Old 07-31-2012, 02:20 AM   #15
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by Moshpit37 View Post
Turbo lag.
Long story short: I want more power at the bottom end of the RPM range for daily driving. Turbos need to spool up more before delivering the boost.
Because waiting till 2700rpm for boost is so passe.
Coheed is offline   Reply With Quote
Old 07-31-2012, 02:21 AM   #16
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by drifter View Post
Eventhough I know there's another thread on tb vs. sc, please tell me why you would rather go with a supercharger. Still learning about this stuff.
The simple answer is it is less complicated thus less expensive and less chance of a breakdown somewhere in the system.
The complicated question is Roots vs. Centrifugal vs. Turbo. I will generalize below.
Roots Supercharger: Powered by the crank pulley (consumes some engine power to operate) Instant boost and response with the depression of your pedal. You get your max target boost almost instantly. This type gives you a ton of on demand torque in the lower rpm range and modest gains in the higher revs. (as with the others these characteristics depends on the size of supercharger chosen).
Centrifugal supercharger: Powered by the crank pulley so it too consumes power of the engine to operate. Has a compressor like a turbo (which is centrifugal). Linear development of boost. This means if your target is 10 psi, then you wont make 10 psi till 7,500 rpm. You will develop boost linearly through the rpm band till you hit 10 psi.
Turbocharger: Powered by the extremely hot high velocity exhaust gasses leaving the engine through the exhaust manifold. The turbo consumes what is considered "free energy" to operate and compress (via centrifugal force) air into the engine. Since more air entering the engine makes more power and makes for more high heat exhaust gasses this synergistically makes the turbo spin faster. This effect is called "spool up" or "spool up time". It means that as the turbo starts to cram more air into the engine, the engine becomes more efficient at spinning the turbo. They work synergistically. The end result is you have usually bad low end torque (~1-3k rpm) then a rapid ramp up in torque (exponential increase) somewhere in the 3-5k rpm (again I am generalizing) reaching max boost and holding that boost and torque to redline. By making the turbocharger "smaller" the spool up can be moved lower in the rpm range to achieve more low end torque but you will sacrifice torque in the upper rpm.
Turbo systems are more complicated due to the implantation of a device in the exhaust stream. One might argue the characteristics of the non-linear spool up is undesireable compared with the characteristics of superchargers but you leech off less power from the engine by going turbo.
The Following 9 Users Say Thank You to sw20kosh For This Useful Post:
bedabi (08-01-2012), Bonburner (07-31-2012), drifter (07-31-2012), Ft-86 Please (07-31-2012), hav0c (07-31-2012), MiguelAE86 (08-01-2012), Mo707 (07-31-2012), SkullWorks (07-31-2012), TPO (07-31-2012)
Old 07-31-2012, 02:24 AM   #17
sw20kosh
Turbo lag.
Then you don't want this HKS system. Not all superchargers are the same.
A centrifugal supercharger like HKS's builds boost slowly and only reaches max boost by redline.
Here is a good example of boost generation by a centrifugal s/c. Look at the bottom portion of the graph where it says boost on the Y axis.
As for Roots style superchargers (which Toyota likes to use) you get boost nearly right away like this Stillen Supercharger. Again look at the bottom portion where it says boost on the Y-axis. It holds 6-7 psi throughout the rev range.
Here is another Roots blower at ~20 psi
Here is the "spool up" of a turbo. Notice its exponential build up.
The Following 4 Users Say Thank You to sw20kosh For This Useful Post:
BrandonFYIA (07-31-2012), denverizzles (07-31-2012), Moshpit37 (07-31-2012), nquillen (11-06-2012)
Old 07-31-2012, 02:44 AM   #18
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Thanks for the info! I'll be waiting until after the factory warranty runs out before I do anything to the engine regardless, but it's awesome to see all the options coming out and I look forward to seeing what's on the market at 36,000 miles!
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
The Following User Says Thank You to Moshpit37 For This Useful Post:
Grateful Dave (08-01-2012)
Old 07-31-2012, 02:56 AM   #19
sw20kosh
Hehe. Roots are great for street use and heavy duty towing.
