Old 12-13-2021, 05:58 PM   #1
CSG Mike
CSG Mike's Avatar
CSG CP pad use update
CSG CP pads with about 7 hours (rounded down) of track use on my 2022, plus ~2500 mixed street use.
All tires used are stock, or similar/lower grip. The CP is a street pad that can handle light duty track use with lower grip tires. These are not meant for track rats, veterans running competitively with super 200tw "street tires", slicks, or heavily modified track cars. They're designed for folks who want a silent, OE+ street pad, that has the capacity to handle light track duty and/or isolated high speed stops.
~0.75 hours at Streets of Willow Springs
~2 hours at Speed Vegas
~1.25 hours at Auto Club Speedway (heavy brakes, full sessions)
~4 hours at Buttonwillow (full sessions)
Mixed drivers at all venues.
- No radial taper on the inboard pad.
- Outboard pad had a small radial taper. Suspected cause to be the caliper bracket tacoing when hot under heavier load. Inboard pad/caliper is secured onto the knuckle, but the outboard pad has no mounting at the center. Par for the crouse on stock calipers while running long sessions.
Old 12-20-2021, 11:30 PM   #2
eyeballs
Drives: '22 BRZ
How do these pads compare to the ferrodoDS2500?
eyeballs is offline   Reply With Quote
Old 12-21-2021, 12:18 AM   #3
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Hi eyeballs,
The CSG CP has a performance ceiling similar to some entry level race pads with high fade resistance (for a performance/dual compound pad), but has all the benefits of a proper street pad, including lower dust and lower noise qualities.
Thanks,
CSG
CounterSpace Garage is offline   Reply With Quote
Ofm update HLHachiRoku Software Tuning 0 04-27-2016 12:19 AM
a little update :) ilpad Northwest 15 06-12-2014 06:36 AM
Evo X update tahdizzle Other Vehicles & General Automotive Discussions 11 03-28-2014 03:47 PM
Mod Update.... UM FRS CANADA 12 12-25-2012 01:50 PM
GT5 2.0 Update!... MF_DEUCE Off-Topic Lounge [WARNING: NO POLITICS] 11 10-15-2011 02:53 PM
