Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-21-2021, 02:45 PM   #141
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by DocWalt View Post
What you actually want are hub to fender measurements. Pinch weld to ground is affected by tire OD.
And technically tire pressure. But most people are running sizes within a few % OD of stock. And if the tire is given, we can compare the OD vs section width as well.
On level ground, pinch weld to ground is much easier to get consistent readings vs trying to get a tape measure straight up and down to the fender while being in the middle of the hub.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
timurrrr (12-21-2021)
Old 12-22-2021, 12:06 AM   #142
BRZ-G1
Drives: 2022 BRZ
Wanted to add this to the data.
I have 18x8.5 44et with 245/35/18
These are the wheel tire combo with stock suspension. Seem nice and flush. Will likely tuck in a bit more as the car is lowered, gaining a bit more negative camber.
I have installed Ohlin coilovers 2 days ago. Will be adjusting and lowering more from what Ohlins came as. Waiting for them to settle. Will follow up with images when lowered, corner balanced and aligned.
PS: This is my first Subaru. I had high expectations, and mostly it has been surpassed. However, installing the new coilovers, I noticed that the stock rear control arm is literally junk. This thing was warping with torque application, what a shame. I will be looking to replace this piece with an aluminum one. Subaru, not Toyota, also has the front lower control arm made of aluminum vs the same thin steel junk in the GR86. One less thing to worry. If you guys get the GR86, look into swapping with the BRZ aluminum piece. Savagegeese mentions this in his YouTube video as well.
BRZ-G1 is offline   Reply With Quote
The Following 4 Users Say Thank You to BRZ-G1 For This Useful Post:
dsc_pat (12-22-2021), joemysterio (01-11-2022), Lonewolf (12-22-2021), Pete (12-22-2021)
Old 12-22-2021, 02:01 AM   #143
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Welcome to the club, hope you enjoy the car even more as time goes by!
You've probably meant the knuckle, not a control arm?
Old 12-22-2021, 02:17 AM   #144
BRZ-G1
Drives: 2022 BRZ
Exactly, thank you for clarifying!
Old 12-22-2021, 03:55 AM   #145
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
That looks literally perfect to me. Looks flush enough but it looks like it still tucks in behind the fender edge so there’s no rubbing even at full deflection? I don’t understand why people want more aggressive offsets than this.
7.5 ET48 —> 8.5 ET44 = -16.5mm fender clearance. I expected to need roughly 10-15mm spacers to get the stock wheels where I want them, so your setup is pretty much exactly there.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Pete (12-22-2021)
Old 12-22-2021, 05:01 AM   #146
BRZ-G1
Drives: 2022 BRZ
Corrected:
Original wheel is 18x7.5 et48, yes!
Old 12-22-2021, 05:19 AM   #147
Varelco
Drives: '15 GT86 & '22 GR86
Original wheel is 18x7 et48, not 7.5
No he is correct, the original wheel is 18x7.5.
3min20sec into this video;
That fitment looks perfect, was waiting for someone to fit a 8.5j with an ET in the 40s based on what's been done so far.
Its nice to see the stock wheels have pockets so bolt on spacers should clear if the nuts protrude more than the face of the spacer.
Varelco is offline   Reply With Quote
The Following User Says Thank You to Varelco For This Useful Post:
Yoshoobaroo (12-22-2021)
Old 12-22-2021, 06:04 AM   #148
BRZ-G1
Drives: 2022 BRZ
Sorry, my mistake. The original US spec 2022 BRZ Limited has 18x7.5 wheels. I had missed the fraction 1/2
The Following 2 Users Say Thank You to BRZ-G1 For This Useful Post:
dsc_pat (12-22-2021), Yoshoobaroo (12-22-2021)
Old 12-22-2021, 11:40 AM   #149
OkieSnuffBox
Because once the car is lowered, they are going to be more tucked than a '73 Gran Torino?
My Gen 1, with appropriate camber for the tires (so like -3.5 fr -2.8 rear), with 18x9.5 ET 38 255/35 weren't flush. They still tucked in a touch at the top. But it looked mean.
Old 12-22-2021, 11:47 AM   #150
Yoshoobaroo
TRACKBREAD
Im aware, true flush fitment doesn’t work anyway, especially when lowered. You need ~5-10mm (depending on the wheelarch geometry) of tuck to clear the wheel arch on compression.
Old 12-22-2021, 08:54 PM   #151
perryair
junior mafia
Drives: ‘20 sti limited
Originally Posted by soilent View Post
I'm personally a fan of 17x8 +35. Cheap, lightweight, pretty flush, and great for a daily. The only issue is there seems to be a somewhat limited selection if you're going for under 17 pounds at a decent price. Outside of that, I think it's the perfect size. RPF1 and Drifz 317SB are what I'm trying to decide between right now.
i had that 17x8 35 rpf1 on my gen 1 and agree that it looks great. only small issue is that you have tomget the convex instead of concave face.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 12-23-2021, 02:43 PM   #152
Re_Invention
Re_Invention's Avatar
Drives: '22 Tacoma, '19 Macan, '22 BRZ
Please update with Ohlins impression, when available - I'm looking to get the road & track soon, too. Just got the car Monday, need to finish break in.
Cheers,
Colin
Re_Invention is offline   Reply With Quote
Old 12-23-2021, 03:21 PM   #153
*Axel
Grey Man
*Axel's Avatar
Drives: 22 MT BRZ
P245/45WR17 on on 7.5" x 17" stock "Premium"????
My question is: Will PRIMACY MXM4 - SIZE: 245/45R17 the wonderfull drifting tire or most other 245 wide tires fit the stock 7.5 x 17 wheels?
I like the Primacy's. I intend to drive them until they are slicks. I have no prob losing traction with them unless I want them to.
So, can I squeeze 245s onto the 7.5 wide 17" wheel? If not, how about 235s?
I want to use the stock 7.5x17 wheel.
*Axel is offline   Reply With Quote
Old 12-23-2021, 03:33 PM   #154
Yoshoobaroo
TRACKBREAD
Originally Posted by *Axel View Post
My question is: Will PRIMACY MXM4 the wonderfull drifting tire or most other 245 wide tires fit the stock 7.5 x 17 wheels?
The stock tires are Primacy HP, not Primacy MXM4. There’s a big difference, the HPs are much better.
timurrrr (12-23-2021)
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
