Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 12-17-2021, 04:23 PM   #1
nevermore_
Drives: '22 BRZ
Clutch suddenly feels slightly scratchy/knurly?
This started for me yesterday suddenly. The clutch feels a bit rough or almost grinding kind of feeling when pressing/releasing. I don't feel it in neutral and not all the time while driving. I never felt that before and was super smooth.
Is this an issue? Its been only 700 miles so far with no hard driving and less than 4k rpm. Also, I mostly take off in 2nd gear. Should I not be doing that?
nevermore_ is offline   Reply With Quote
Old 12-17-2021, 04:31 PM   #2
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Why do you take off in 2nd gear?
The Following User Says Thank You to timurrrr For This Useful Post:
funwheeldrive (12-17-2021)
Old 12-17-2021, 04:31 PM   #3
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Why would you use 2nd gear. edit OOPS beaten again ^^^
The Following User Says Thank You to gen3v8 For This Useful Post:
Old 12-17-2021, 04:38 PM   #4
PhatFreshPrince
PhatFreshPrince's Avatar
Drives: 2022 BRZ Limited SBP
I could see staring in second gear if you are in snow, but you being in LA then NO you should start in first. Starting in second is probably not the cause of your issue. What is grinding.. the car's gears or the act of pushing the clutch in and out?
PhatFreshPrince is offline   Reply With Quote
Old 12-17-2021, 04:44 PM   #5
nevermore_
Drives: '22 BRZ
Its when pushing the clutch in/out. I felt it was easier to use 2nd gear without revving too much. Can stop doing that.
The Following User Says Thank You to nevermore_ For This Useful Post:
gen3v8 (12-17-2021)
Old 12-17-2021, 05:54 PM   #6
Mcgiiver
Drives: 2022 BRZ Premium, 2009 Toyota Tacom
Wearing out clutch
Starting in 2nd is not likely the cause of your issue, but you are definitely wearing out your clutch disc prematurely .
Mcgiiver is offline   Reply With Quote
Old 12-17-2021, 05:56 PM   #7
tenderization
Drives: 88 RX-7, 2022 BRZ
I have ~1100 miles (but a lot of highway) but no clutch chatter issues so far (that's what it sounds like).
tenderization is offline   Reply With Quote
Old 12-17-2021, 10:21 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
you paid for all the gears, this cars more fun if you use them all!
Old 12-18-2021, 01:19 AM   #9
Sasquachulator
Pavement Grey
you should start it in third......
The Following 3 Users Say Thank You to Sasquachulator For This Useful Post:
Jdmjunkie (12-18-2021), Kona61 (12-18-2021), PhatFreshPrince (12-18-2021)
Old 12-18-2021, 07:59 AM   #10
emce
emce's Avatar
Drives: 22 BRZ Limited
I'm not totally sure what knurly and scratchy mean in terms of the clutch feel, but I would say mine did weird things around that mileage. After the clutch and transmission would warm up, it would start grabbing a lot more immediately and it would be harder to ease it into gear - always felt like I was dumping the clutch. This was especially annoying taking off in first or shifting into second.
This has since stopped for me, and I associated it with something that was happening as the clutch was breaking in. This is the first car I've owned brand new with a manual, so I have no science to compare this to, just assumptions.
emce is offline   Reply With Quote
Old 12-18-2021, 01:14 PM   #11
Pie
Drives: Tesla
If you're still over revving it in 2nd, then you probably started wearing down the clutch prematurely.
It's better to modulate the throttle in first instead of band aiding the issue by starting in 2nd.
Pie is offline   Reply With Quote
Old 12-18-2021, 01:37 PM   #12
LoneFashion
Drives: Arriving
Oh man, I think I noticed this too. But I always take off in first gear.
Edit: oh misread, I meant the actual shifter for myself
LoneFashion is offline   Reply With Quote
Old 12-18-2021, 09:28 PM   #13
sds
Drives: '22 BRZ Limited 6MT
Stop starting in 2nd. You've likely hotspotted the flywheel already. If you take it easy moving forward, things might improve...
sds is offline   Reply With Quote
Old 12-19-2021, 12:37 PM   #14
soundman98
soundman98's Avatar
CVT BRZ lol
slip it till it goes!
Clutch pedal feels rough Meep Issues | Warranty | Recalls / TSB 6 01-14-2022 05:47 PM
Clutch suddenly sticking, squeaking, and killing the car artizhay Engine, Exhaust, Transmission 9 08-20-2018 01:09 AM
Cruise control and current gear suddenly not working, but suddenly worked again btan219 Issues | Warranty | Recalls / TSB 2 06-30-2018 02:09 AM
HELP! Clutch feels funny dsteezy86 Northern California 2 08-09-2017 01:08 AM
Clutch feels 'scratchy/frictiony/grindy' eightysixer Issues | Warranty | Recalls / TSB 23 01-10-2016 08:32 PM
