Old 11-30-2021, 03:38 PM   #1
zze86
Drives: AE86, AP1
stock clutch alternatives?
Looking for stock clutch replacement. I know Exedy makes a bunch of OEM clutches. I know Aisin is in part owned by Toyota. Any reason to go with one brand over another other than price/OEM-ness?
Aisin CKT078 is $185, includes PP, Disc, TOB and Pilot Bearing
Exedy FJK1005 = $225, includes PP, Disc, TOB and Pilot Bearing
OEM Toyota: PP - SU00300800 - $185, disc - SU00300799 - $100, TOB - SU00307349 - $20 Total = $305
Exedy 15806 = $400, Organic, “Stage 1” includes PP, Disc, TOB and Pilot Bearing. I honestly have no idea what “Stage 1” implies.
I understand that the TOB was an issue and Toyota issued a TSB along with a revised TOB. Is the new Toyota TOB good? Any inputs regarding the other brands? Other quality brands like NTN, SKF?
zze86 is offline   Reply With Quote
Old 11-30-2021, 03:47 PM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
Hey, I can only go off experience but I have an Exedy 'heavy duty' clutch kit in mine (Stage 1 I assume). I was told it uses a WRX pressure plate.
I have done many hillclimbs since then with many runs at each event, very hard launches in the dry (on soft semi slicks) and much feathering in the wet, and have had no issues whatsoever.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 11-30-2021, 04:19 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Get a better fork and pivot while you're at it.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
jeepmor (12-14-2021), sato (01-02-2022), Thefalls (12-09-2021)
Old 11-30-2021, 04:37 PM   #4
Purist
Purist's Avatar
Drives: Subaru BRZ
I've heard this before. What's the issue? What does it change?
Less More
Old 11-30-2021, 09:50 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Adds insurance that they'll not break or bend (more needed for stiff aftermarket clutches for high power outpus though). And as changing them also involves dropping transmission, worth doing at same time. For same reason people usually change throwout bearing at any gearbox dropping work, even if old still works fine.
blsfrs (12-01-2021), Purist (11-30-2021)
Old 11-30-2021, 10:23 PM   #6
Grady
Grady's Avatar
Yes always change throw out bearing and use the updated one!
Old 12-01-2021, 12:38 AM   #7
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
FYI, I wouldn't be surprised if all those options use the exact same TOB. Most of the time, different clutch manufactures just manufacture the disc and (if applicable) the pressure plate. I've seen mild clutch kits from Exedy and Clutchmasters both use whatever TOB was OEM for that application.
BlueWhelan is offline   Reply With Quote
Old 12-01-2021, 05:56 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I changed the clutch lately and changed the throw out bearing with the newer one. I would suggest to stay with the factory clutch, unless you have a much higher power output..
Old 12-14-2021, 02:01 AM   #9
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
I've had the Exedy and new TOB from subi side by side. They are not the same. The new TOB is the same part with a different grease in it now. I have a Southbend Stage 2 clutch. It is an Exedy clutch throughout and laser etched as such. It has the normal stamped steel housing, not the fancy aluminum style on the higher end exedys. So a normal clutch with a stiffer spring package inside. Stage 2 is a 350 ft lb torque hold rating. Stock is in the 180-200 ft-lb holding range if I remember those numbers correctly.
I bumped it up when I got my HKS supercharger. Actually, I lucked out a bit, the TOB failed before the supercharger arrived as it took 5 months to ship. Only regret was the extra ticket punch on the wallet. Glad I went to a stage 2 though, this SC has shown itself to break the rear loose in the rain sometimes pulling hard in second hit 6k plus on my Advan all seasons. Good tires, but once you feel summer tire grip, no all season feels worth a darn.
jeepmor is offline   Reply With Quote
Old 12-14-2021, 10:46 AM   #10
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Exedy clutch
New TOB
Verus pivot/fork
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
e_lunatic (11-11-2023)
Old 12-23-2021, 08:26 PM   #11
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
If you’re planning to keep the car for any significant period of time after you change the clutch, definitely upgrade your clutch fork. This is what happened to mine (scroll almost to the bottom). It’s apparently a fairly common occurrence.
https://www.ft86club.com/forums/show...=144856&page=2
vfrqqq is offline   Reply With Quote
The Following User Says Thank You to vfrqqq For This Useful Post:
blsfrs (12-23-2021)
Old 12-24-2021, 03:45 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Make sure you get a clutch alignment tool with your kit. I forgot that when getting oe parts and luckily had access to a machinist who owed my dad a favor so I was only down an extra day or two.
For that alone I'd go with exedy or aisin for your first clutch, if you hang onto the tool the next clutch/pp can be OEM parts assuming it's not got crazy power.
For that alone it's probably worth getting the exedy or aisin.
ineedyourdiddly
Old 12-31-2021, 12:52 AM   #13
FrickingReallySlow
Drives: 2015 FR-S
I think gen2 stock clutch package is actually a really good gen1 "Stage2" equivalent. Now that we know gen2 makes roughly 240-245 BHP based on dynos.
The prices on gen2 clutch is also roughly commensurate with "stage2" Parts.subaru.com lists them at ~2x the cost as gen1 clutch packs. For anyone with FI its a good alternative that ppl can consider that's also OEM.
The flywheel looks to have the same bolt pattern but someone will need to confirm.
gen 2 Clutch $451. gen 1 clutch $210
gen 2 Pressure plate $355. gen 1 pressure plate $190
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
RedReplicant (12-04-2022)
Old 01-01-2022, 06:51 PM   #14
Little Samurai
Ulli
Little Samurai's Avatar
Drives: Toyota GT86
I also had the problem with the series release lever on the series thrust bearing
I upgraded to a hydraulic bearing from Sachs Motorsport and the standard lever. the series clutch worked well, today i'm racing with a sequential gearbox
https://www.ft86club.com/forums/atta...1&d=1641080925
Attachment 208449
Little Samurai is offline   Reply With Quote
If my stock clutch is about to go out should I replace it with a stock or a stage 1? Bread1 Engine, Exhaust, Transmission 6 01-28-2018 01:24 AM
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
ACT clutch and LWF or stock clutch and Evolution industries LWF Hawk77FT Engine, Exhaust, Transmission 13 12-21-2014 02:14 AM
86 Alternatives ??? H8R GTS AUSTRALIA 33 09-05-2012 12:59 AM
Nav alternatives? Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 33 04-13-2012 04:27 PM
