Old 12-23-2021, 11:00 PM   #15
grumpysnapper
grumpysnapper's Avatar
Probably a good idea to add a little WRX hood(style) scoop over it. The A&A Corvette supercharger intercoolers are mounted like this and they claim it only works using a scoop
Has a nicely made scoop as part of the package🙂
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
blsfrs (12-24-2021)
Old 12-23-2021, 11:39 PM   #16
Ashikabi
Ashikabi's Avatar
That's exactly what I was talking about
Sent from my ONEPLUS A5010 using Tapatalk
Old 12-24-2021, 01:45 AM   #17
86TOYO2k17
Drives: 2017 toyota 86
Water meth injection will keep IAT down a lot which will help all temps from snowballing.
Also you can add a couple small nozzles to spray onto your radiator, intercooler, and/or oil cooler/s.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
grumpysnapper (12-24-2021)
Old 12-24-2021, 07:44 PM   #18
FunnyGopher
Drives: 2015 BRZ Limited
Once you have the sandwich plate installed, would you mind showing pics of it? I'm interested in how you have coolers hooked up to run them in parallel.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
The Following User Says Thank You to FunnyGopher For This Useful Post:
grumpysnapper (12-26-2021)
Old 12-27-2021, 08:46 AM   #19
grumpysnapper
Because most of my temp issues are specific to revs vs road speed, part of the plan was to add fans (when I could find the right ones), so today it all came together.
3 x very slim (25mm) 80mm fans, allowing room under the "scoop" for good(ish) flow, but more importantly now a reasonable amount of forced airflow at very low speeds.
Ultramaroon (12-27-2021)
Old 12-27-2021, 04:12 PM   #20
VERY impressive packaging.
grumpysnapper (12-27-2021)
Old 01-05-2022, 06:58 AM   #21
grumpysnapper
This is the plate, its a GReddy (filter relocation) plate Type E.
Its perfect for this because it has 2 x dual full size outlets, both regulated by a thermostat.
The Following 2 Users Say Thank You to grumpysnapper For This Useful Post:
FunnyGopher (01-05-2022), RToyo86 (01-05-2022)
Old 01-05-2022, 09:27 AM   #22
86TOYO2k17
Curious what fans are those? are they at least IP67?
I have posted 80x25 IP67 fans before with 44.3CFM,
this is what I use
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
grumpysnapper (01-05-2022)
Old 01-05-2022, 09:46 AM   #23
grumpysnapper
this is what I use
Yeah these are IP68, 55 CFM, @4500rpm.
I'll be interested to see how they last.
Got them from an old school specialist electrics/solar shop here.
86TOYO2k17 (01-05-2022)
Old 01-05-2022, 01:52 PM   #24
86TOYO2k17
dang, even fancier, you have a link?
assuming they dont cost an arm and a leg, then If I ever need to replace mine I will switch to those.
IP68 should be practically bullet proof.
IP67 is already plenty enough for this application, people use on sand buggies and off road vehicles all the time even.
Old 01-05-2022, 09:52 PM   #25
FunnyGopher
Ah, okay. This is much simpler than I was thinking. Seeing the images, I now realize my Jackson Racing Dual Radiator/Oil Cooler sandwich plate might actually let me run a dedicated cooler as well. It comes with plugs to block the bottom in/out ports that I installed. I'll have to check if the thermostat regulates both sets of ports. Thanks for the pics!
The reason you cut the splash guard lip also makes sense now.
grumpysnapper (01-06-2022)
Old 01-07-2022, 09:14 AM   #26
grumpysnapper
This is the fan, with a link to the local seller, but I guess it should be available all over the place, and not too expensive.
https://www.altronics.com.au/p/f0950...l-bearing-fan/
86TOYO2k17 (01-07-2022)
Old 01-07-2022, 09:20 AM   #27
86TOYO2k17
well aside from the price of the ones I got being dirt cheap, which at 4x or 8x in my case which I guess adds up. Didn't realize how many options where available.
https://www.mouser.com/c/thermal-man...rt=airflow%7C1
almost the same as yours, https://www.digikey.com/en/products/...0U-AE9/5285626 but 60cfm.
if you go to 24v can get 140CFM or 35mm depth you can get 80CFM
now you got me looking at upgrading, just when i thought I could take a break from modding for a little bit lol.
grumpysnapper (01-07-2022)
Old 01-07-2022, 10:12 AM   #28
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
FYI: The Jackson sandwich plate for the dual rad is not thermostatic.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Capt Spaulding (01-12-2022), FunnyGopher (01-08-2022)
Fitted car cover FS FRSfan111 Cleaning and Detailing 7 06-21-2013 06:23 PM
DBA T3 rotors fitted AVOturboworld Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-16-2013 02:28 PM
BRZ fitted with LS2 V8 Tman08 Engine, Exhaust, Transmission 9 12-13-2012 06:28 PM
1st FR-S TRD Kit fitted w/jdm lights SpecPer Cosmetic Modification (Interior/Exterior/Lighting) 160 09-08-2012 12:32 AM
Anybody fitted any STI bits yet ICantAffordAnLFA BRZ First-Gen (2012+) — General Topics 4 07-12-2012 07:59 PM
