Old 12-23-2021, 05:31 PM   #1
Swisher Seattle
Drives: 2017 BRZ LMT w/ performance Pkg
HKS Hi-Power Single Racing V2 vs Spec L V2 (Dual)
I have a 17 BRZ limited with performance package and I can't make up my mind. I have been struggling with this decision for months now. I prefer NA setup. So far the only things I have changed are below
1. Mishimoto Induct Tube (Sound Generator Delete)
2. Michelin PS4S. got rid of stock tires after 4 years.
3. HKS Super Hybrid Intake Filter
4. Redline Full Synthetic Fluid for Rear Diff and Trans
5. Motul dot4 RBF for Brake Fulid
6. Nano Ceramic tint
7. 2 channel dash cam
The last thing I wanna change is hks catback exhaust and I will leave everything else stock.
Single V2 vs Dual V2?
Single Racing V2
Pros
1. The lightest in HKS lineup
2. Cheap ($540)
3. Silencer Included so not too loud
4. Can expect most performance up
5. not sold in Japan
Cons
1. Unbalanced look. (one hole is left empty)
2. Probably louder than spec l v2?
Spec L V2
Pros
1. The best look in the lineup
2. light
3. not too loud (quieter than single racing v2?)
cons
1. heavier than single racing
2. Expensive ($1000-1100)
3. Carbon Fiber tips discontinued (the one I wanted)
Which one should I choose?
PS= I don't go to track. It is the only car I have now and it is my daily.
Swisher Seattle is offline   Reply With Quote
Old 12-23-2021, 06:21 PM   #2
PenGun
Drives: Red 2019 Subaru BRZ
So you are going to spend fairly heavily to change the sound? Am I missing something here? I'm very old.
PenGun is offline   Reply With Quote
Old 12-23-2021, 06:30 PM   #3
alphasaur
friendly
Drives: 17' 86
https://thmotorsports.com/7589563-hk...n=OrderShipped
This is where I got mine from (it is not the carbon fiber as pictured, but the titanium)
The dual canister is still fairly light, its moderately loud.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 12-23-2021, 06:43 PM   #4
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
The weight difference between the systems isn't that big, only a 4.6lb difference (28.4 lbs for Single V2, 33 lbs for Spec-L2).
For the Spec-L2, you can purchase the carbon tips separately.
Both systems rated at 90dB, but Spec-L2 slightly quieter at idle with 59dB vs Single V2's 65 dB.
Biggest difference is the price and aesthetics, and also the material. The Spec-L2 uses higher quality 304SS which is more rust resistant than the Single V2's 409SS, which explains why it has a black coating, but there's a chance the black coating may peel/flake in the long run.
I would personally go for the Spec-L2 between the two.
The way the car sounds contributes greatly to the driving experience. But of course, how much one is willing to spend to achieve a certain sound is another topic
Old 12-24-2021, 01:41 AM   #5
Swisher Seattle
sound + look
Old 12-24-2021, 01:47 AM   #6
Swisher Seattle
Thank you for the info. gotta get that higher quality one!
decided to go with spec L V2
The Following 2 Users Say Thank You to Swisher Seattle For This Useful Post:
Breezio (12-27-2021), NLSP (12-24-2021)
Old 12-24-2021, 12:19 PM   #7
PenGun
OK. Not something I care about. I did have a 69 Cutlass with a 502 and 3" pipes all the way, and it could set off car alarms in parked cars, anytime I wanted.
Old 12-27-2021, 11:47 PM   #8
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
I have an original Spec-L on my 2017. Love it. Highly recommend.
Breezio is offline   Reply With Quote
Old 12-28-2021, 12:30 AM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Your #4 Pro is not going to happen.
Unless you mean by just weight.
Old 12-28-2021, 11:23 AM   #10
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
I have the single exit V2. I love it. Its black and I prefer a single exit on a 4cyl. I bought a left side cutout cover.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 01-03-2022, 07:21 AM   #11
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Single Racing V2
Pros
2. Cheap ($540)
Cons
Spec L V2
Pros
2. light
cons
Spec L is a dream. Pairs perfectly with my catted headers. Their double resonated front pipe is also a great choice in the event that you decide to go catless headers because it will keep the drone/noise levels at a respectable level.
I do have to warn you that they do drone a little. So it is advisable to upgrade your hangers to something thicker like JDM hangers. Is better to replace all 5 instead of the rear 2. Depending where you get them from, takes about a month to get them.
spcmafia is offline   Reply With Quote
hks. hi-power.
WTB: JDL or HKS Dual Resonated Front Pipe and HKS Hi-Power Spec-L Import Want-To-Buy Requests 0 07-13-2021 06:25 PM
HKS Hi-Power Spec-L CBE (Ti-tips) and HKS dual resonated front pipe review Pointmutation Engine, Exhaust, Transmission 8 06-16-2019 10:03 AM
WTB: HKS Hi Spec Power L Dual Exhaust (Ti Tips) Berzerk Want-To-Buy Requests 0 06-26-2017 01:10 PM
HKS Hi-Power Single Racing Version AznKirby Engine, Exhaust, Transmission 4 02-28-2014 09:44 PM
T1R 70R Version 2.0 Power exhaust single & dual ! AJ PwR Engine, Exhaust, Transmission 11 07-12-2013 07:43 PM
