Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-22-2021, 11:38 PM   #15
eyeballs
Drives: '22 BRZ
I've had a speaker rattle on the drivers side since the car rolled off the lot first week of November. No other issues.
eyeballs is offline   Reply With Quote
Old 12-23-2021, 12:12 AM   #16
Strat_FRS
Drives: 2015 FRS for daily and track use
Originally Posted by ForeverCar View Post
~500 miles on mine. The only “issue” I have noticed is a resonance/rattle that sounds like loose catalytic converter heat shield when reving to/past ~4500 rpm to rev match. I’ll see how it develops.
It's no the cat, it's the motor itself. When you let off and it coasts down in high RPMs there is a rather harsh rattle/resonance.
Strat_FRS is offline   Reply With Quote
The Following User Says Thank You to Strat_FRS For This Useful Post:
ForeverCar (12-23-2021)
Old 12-23-2021, 12:32 AM   #17
ForeverCar
Drives: 2022 BRZ and some other cars
Interesting.
ForeverCar is offline   Reply With Quote
Old 12-23-2021, 01:10 AM   #18
MisterGoober
Drives: IS300, WRX, STI, Bicycle
Interested to know more about the mirror issue. Anyone know where the harness is, is it a bad mirror, or the short harness between the mirror/dome area? Hoping it's not a long harness going all around the car.
MisterGoober is offline   Reply With Quote
Old 12-23-2021, 07:12 AM   #19
emce
emce's Avatar
Drives: 22 BRZ Limited
Per Kado's post (https://www.ft86club.com/forums/show...04&postcount=2) it's a bad harness. I installed a homelink mirror myself, and have the same issue. There's wiring that's run around the vehicle up to the dome console. With the mirror kit, you get an additional 3 wire harness/adapter you plug into that and run down to the mirror. That adapter goes from 3 to either 8 or 10 pins at the mirror... I'm guessing they just don't have one of the 8 or 10 mirror pins mapped to power for the homelink lead.
emce is offline   Reply With Quote
Old 12-23-2021, 08:53 AM   #20
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
Are you saying the wire harness that came with the mirror needs to have more than 3 wires? If so, that is a simple fix. Or are you saying the wiring in the car needs to be changed or connected to power?
PhatFreshPrince is offline   Reply With Quote
Old 12-23-2021, 11:10 AM   #21
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
The patch harness is bad, the car is providing power/ignition/ground, that’s enough. The patch harness doesn’t have the HL connected to the ignition looks like.
Old 12-23-2021, 11:59 AM   #22
HyperSCSI
Drives: 2022 BRZ
And I thought I was crazy with the blinker issue..
HyperSCSI is offline   Reply With Quote
Old 12-23-2021, 12:28 PM   #23
Interceptor777
Interceptor777's Avatar
Drives: 2022 BRZ, 1999 "touge-spec" Miata
I haven't felt this under high rpm, but I've noticed a certain deep resonance that this car has when it's idling, especially when cold. If the car is inside a garage it really bothers your ears.
Not complaining but just observing.
Interceptor777 is offline   Reply With Quote
Old 12-23-2021, 04:50 PM   #24
Rcode
Rcode's Avatar
Drives: Ford Fiesta ST, 2022 Subaru BRZ
+1 to the first two. Haven't noticed the seats squeaking but the shift boot definitely does when it's cold, which I think is just normal.
Apple CarPlay crashes and reboots apps pretty frequently on me, and I've noticed the "meter" settings for the dash reset to off randomly - eg, the rev warning and selected gear display.
Other than that no real issues that I wouldn't consider normal at just over 2800 miles.
I'm having issues with Android Auto as well, interesting to see Carplay having some as well. Occasionally it just crashes saying device is not compatible. I always seem to have that error message if I turn off the car and leave the phone plugged in while say getting gas or something. Upon turning the car back on the same message appears.
Unplugging the phone for a minute or two sometimes remedies the problem, but not always. It's odd that it works fine in my parent's Crosstrek.
The only other issue I have is that the blind spot monitoring doesn't beep when a car is beside me and the blinker is on. The settings indicate the beep is on, but nothing. The shift beep does work though. Don't know if I'm missing something though.
Otherwise, and knock on wood, the car is solid. I haven't noticed any blinker issues yet.
Rcode is offline   Reply With Quote
Old 12-23-2021, 05:14 PM   #25
Yoshoobaroo
TRACKBREAD
CarPlay has been rock solid for me. Some cars/phones can be picky about cables though.
Old 12-23-2021, 11:28 PM   #26
Midnightsky
Midnightsky's Avatar
Drives: 2022 BRZ WRB
This is a great thread, thank you everyone for contributing.
Midnightsky is offline   Reply With Quote
Old 12-24-2021, 03:50 AM   #27
JD001
JD001's Avatar
Drives: Subaru BRZ
"Them crickets,them crickets, them crickets, they were banished from the series 1 only to haunt the series 2"..
Old 12-24-2021, 03:51 AM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
My friend all threads on this forum are "great".. obviously some hit the true enlightenment but only to be banned or or left to rust in the history of time.
Anyone not buying to avoid early issues like 1st gen FRS? stocktc1 GR86 General Topics (2nd Gen 2022+ Toyota 86) 203 09-23-2021 10:11 PM
Buying an early build in the fall, but some issues with these cars are worrying me... RyMi BRZ First-Gen (2012+) — General Topics 34 02-27-2019 09:56 PM
New 2014s still have early issues? Prospective buyer Lord09 Issues | Warranty | Recalls / TSB 25 06-14-2014 05:42 AM
Early problems - speaker rasp and long turnover Hawaiian Issues | Warranty | Recalls / TSB 44 08-30-2013 05:39 PM
Initial Issues / Problems JDMSushi AUSTRALIA 56 09-30-2012 11:21 PM
