross between a diesel and a car with a bad dual mass flywheel haha
The Following 2 Users Say Thank You to sds For This Useful Post:
beat1 (12-29-2021), JesseG (12-29-2021)
Old 12-29-2021, 08:18 PM   #51
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Sounds like the same low RPM behaviour as the first gen then.
The Following 4 Users Say Thank You to Yoshoobaroo For This Useful Post:
beat1 (12-29-2021), Daedex (01-18-2022), JesseG (12-29-2021), kaesu (12-30-2021)
Old 12-29-2021, 08:39 PM   #52
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
It took me a while to get used to all the sounds my FR-S made, the 1st gens didn’t try to hide anything. It’s good to hear they haven’t refined the 2nd gens too much.
The engine is “new”, but it’s a stout motor, and most of the other parts of these cars have been tested and proven over time. Sounds like small software issues will be the biggest headache for early adopters. I’m planning on getting my 2nd gen GR86 or BRZ in Fall 2022.
JesseG is offline   Reply With Quote
Old 12-30-2021, 11:29 AM   #53
kaesu
Drives: 22 BRZ
yea i noticed it isn't as prevalent this time around though. At least for now...
Yoshoobaroo (12-30-2021)
Old 12-30-2021, 11:13 PM   #54
Kona61
Kona61's Avatar
Drives: ‘22 CWP
I've got that too. It's noticeable but most other stick cars I've owned have done that as well so I'm not concerned by it.
Kona61 is offline   Reply With Quote
Old 12-31-2021, 09:47 AM   #55
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Kado View Post
First item is known and SOA is looking into it.
Homelink issue is also known. Bring it back to the dealer. It is a bad harness that is missing the power line to the homelink module.
How many wires are running to your mirror?
Those of you having what feels like software problems (blinkers, shift light resetting), make sure you connect the car to WiFi and initiate a software update on the headunit.
What software version do you have now for reference?
Old 12-31-2021, 10:59 AM   #56
Yoshoobaroo
TRACKBREAD
Issues/Problems for early adopters
F41CMM091-781
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
dragoontwo (12-31-2021)
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 09:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 08:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 04:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 04:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 10:21 PM
