Old 12-14-2021, 09:44 PM   #1667
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
TIL cutting a round part in half with some precision is difficult.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Dadhawk (12-15-2021), Ultramaroon (12-15-2021)
Old 12-15-2021, 04:00 PM   #1668
It's even tougher with more precision.
bcj (12-16-2021), NoHaveMSG (12-15-2021)
Old 12-15-2021, 04:10 PM   #1669
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What's that saying about how every thousandth, cost a thousand or something, something.
What sucks is it is a stamped wheel half. So there is no center to mark and it is formed with multiple steps and the measurement I think they messed up is down where my calipers don't reach and I don't have a set of inside spring calipers. So cutting it in half was the easiest solution I had to get it done.
soundman98 (12-15-2021), Ultramaroon (12-16-2021)
Old 12-16-2021, 02:00 AM   #1670
It's damn near impossible with a hole already in the center. Gotta do what you gotta do.
NoHaveMSG (12-16-2021), Tcoat (12-16-2021)
Old 12-16-2021, 05:35 PM   #1671
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I couldn’t sleep with those numbers and bought an inside spring caliper to verify. I did get close but I should have just waited and used the right tool for the job.
I just got the radius and used my caliper as a gauge to mark center on the outer lip. It worked okay for a rough estimate.
soundman98 (12-16-2021)
Old 12-16-2021, 05:39 PM   #1672
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Wtf are you trying to do?
Old 12-16-2021, 05:50 PM   #1673
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Working on opening tooling with new vendor for this stamped rim half. Going over manufacturing drawings which ended up not being right.
Spuds (12-16-2021)
Old 12-16-2021, 06:03 PM   #1674
Spuds
The Dictater
Spuds's Avatar
You could just put it in a vise and measure from one side of it, assuming you confirm the sides of the vise are parallel.
Old 12-16-2021, 06:06 PM   #1675
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I needed the ID at the top of the bend.
Old 12-16-2021, 06:11 PM   #1676
Spuds
The Dictater
Spuds's Avatar
I guess I still don't know what you are trying to do lol. I thought you were trying to cut it in half still. Good luck though!
Old 12-16-2021, 06:38 PM   #1677
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Honestly, I am not so sure I do either
Spuds (12-16-2021), Ultramaroon (12-16-2021)
Old 12-16-2021, 08:42 PM   #1678
@NoHaveMSG easiest way I know to mark the center line of a circle....
Take a board (or cardboard, or whatever) and make a straight line down the middle. Then from the bottom of the line, form a V with two boards at a 45 degree angle from the base of the line. Now slide whatever you want to mark into the V and follow the line.
You can also cut the line through the board, turn it over and make the mark that way, or use the jig and the line to cut the object.
It also has the advantage of working for any size object that fits in the V.
Amazon sells something similar that uses a ruler but I like mine better because I can make it any size I want.
I have a similar jig I made for a table saw that lets me cut half circles if needed, and works for cutting wood for picture frames (45 degree angles). Saw this a 100 years ago in one of the woodworking mags.
NoHaveMSG (12-16-2021), Ultramaroon (12-16-2021)
Old 12-16-2021, 10:23 PM   #1679
soundman98
ProCrastinationConsultant
soundman98's Avatar
lol, i would've just chop-sawed it in half.
the lug nut holes are centered, so i'd just mark across the lug holes, and chop saw those. instant direct center.
Dadhawk (12-17-2021)
Old 12-16-2021, 11:47 PM   #1680
Remember when a hundred years ago meant 19th century?
That's a neat trick. Thx!
Dadhawk (12-17-2021), Spuds (12-16-2021)
OFT KC learned Nah Software Tuning 3 03-17-2016 12:52 AM
Learned some interesting things about my car today... SisterBlue22 Scion FR-S / Toyota 86 GT86 General Forum 12 08-09-2015 02:23 PM
Everything I know, I learned from the internet. Chillswitch Cosmetic Modification (Interior/Exterior/Lighting) 17 01-09-2015 02:31 PM
KC learned, what does it mean? wparsons Software Tuning 4 08-15-2014 11:37 PM
Today I learned (TIL) IloveBaldEagles Off-Topic Lounge [WARNING: NO POLITICS] 5 03-16-2013 08:15 PM