If you are going for high performance on the track, you will find turbos are the best as they are more efficient by not running off the crank pulley. The turbo lag disappears (within reason) once you are moving on the track since you never want your revs to be below ~4k anyways. You want to stay in your powerband which is 4k+ and thus a turbo that makes max boost at or before 4k will be better at generating more power. There will be no spool up if you stay at the right rpm range while driving. Daily driving doesn't give you the opportunity to do this and thus car manufacturers generally place small turbos on their cars. They will spool up fast (1.5-2.5k rpm) but they will not be able to generate the kind of power a bigger turbo would in the high rpm range.
If TRD sticks to their methods, TRD's supercharger will probably be root's style and it will carry a warantee so this makes it very attractive for street warriors and track junkies alike.
Old 07-31-2012, 03:01 AM   #20
GirlyScions
Drives: Mazda3
That is the hks race kit with the a/c delete. The street kit has the a/c and doesn't look nearly as sexy as the race kit.
GirlyScions is offline   Reply With Quote
Old 07-31-2012, 04:43 AM   #21
HKS Australia
Australia HKS Distributor
HKS Australia's Avatar
Drives: Fast One
HKS Supercharger doesn't rob craknshaft power down low. Have a look at the design here: http://www.hks-power.co.jp/en/produc...r/feature.html and read through the brown colour tabs at the top for more info.
Cheers
HKS Australia
HKS Australia is offline   Reply With Quote
Old 07-31-2012, 05:26 AM   #22
sw20kosh
Cheers
HKS Australia
That statement is misleading. To compress air a supercharger needs power. It gets its power from the crankshaft. Plain and simple. The power needed t turn the compressor wheel doesn't just come out of nowhere.
In regards to "down low" are you talking about the supercharger being on a clutch system where the supercharger is not engaged during low load low rpm driving? If so, roots type superchargers have been developed with the same system. Reduces the parasitic drag on the engine when boost/power is not needed. :happy0180:
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 07-31-2012, 07:10 AM   #23
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Supercharger will give your car more power faster. Turbos cause lag.
[ame="http://www.youtube.com/watch?v=lwIilncWpG8&feature=youtube_gdata_player"]HKS GT Supercharger for 86/BRZ #ft86 #lovecars - YouTube[/ame]
FLIPs_FR-S is offline   Reply With Quote
Old 07-31-2012, 07:51 AM   #24
wcbjr
Drives: 2006 Subaru LGT
In a very general sense, yes. And it depends on the type of blower.
Also very generally, being in the correct gear eliminates that 'lag' and turbos have much more headroom for power at the top of the rpm band.
wcbjr is offline   Reply With Quote
Old 07-31-2012, 08:15 AM   #25
Coheed
Coheed's Avatar
Yes, unless a centrifugal charger is used. You'll have more immediate response with any direct-drive charger method. But I'll still be pulling away after 3000rpm with a disco potato. The compressor on a turbo uses a lot less power from the engine than a typical supercharger.
The Following User Says Thank You to Coheed For This Useful Post:
ft86-UAE (07-31-2012)
Old 07-31-2012, 08:41 AM   #26
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
and always make more power
ft86-UAE is offline   Reply With Quote
Old 07-31-2012, 09:58 AM   #27
Beardo
The GT86/BRZ is sold as being all about throttle response and "purity". Turbo lag is not about waiting till 2800rpms while it builds boost it's about how quickly the turbo delivers once you get back on the throttle.
My understanding (and experience from an Audi S4) is that Superchargers have throttle response. Turbocharged cars are getting better but without an anti lag system they are not on the same page.
Beardo is offline   Reply With Quote
Old 07-31-2012, 10:00 AM   #28
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You race below 2800rpm?
The Following 2 Users Say Thank You to boredom.is.me For This Useful Post:
MiguelAE86 (08-01-2012), wcbjr (07-31-2012)
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 11:20 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 08:11 PM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-28-2012 12:42 AM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 10:10 PM
